amp not powering on
Discussion in 'Audio & Video' started by smslavin, May 13, 2018.
  1. May 13, 2018 at 11:00 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    came outside to try the TuN software a bit more and discovered the amp no longer powers on. it was just working last night. on the multimeter, battery cable reads about 12.5. remote wire reads the same and it is coming from the remote out on the FiX. no lights on the amp. FiX and TwK are both powering on. inline fuse on the amp cable is intact.
    looking for a few ideas on what to check.
  2. May 13, 2018 at 11:54 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Other two choices are ground wire and amp fuses.
    Sunnier and smslavin[OP] like this.
  3. May 13, 2018 at 11:57 AM
    smslavin
    Hudson Valley
    Some stuff
    yea, it was the ground. found a new spot. sanded it way down. amp fired right back up. not sure what had changed between yesterday and today. had me freaking out a bit.
    T-Rex266 and Sunnier like this.
