AMP research power running boards?
Discussion in '3rd Gen Tundras (2022+)' started by Big Sexy, Dec 27, 2023.
  1. Apr 15, 2025 at 3:42 PM
    #211
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Sorry, day late on the reply.., got there and they ordered in the XL (longer drop), instead of the Xtreme (dual motor), but re-ordered and have me in for Thu morning. They did say all would fit, and not sure why R/T doesn't show on their website, but we will find out mid afternoon on Thu I guess.... Will jump back in on Friday, and let you know. Apparently, the normal ones are on back order as well.
    Stay well.
  2. Apr 15, 2025 at 5:08 PM
    #212
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    So this is interesting.., Extreme Terrain shows the Xtreme's fit the Hybrid, but only the 22 & 23...
    A) I wonder if that is correct
    B) If so, wonder why
  3. Apr 16, 2025 at 7:09 AM
    #213
    PDXrefurb
    PDXrefurb New Member
    25 Blueprint Platinum Hybrid TRD OR
    3" TRD lift kit
    This is the result I get on Real Truck and what prompted me to call them and AMP tech support. Real truck told me the only model compatible with the hybrid currently is the single motor 76338-01A. I didn't specifically ask about the XLs. I believe I spoke to extreme terrain as well who told me the extremes will work.. but I trust amp and real truck more
    I'm 6' 4" and I actually don't like how far just the regular AMP step drops, even with my legs I have to scoot across the seat and reach for the step when stepping out. The step sits a little behind the rocker panel so I have to step out and back. I also have to scoot across the bolster a little when stepping in because of the length of drop. I had the OEM power step on my last platinum and they were perfect drop, prob a couple inches higher than these, no searching for the step and could step in without touching my seat. The OEM also had a much better board angle with my heels pointing at the sky when stepping in where as these sit flat slight angle to heel down when stepping in(even though they aren't supposed to) on Driver side, and all the way slanted out on my passenger side to the point it feels like you will slip off if it's wet. AMP is now sending me a replacement rear linkage for my rear passenger side under warranty because the step angle is so bad.
    I'm not sure I would be having these issues if I would have been able to install the dual motor extremes like I originally wanted
    cartage1[QUOTED] likes this.
  4. Apr 16, 2025 at 2:55 PM
    #214
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Would be good if Toyota had the option to install them as OEM equipment... Wife's Sequoia has them from the factory and they are great. Would have been happy to buy them from the dealer and use that factory switch and set up.
  5. Apr 17, 2025 at 6:35 PM
    #215
    jvilla
    jvilla New Member
    2025 Black Tundra Plat Hybrid TRD OR
    Would love to hear back see if they work. I was trying to order on real truck and they said no go. And told me to go with rhino... Even considered the regular one and they said 4-6 weeks backorder.
  6. Apr 18, 2025 at 6:36 AM
    #216
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Well, not great news. Total Offroad/4WP swears they will fit, but of course ordered the wrong ones again. After three misses, cancelled the order, and will search around for something else. Wish I could report either way, but after multiple misfires, had to pull the plug. I will keep searching, and if anything comes up (favorable or not) will provide details.
  7. Apr 18, 2025 at 6:37 AM
    #217
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Plus, now, the backorder makes me worry about price fluctuations. No political commentary at all, just a fluid international shipping environment at the moment...
  8. Apr 19, 2025 at 5:12 AM
    #218
    jvilla
    jvilla New Member
    thanks for reporting. might go with the go rhino or wait for the regular amp running boards. can't decide....
  9. Apr 19, 2025 at 6:26 AM
    #219
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    I did find another shop a little further away that installs a ton of these. Guys knows his stuff, was talking about each pin, each specific wire, what their purpose is, ,etc..
    He is going to call AMP on Monday (closed on Good Friday) on talk to his contact in Engineering. Waiting for a call back on Monday.., and will report back once again.
  10. May 2, 2025 at 5:44 PM
    #220
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Update that my "new guy" is confident we should not install the Xtreme's on the hybrid. Ordered the standard, and will get in line because of a back order. Saga continues.
  11. May 2, 2025 at 6:13 PM
    #221
    jvilla
    jvilla New Member
    I just installed the amp vision version since no backorder. And they work with the hybrid motor.
    BlackNBlu and cartage1 like this.
  12. May 2, 2025 at 8:23 PM
    #222
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Tru Amazon, I did with success
  13. May 3, 2025 at 5:55 AM
    #223
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    @23 Platinum - you were able to install the Xtreme's on a Hybrid? Sorry, didn't fully understand the comment. Thanks in advance.
  14. May 3, 2025 at 5:58 AM
    #224
    23 Platinum
    California
    No, I misread that. I do not have the hybrid. Oops
  15. May 3, 2025 at 10:40 AM
    #225
    D_Money
    D_Money New Member
    23 Pro MGM
    Nice to see actual pictures of these…can you turn off the lights while driving? Do they stay on by default? Thanks!
    cartage1 likes this.
  16. May 4, 2025 at 11:00 AM
    #226
    jvilla
    jvilla New Member
    yes you can have it turn on while deployed and turn off while retracted. or set them to stay on however long you want through the app. there is an approach option but i haven't gotten that working yet.
  17. May 6, 2025 at 11:55 AM
    #227
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    These are sick! Is the color adjustable? I missed which amp product this is exactly. Would love to research and add my own but I haven't found the right product yet. This just might be it.
  18. May 12, 2025 at 5:56 AM
    #228
    jvilla
    jvilla New Member
    Its the Amp Research "VISION" power running boards.
    ghunter321 likes this.
  19. May 12, 2025 at 4:38 PM
    #229
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Just to close the loop., did not go with the Xtreme or XL, but stuck with the original. Installed and very happy with the upgrade. Still wish Toyota would offer and install at a dealer (really would like the same factory switch set up as OEM), but a very nice upgrade nonetheless. Will keep looking to see if/when the Xtreme's are confirmed to fit.
  20. May 12, 2025 at 4:48 PM
    #230
    raylo
    raylo not so new member
    Frederick, MD
    The problem with fixed boards... and GoRhino elecrtic boards... is that they sit too high, as in just a few inches below the cab floor. So for taller people they make getting into the truck difficult because when standing on the boards your butt will be up near the roof making it a contortion to get down into the seat. The Amps drop low enough to make the ergonomics work much better. You stand on the board and just slide right over and in.
  21. May 12, 2025 at 4:51 PM
    #231
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    We just traded a 24 Limited for a 25 TRD lifted Platinum with the AMP boards, the are pretty bad ass IMG_9394.jpg
    cartage1 and Tundrastruck91 like this.
  22. May 14, 2025 at 8:02 AM
    #232
    jvilla
    jvilla New Member
    how big is your gap between the running boards and bottom of the truck trim when it's retracted? mines like 1/2" to 3/4" inch and i'm thinking is too big of a gap.
  23. May 14, 2025 at 8:13 AM
    #233
    SC SR5
    SC SR5 New Member
    I’ll measure when I get back to truck
