Amp research side step
Discussion in '2.5 Gen Tundras (2014-2021)' started by DEe'sBigWheelTundra, Mar 14, 2016.
  1. Mar 14, 2016 at 12:04 AM
    DEe'sBigWheelTundra
    DEe'sBigWheelTundra [OP] New Member
    2015 TOyota Tundra
    Window tint all all window including winshield 5k hid headlight high/low 5k hid foglight 5k Led exterior interior Amp research running board 2.5 space lift pro-comp 20x9 +1 fuel hostage 33x12.50x20 No rub..
    i got my 2015 toyota tundra sr5..
    Juat got my electronic side steps..
    Followed the direction amp supplyied.. Hooked it all up.. All door work besides driver door.. Someone help please , i cant find anything about the newer models. Here's whats going on.. I disconnect the blue wire on the Driver side. All other doors work fine. Reconnect it, driver side steps come down but when i close door it wont go back up, but if i disconnect it driver back door works fine. Door close go up, door open goes down. (Rear).. Please help thanks
  2. Mar 14, 2016 at 5:42 AM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I installed them on my '15, followed the instructions exactly, and didn't have any problems at all. It sounds like you have the correct trigger wire, else the steps wouldn't work at all with that door. But maybe there's something wrong with the control box? I would call Amp and explain the problem. I found them to be extremely helpful anytime I had contact with them.
  3. Mar 14, 2016 at 9:10 AM
    DEe'sBigWheelTundra
    2015 TOyota Tundra
    Thanks fellow buddy
  4. Mar 14, 2016 at 9:19 AM
    DEe'sBigWheelTundra
    2015 TOyota Tundra
    If u dont mind me asking which plug is it on the driverside? Any pictures would help thanks
  5. Mar 14, 2016 at 9:38 AM
    DEe'sBigWheelTundra
    2015 TOyota Tundra
    Baby blue wire. Got it working. Thanks
  6. Mar 14, 2016 at 12:54 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Are these the ones that are really low profile and thin looking that automatically flip out if a door is opened?
    Do you have to drill into the frame or does it use predrilled holes in the frame?
    I ordered my truck without steps but i am wanting some now.
  7. Mar 14, 2016 at 2:01 PM
    DEe'sBigWheelTundra
    2015 TOyota Tundra
    There are the automatic ones. Amp research power steps. Bolts right up to
    Factory holes.. Real easy to install one u understand the wires
  8. Mar 14, 2016 at 7:20 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
