Amber light
Discussion in 'Lighting' started by TXRailRoadBandit73, Oct 21, 2016.
  1. Oct 21, 2016 at 8:55 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    I had a 13 CM SR5 it had that real dim amber courtesy light bottom of rear view mirror now I have a 14 CM SR5 no light this on higher trims?
  2. Oct 21, 2016 at 9:14 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I believe these were only available on higher trims. My Platinum has it.
  3. Oct 21, 2016 at 10:36 PM
    Can't we jus get the rear view mirror that has in plug in
  4. Oct 22, 2016 at 9:46 PM
    Can I order one with light n will it work with one I have?
  5. Oct 22, 2016 at 9:55 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Depends if your truck is pre-wired for it. I don't know if it is or not. If it is not , you will need to run wires and tap into your interior lights.
