AMP Bedstep
Discussion in '2.5 Gen Tundras (2014-2021)' started by Firefly412, Jun 7, 2019.
  1. Jun 7, 2019 at 4:12 PM
    Firefly412
    Firefly412 [OP] New Member
    Robert
    2018 SR5 Double Cab
    5306DB05-8854-44EF-8EC5-D004E18563C3.jpg Just installed the AMP Bedstep in my 2018 SR5. After weighing all the options and the great posts here, I elected to cut the factory bracket. After completion, I’m glad I did, as opposed to using the replacement bracket as suggested by a call to an AMP Installer and the instructions.
    I initially drew out the cut lines with a “French curve of sorts”, used a jig saw with a metal blade for initial cuts, then used an air sander/grinder to smooth everything out. Repainted the cuts and then installed.
    Nice piece of hardware.
    CementGen3, 2chains and RitcheyRch like this.
  2. Jun 7, 2019 at 4:39 PM
    2chains
    2chains New Member
    Southern Ablerta
    Looks great, how far above the ground does the step extend? Right now I use a milk crate and wouldn't mind checking them out.
  3. Jun 7, 2019 at 5:56 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    It's roughly 14" to the top of the step on mine, and 7ish from the bottom of the bumper to the top of the step. I'm not sure if my stock height is different than yours though. I do enjoy the step when my 4 wheeler is in the back with the tail gate down.
    2chains[QUOTED] likes this.
  4. Jun 7, 2019 at 5:58 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Looks nice. We’re any mods required to install this?
  5. Jun 7, 2019 at 6:03 PM
    Army_of_One
    OEM+
    He chose to cut the bracket. Amp Research provides one, but it doesn't seem quite as strong. Getting that bracket out was quite a pain.
    AZTundra and Fishman57[QUOTED] like this.
  6. Jun 8, 2019 at 7:52 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Did you have to cut the brackets in order to get it to come out that way?
    On my '16 it's mounted to the side versus most I see are mounted your way. AMP told me it was the only way to mount it.
  7. Jun 8, 2019 at 1:25 PM
    Firefly412
    Robert
    2018 SR5 Double Cab
  8. Jun 8, 2019 at 6:34 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I didn't know the had a side step like that. I don't the same as you, cutting the factory bracket. I left it in the old truck knowing I could just cut the factory one. Much easier. I put my step on the farthest in spot. It's a little harder to get it out but hides it better in the up position.
  9. Jun 8, 2019 at 6:40 PM
    AZTundra
    Paul
    Phoenix, AZ
    I was sold that same model and returned it after I installed it because it doesn't sit flush and follow the body lines. Apparently there are 2 different part numbers. The other one fits much better.
  10. Jun 9, 2019 at 12:59 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    you dont need to remove the bracket to cut it, you can use an angle grinder and just lop the thing off. (if you're a savage like me)
    also if you have the one that doesnt follow the bumper lines, you can make it line up with some shims.
  11. Jun 9, 2019 at 1:07 PM
    htw_hawaii
    htw_hawaii Tundra N00b
    Victor
    Hawaii
    2018 Cement CM 4x4 TRD
    Offtopic, but why do you have a strikethrough through your username? I've seen others with the same and have been meaning to ask. Thanks
  12. Jun 9, 2019 at 4:26 PM
    Fishman57
    Wayne
    Bucks County, PA
    It’s paying tribute to LEOs. If you want it, PM one of the mods.
    JeffC995 and htw_hawaii[QUOTED] like this.
  13. Jun 9, 2019 at 4:44 PM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Great install Firefly412. I really like how you cut the stock bracket instead of using the one supplied by AMP. I installed mine about a month ago and it's may be the best upgrade I've done to my 2019 Tundra Limited Off Road. Wish I'd thought to cut the stock bracket instead of removing it and replacing it with the AMP bracket; it was a difficult install (made worse when I rounded off one of the bolt heads under the plastic on top of the bumper) turning a 1-hour easy job into a half-day of frustration.
    The AMP Research Bed Step (which is the same as the one you can get from Toyota) is a great addition to any Tundra, and I'd recommend anyone installing one look closely at cutting the original bumper bracket like the OP instead of trying to remove it to replace it with the one supplied by AMP.
  14. Jun 9, 2019 at 9:51 PM
    htw_hawaii
    Victor
    Hawaii
    Thanks for the info
    Fishman57[QUOTED] likes this.
  15. Jun 9, 2019 at 10:35 PM
    Need one of these
  16. Jun 9, 2019 at 11:56 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Damn man that’s a really clean install. I wish I had cut the stupid bracket. Those GD plastic clips everywhere are a nightmare.
    OR18TRD likes this.
  17. Jun 10, 2019 at 4:07 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    SOB. No it doesn't sit flush and I didn't realize there was another model. They told it was only available on 2013's or older. It doesn't look aesthetically pleasing from the back. Now I may have to spend money again. :annoyed:
  18. Jun 10, 2019 at 6:52 AM
    AZTundra
    Paul
    Phoenix, AZ
    Are you not able to take that one off and return it?...I posted my troubles with the install a while back (stock bracket would not come out). After the install the step didn't seem right at all compared to the one I had on my prior vehicle (Ram 2500). I went back to the shop where I bought the step and they swapped it with the other model. Apparently their computer shows 2 models - One is for trucks that have a resin bracket from the factory and the other is for trucks with a metal bracket. I forget which is which, but let me see if I can find my post with all the details for you.
  19. Jun 10, 2019 at 7:01 AM
    AZTundra
    Paul
    Phoenix, AZ
  20. Jun 10, 2019 at 10:44 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    Unfortunately no as it's coming up on two years since I put it on.
  21. Jun 10, 2019 at 10:48 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    Yes, that's exactly what happened to me. Mine even the bumper. I ended up buying a piece from Home Depot that has a nail at the end and then a little foam piece on the other and nailed the nail into the stopper piece that comes in the step so that it stops earlier and doesn't hit the truck. From the side it looks like it still hits it but if you get down low enough it barely clears it.
    Looks somewhat silly from the back though. I may swap out to the correct one and try to sell the other one.
  22. Jun 10, 2019 at 11:21 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Do you have a pic. Thats what is keeping me from grabbing one of these, I don't like the way they poke out when they are in the up position.
  23. Jun 10, 2019 at 1:01 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Mine doesn't "poke out" at all. It's lined up well with the underside of the bumper and tucked in quite tightly to the underside of the truck. When looking at the truck overall, most would never even notice it's there.
    Heck, if you want a real thrill, try installing the folding side steps (BedStep2) just behind the truck cab. AMP wants you to remove a bolt securing the bed, insert a metal plate over that, and then reinstall the bolt through the back area of that plate - all with less than an inch or two of clearance. Had to buy an wrench extension to get that tough bolt off and then couldn't get my fingers in there, over the plate, enough to put the bolt back on. After hours of unsuccessful fighting, I finally decided this was a job for someone else. The dealer's service department ultimately got it done, but it took two guys almost twice as long as they originally estimated. When I talked to them afterwards, they (shaking their heads, etc) were almost as shell-shocked as I was. We all had scratched up knuckles and similar.
  24. Jun 10, 2019 at 3:59 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    You can see in the last picture what's circled. On my old truck I had the step toward the outside. There's about 1-1/8" to 1-1/4" difference between in and out. Hope this is what you was looking for.
    Tundra Fan[QUOTED] likes this.
  25. Jun 10, 2019 at 4:41 PM
    AZTundra
    Paul
    Phoenix, AZ
    Here are the slots used per the manual (for reference). Good idea! Wonder if moving it lowers the weight capacity any?
    splitfuse likes this.
  26. Jun 10, 2019 at 4:48 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    It shouldn't lower the weight capacity. If anything I think it would raise it because you're not stepping away from the center as far. When I put it on the new truck , I tried it and it didn't hit so I left it. But like I said it's slightly harder to get your foot on it but I like it better this way.
    AZTundra likes this.
  27. Jun 10, 2019 at 4:51 PM
    AZTundra
    Paul
    Phoenix, AZ
    Agree, it does look cleaner that way.
  28. Jun 10, 2019 at 4:53 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I put one on my old double cab. IMO, it's useless unless you're bed cover is open or you have a tool box. It's so far under the buldged bed side, you can't stand on it unless you have something to grab on to.
  29. Jun 10, 2019 at 5:40 PM
    handyman
    handyman New Member
    I'm shortening my hard tonneau cover to allow for a black aluminum gull-wing toolbox. The bed under the tonneau cover will be used for my fishing gear, small generator, and similar. This is all in preparation of hitting the road with a travel trailer. The wife will tow our inflatable boat between locations, with those locations used as a base for nearby travels.
  30. Aug 23, 2019 at 8:17 AM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    So after searching the post and the Internet you’re saying that this model that’s for the 2014 and 2015 fits better than the one that’s designed for the 2017 and up models correct? But the only catch is that I have to modify the bracket right? I have a 2018
