American Racing Headers
Discussion in 'Performance and Tuning' started by texasrho83, May 19, 2019.
  1. May 19, 2019 at 8:51 PM
    texasrho83
    texasrho83 [OP] DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Rex Kramer likes this.
  2. May 19, 2019 at 9:34 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    I’m down to help;)
    You’ve already taken my first suggestion about the 12mm
    You sure you want something with an H pipe? An X pipe scavenges better, has better low end torque, and sounds better.
    If you’re already committed all good:)
    How loud are you lookin to be? And how much drone can you tolerate?
    SilvenZer02, Rex Kramer, Sas and 4 others like this.
  3. May 19, 2019 at 9:35 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    jack up the truck and take the wheels off
    disconnect and remove any wires / brackets from the shock towers to get room
    unclip the fuel lines from their brackets as well on the drivers side
    if you could take the upper control arms off as well, that would help getting to the head studs
    get every length 12mm wrench and socket you can find as well as multiple swivels and extensions
    I had to remove the starter shield to slide the passenger side header into place, but didn't have to hammer the firewall like others have
    texasrho83[OP] and Rica25 like this.
  4. May 23, 2019 at 11:26 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    Just installed my ARH headers. Drivers side was a beast. you are definitely going to want a 12 mm ratcheting box wrench. The 2 lower/middle studs on the driver side are no fun to get to. I also had a time getting the driver side header in there that i did not experience with teh JBA. But these take up a slightly larger envelope and mine is 4x4. I kept getting hung up on the differential flange. You may need to twist/rotate that side as you go in so it can clear.
    texasrho83[OP] likes this.
  5. Jun 2, 2019 at 12:28 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    How does it sound? Is there any drone?
  6. Jun 25, 2019 at 4:20 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    5D4CDBB1-6137-4166-80CD-91AACF826868.jpg 5D9F17EA-846D-4E92-912C-F2C7FDF43299.jpg
    She’s in the hospital. About to go under the knife. Can’t wait to hear/see the results.
    GAknight, Matty4wd and Watt maker like this.
  7. Jun 26, 2019 at 6:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    CBE5FE46-FE9A-4409-99D9-BF407D91A9E4.jpg 9F026FCD-28DA-47B0-AC85-FC208E7D6DD8.jpg 487E2CA4-102C-4AC7-9742-A6684DA29F61.jpg
    Out with the old...
    GAknight and Watt maker like this.
  8. Jun 27, 2019 at 4:52 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    Save those cats man! I got some serious cash for mine
  9. Jun 27, 2019 at 5:05 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    From a junk yard?
  10. Jun 27, 2019 at 5:30 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    I second this questiom
  11. Jun 27, 2019 at 6:56 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I already asked a guy what I could get for em and he told me $30 each. I told him :rofl:
  12. Jun 27, 2019 at 8:03 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Wouldn't long tubes, followed by a 2 into 1 y-pipe, followed by a single performance muffler, followed by a tail-pipe using all mandrel bent pipe no larger than 3" make the most power?
  13. Jun 27, 2019 at 8:15 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    mid pipes are unequal length so you need an x pipe to balance out the pulses
    GAknight likes this.
  14. Jun 27, 2019 at 8:21 AM
    Rex Kramer
    Georgia
    Unequal length mid-pipes is okay - won't hurt a thing, and the 2 to 1 Y pipe blends & balances the exhaust pulses.
  15. Jun 27, 2019 at 8:22 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I've heard different from other people, but I don't build exhausts so what do I know haha
  16. Jun 27, 2019 at 9:47 AM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I got $65 a piece from mine from an metal recycling place.
  17. Jun 27, 2019 at 5:53 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I got $70 for the two front cats from my Tacoma. You have to find a catalytic converter recycler. Usually they are the same places that do metal recycling.
    Search online to find local recyclers.
    $40 sounds like a non-recycler middleman may have taken a little off the top.
  18. Jun 27, 2019 at 6:15 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    63579CE3-EC0D-4F75-84A9-68FA989B7FD1.jpg 04C2FE12-3DB2-4820-9B17-6D09F927AC89.jpg 5FB103A4-0456-473E-BB80-652CDE1FDC16.jpg 14AA02EB-DEEC-4005-BCD1-922F90011AD2.jpg 1ADB6358-031C-4AFC-A396-8694BC7F78DE.jpg 09334F99-4347-4AE0-8143-3625A690073A.jpg 3D87DC28-1B87-4F97-B79F-42670729D762.jpg CBE872B2-CACF-4887-9E6D-1267371D3EA9.jpg
    They’re in. Probably gonna pull the clamps and weld it all together.
  19. Jun 28, 2019 at 3:58 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    How do you like it?
    Performance? Sound? Quality? Value? Was it worth it.
  20. Jun 28, 2019 at 4:16 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Those headers are very pretty! I'm really trying hard to find some HP numbers on them. Why is this such a secret??? Its a lot of money to spend on a performance part when the performance numbers are not known...
  21. Jun 28, 2019 at 5:28 AM
    Rex Kramer
    Georgia
    Agreed. I would like to see before and after Dyno tests on a stock truck.
    osidepunker[QUOTED] likes this.
  22. Jun 28, 2019 at 1:37 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Did you see the dyno charts I posted?
  23. Jun 29, 2019 at 7:44 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    088B23C1-A488-45C2-BE69-74F51A50E1BF.jpg 613DF333-229D-4B4B-A1C0-3173CF8082FB.jpg F58EE70D-1B51-40AB-AD44-A0830C45704F.jpg D4B35C34-E048-446F-AF26-1ED22628508E.jpg DD230065-A1F4-421E-8457-8B921CF8BA3B.jpg
  24. Jun 29, 2019 at 7:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Love it. Best sound in the world. I tell people when you’re 20 any sound is good sound, but when you’re 40 not any sound is good sound. This is quality sound. It’s quiet in the cab, on the highway while cruising, but when you get on it you know it’s there and so does everyone else. Zero drone. Insane how there’s no drone. Quality is ultra high: the bends have no wrinkles, the welds are gorgeous, and the flange and header surfaces are milled perfectly. Completely worth it imo. Again, many don’t think any exhaust is worth this much but you get what you pay for.
    Toyotoholic likes this.
  25. Jun 29, 2019 at 7:58 AM
    Rex Kramer
    Georgia
    If I am reading this correctly, the biggest gain for your money is the low cost DAP tune.
    osidepunker likes this.
  26. Jun 29, 2019 at 8:15 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Can’t argue with that.
  27. Jun 30, 2019 at 2:45 PM
    swank501
    swank501 New Member
    2007 single cab 4x4
    Circling back to the scrap question, I got $90/cat from a local buyer here in houston. So yeah, theres potentially $360 scrap value waiting at the end of this install.
  28. Jun 30, 2019 at 3:42 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dude, tell me where!?
  29. Jun 30, 2019 at 4:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Any vids/ sound clips.
    Super interested in these headers... Been eye'n these for several months.
    I'm curious how this set up would compare with the OV tune to the DAP tune?
  30. Jun 30, 2019 at 5:20 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here’s one from another guy who has the same setup. His GoPro is way better than what I’ve got. I took some audio but it wasn’t good so I’ll try again.
    GAknight[QUOTED] likes this.
