Amp research step OBD harness or no?
Discussion in 'General Tundra Discussion' started by Cement20, Mar 18, 2021.
  1. Mar 18, 2021 at 8:39 PM
    Cement20
    Cement20 [OP] New Member
    Landon
    SL,Ut
    2020 Cement Tundra Crewmax Sr5
    -ThrashedOffroad Send-It Suspension -ThrashedOffroad Billet UCA -ThrashedOffroad 6 switch pod -ICON stage 2 leaf springs -Coachbuilder 1” shackles -TimbrenIndustries Bump stops -RocktrixWheels 18x9 RT111 Teardrop matte black wheels -NittoTire 35x12.50r18 RidgeGrapplers -Ironman4x4 RAID Front bumper -Diodedynamics fog,bumper,ditch,chase and rock lights, interior LED Swap -RCIOffroad engine, transmission and cat skid plates -SbFilters Cold air intake -Victory4x4 bed mount Molle -Katzkin Graphite leather -ESPtruck plastic CrewMax storage compartment -ScreenProtech interior screen guards -Tufskin raised 3D Solar octane lettering -JamHandle door assist in orange -Unfocused Offroad Safety orange lighting bumpers
    Looking to pull the trigger here on Amp research steps. Should I spend more for the OBDii harness plug and play? It explains that it might take up to 90 minutes off the install time
  2. Mar 18, 2021 at 8:47 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have AMP steps and have them hardwired in my 2014.
    Just make sure your tap or posi-tap connections are good and you'll be fine.
    The OEM wires are very small, and it takes a little effort to make sure your connectors make contact......
    Note, if you have a double cab, measure yourself and decide what and if you want to cut them.
    I wish I would have measured mine, before cutting them to the instructions recommendation.
    If you have a crewmax, you won't cut them at all...
    Welcome to the forum...:thumbsup:
    86BB3E0F-7B35-440A-A7EB-73DE0AC53289_zps_052b7c82351916097889b54aec3badbbc4d76c49.jpg
    84B44710-EE14-4D9E-9EEA-4D48E094A565_zps_8117ed0c894a0afc7c5386aece6b18d215d6136f.jpg
    Cement20[OP] likes this.
  3. Mar 18, 2021 at 9:05 PM
    Cement20
    Landon
    SL,Ut
    Awesome. Thanks for the reply. I can’t imagine the connectors are bad at all on the truck. But great advice. Yours looks clean.
    1lowlife likes this.
  4. Mar 19, 2021 at 4:48 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Plug and play is the way to go unless you’re constantly plugging into the port.
    RTV the lights in place.
  5. Mar 19, 2021 at 7:13 AM
    Cement20
    Landon
    SL,Ut
    Rtv the lights in place?
  6. Mar 19, 2021 at 7:17 AM
    R0CKETMAN
    NGAMTNS
    mine came with 3m tape which quickly failed. A drop of clear RTV has held them in place for four years now.
    Cement20[QUOTED][OP] likes this.
  7. Mar 20, 2021 at 6:36 PM
    Cement20
    Landon
    SL,Ut
    I learned the plug and play is not compatible with the 2020?? Also it has the available override switch I can buy. But do I go with the STA1 or the STB1 option? I don’t know what those are.
  8. Mar 21, 2021 at 11:14 PM
    Cement20
    Landon
    SL,Ut
    Does anyone know the answer here for the STA1 or STB1 for a 2020 crewmax? I can’t find anything on the different options
