AMP RESEARCH power-steps?
Discussion in 'General Tundra Discussion' started by geno0506, Nov 16, 2017.
  1. Feb 7, 2018 at 1:28 PM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Nope, you have the right part. The second picture is an optional splitter in case you have more than one item you need to plug into the OBD port.
    geno0506[OP] likes this.
  2. Feb 7, 2018 at 1:30 PM
    dsimonl
    dsimonl New Member
    two wires will come from the pnp wiring harness up through a grommet under the driver's floor. they splice onto the connector you have pictured that plugs into the obdii port. That is what triggers the steps to drop and retract.
    ChucklesToy and geno0506[OP] like this.
  3. Feb 7, 2018 at 1:42 PM
    geno0506
    geno0506 [OP] New Member
    Michael
    Awesome, thanks!
  4. Feb 7, 2018 at 1:43 PM
    geno0506
    Michael
    Thank you!
  5. Feb 7, 2018 at 2:23 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I had the PNP version on my Silverado...just like the top picture...I added the harness in the bottom picture because I was always going to the dealer for "software calibrations" to fix issues and they were always unplugging my PNP to the PowerSteps...this harness allowed the PNP to stay plugged in while the service techs messed around with software updates...you won't have that headache (not many sw updates on the Tundy)! I have the hard wired version on my Tundy...
    geno0506[QUOTED][OP] likes this.
  6. Feb 7, 2018 at 2:37 PM
    geno0506
    Michael
    I may get that harness, when the dealer pulled out the harness each time, does it reset the AMP's or is it just a matter of unplugging and having to plug back in that you didnt like!
    Thanks
  7. Feb 7, 2018 at 2:46 PM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    Pulling the harness from the OBDII port will just keep your steps retracted. The AMPs only get door open signals from that OBDII plug.
  8. Feb 7, 2018 at 2:49 PM
    geno0506
    Michael
    cool, so it doesn't mess with anything when they unplug and plug each time, thanks
  9. Feb 7, 2018 at 2:51 PM
    LlamaResistance
    Concord, CA
    Nope, the steps are only looking for door ajar signals, I have the non-PnP and you tap into the door switch inputs for all the doors on install. I went that way as I don't like blocking my OBD port.
  10. Feb 7, 2018 at 2:59 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    You don't need the extra harness...In two years of owning my Tundy, I've only had one update (for the IBC)...in two years of owning my Silvy, I had 7 updates and counting...:)
  11. Feb 7, 2018 at 3:36 PM
    geno0506
    Michael
    Thanks Brian!
  12. Feb 7, 2018 at 3:38 PM
    geno0506
    Michael
    Thanks Chuck, eI'll not get that extra harness as long as all they have to do is unplug and update then plug back in! I just didn't know if it would hamper the service people at Toyota when going to update!
    :cheers:
  13. Feb 7, 2018 at 4:22 PM
    BamaGuyinTX
    BamaGuyinTX New Member
    2018 Silver Tundra SR5
    Do these play nice with the 2018s?
  14. Feb 7, 2018 at 5:06 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    The above reference to SVC leads to Best Top brand power boards. Are these the same as the AMP steps? They appear to have some kind of wireless interface that triggers the steps.
  15. Feb 7, 2018 at 5:40 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    The Bestop power steps use a wireless sending unit on each door to trigger the steps as I recall. As with many wireless units, they require batteries - not sure how often. The PNP is fairly new to the Tundra, but in 2014 I had the PNP on my Silverado. Unfortunately, the Silverado had some compatibility issues with anything connected to the OBD port, so every once in a while, the steps would not deploy. Also, it had to receive many software updates and the dealer service people left them unplugged several times - it did NOT cause any issues, but it was an inconvenience to them (and me when left unplugged). So I bought the additional harness - still had errors periodically, but saved me the service hassle.
    When I bought the AMP PowerSteps for my Tundra, the PNP was not available yet or I would have considered them. My comment regarding service was meant to be sarcastic since the Silverado required a lot more service than my Tundra has for the same ownership period.
    Another point: I researched various power steps in 2014 - I found that the Bestop steps' warranty was much shorter than AMP PowerSteps and there were many references to bad blood between AMP and Bestop.
  16. Feb 7, 2018 at 11:12 PM
    geno0506
    Michael
    They have been installed in the 18's, email AMP and they will verify!
  17. Feb 7, 2018 at 11:13 PM
    geno0506
    Michael
    Yep, 5 year warranty on the AMP's is a good thing!
  18. Feb 8, 2018 at 6:49 AM
    dsimonl
    dsimonl New Member
    My PNP have been installed since Nov '16. NEVER once had a malfunction. They work every time whether 2' of snow, sand , rain, etc.
    geno0506[OP], ChucklesToy and ldale like this.
  19. Feb 8, 2018 at 7:39 AM
    #49
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    That's awesome and good to hear. I think the issues I had with Silverado PNP were because the buss had general issues.
  20. Feb 8, 2018 at 8:11 AM
    #50
    geno0506
    Michael
    Awesome
  21. May 4, 2018 at 1:23 PM
    #51
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    When I called AMP they said the PNP will not work with th 2018 and they did not have and estimated date on when they may. They do offer the AMP extreme power steps now for 2018 but not PNP either. Trying to get some on mine but can't decide if won't to wait for the PNP or just go ahead and get them wired
  22. May 4, 2018 at 1:35 PM
    #52
    geno0506
    Michael
    I bought the PNP for my 2017 and glad I did, it was so easy! If I had a 2018, I would defiantly wait for the PNP being I'm no expert and liked the fact the PNP was so simple! Good Luck!
  23. May 17, 2018 at 10:28 AM
    #53
    don3032
    don3032 New Member
    don
    finally ordered my steps last night, amp step but went with bestop bed step for rear, seems like some people having issues with the mounting position of the amp bedstep hitting bumpers
