Am I the only one having trouble connecting my homelink to my Tundra
Discussion in 'General Tundra Discussion' started by bodontno2, Aug 27, 2017.
  1. Aug 27, 2017 at 9:09 PM
    bodontno2
    bodontno2 [OP] New Member
    Bo
    2017 Tundra SR5
    I recently purchased a 2017 Tundra SR5 and have tried everything that the truck manual the genie manual and still cannot get my homelink on the mirrors of the truck to operate my garage door opener.
  2. Aug 27, 2017 at 9:13 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    My 2015 is the same with oddly enough a genie as well. Tried everything then said the hell with it.
    sleddogg6 likes this.
  3. Aug 27, 2017 at 9:19 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Something to keep in kind, garage openers only have a couple slots available for remotes. If those slots are full, then there is nothing you can do, short of deleting all of them and reprogramming the ones you actually use. May not be an issue with your truck or your process, your garage door opener may just be "full".
  4. Aug 27, 2017 at 9:46 PM
    multimile
    multimile New Member
    2020 Crewmax Cement
    I was originally trying to set mine up with an aftermarket, non-genie, remote. For the life of me, I couldn’t get it to work. I started everything over with an OEM Genie remote and it worked on the first try. Give it a shot with a different remote, if you haven’t yet.
  5. Aug 28, 2017 at 3:13 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had to use the rolling code method and press the button 3 times. Pushing twice did not work. Tacoma was same.
    G-man likes this.
  6. Aug 28, 2017 at 5:11 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    My problem with home link is I can open my garage door with the key out of the ignition. Does me no good as I park the truck in the driveway. Called Home link and they say there is nothing that can be done. I know in one omg previous Tacoma's I was only able to use it with the ignition on.
    T-Rex266 likes this.
  7. Aug 28, 2017 at 6:02 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    yeah, when I tried to setup this up on my tundra, I found that the manual was missing a step. I used this video to get it setup:
    https://www.youtube.com/watch?v=mvoKBm7h3aY
    the missing step was to set the garage door opener on learn mode to accept the signal from the tundra.
    good luck.
    14txtss likes this.
  8. Aug 28, 2017 at 7:04 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I also had to set my garage door openers into learn mode because they are the "rolling code" type. If I recall, you still have to point the remote to the homelink and follow that procedure, then press the learn button on the garage door opener, then go back to the homelink buttons. It's a bit of a pain.
  9. Aug 28, 2017 at 10:10 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    The steps for a rolling code opener are in the manual. With this method you do not use the remote for the door. The bad part is, unless you have a helper, is you have to push the learn button on the opener. Typically after you do you have 30 seconds to get in to the truck and push the Homelink button and hold 2 seconds 2 or 3 times. My opener requires 3 times. I do not mind the Homelink being active without the key in. If I had a remote in the truck it would not have to have the key in to work. I park my truck in the driveway. If I want to feel more secure I can lock the truck doors.
  10. Aug 28, 2017 at 11:11 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    You realize that if you set this up and somebody steals your truck they now have access to your house....
  11. Aug 28, 2017 at 2:53 PM
    Netmonkey
    Georgetown, TX
    Most people keep the garage door remote in their vehicles too. I don't know anyone who brings the remote into their house or keeps it on their person. we have these features for convenience and I suppose that is the risk you take. Maybe if they had Bluetooth garage door openers, then we could use our phones to open the garage door. The homelink feature is no less secure than leaving the remote in the vehicle. If someone does steal the vehicle, you can always clear the opener or change the code.
    P-Factor and TundraTss[QUOTED] like this.
  12. Aug 28, 2017 at 3:12 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I think it would be time to throw the vacation switch on the wall switch.
  13. Aug 29, 2017 at 6:02 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I use my phone to open my garage over wifi. I have an app that allows me to see if and when the garage door was opened. The brand is a Chamberlain.
    PermaFrostTRD likes this.
  14. Aug 29, 2017 at 6:07 PM
    jstchilln
    jstchilln New Member
    Larry
    Eastern Kansas
    2017 Tundra 4X4 SR5 Double Cab / TRD Off road Package
    TRD Pro Grille
    Had Homelink problems with our 2017 Subaru Outback and the 2017 tundra on a year old garage door opener. Both vehicles were a major pain in the ass and I cannot tell you exactly what I did because I followed the instruction and tried several other things and I dont have a damn clue which one did the trick. I love having it on the mirror and both vehicles work after they are turned off.
  15. Aug 29, 2017 at 6:22 PM
    Netmonkey
    Georgetown, TX
    Ooh. Sweet :)
  16. Sep 3, 2017 at 5:11 PM
    birdman076
    Chuck
    Montana
    Revisited this and tried the video method to the T thinking I may have missed something and on the 3rd time it worked. Not sure why as I did everything the same each time, not going to look a gift horse in the mouth though, we'll see how long it lasts.
  17. Sep 4, 2017 at 12:19 PM
    Baconator
    Baconator New Member
    Keith
    2016 White Crewmax 5.7l SR5
    Has anyone ever figured out a mod to only power the homelink when the key is on/acc?
  18. Aug 23, 2019 at 2:59 PM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    Excellent tutorial yours was the only one that worked for me, thanks.
  19. Aug 23, 2019 at 3:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I use a key chain remote, so it’s with me all the time.
    I never set those home link to any of my vehicles.
    You left you car in driveway and people just open your door and open the garage.
    You might as well leave your key on you door...
  20. Aug 23, 2019 at 3:34 PM
    P-Factor
    P-Factor New Member
    I had the same issue programing and after a lot of time and aggravation I found out that my garage opener was too old to support newer version of Homelink and I had to replace my openers.
  21. Dec 17, 2019 at 5:50 AM
    14txtss
    14txtss New Member
    Ron
    Houston
    2017 attitude black platinum 5.7 4x4
    This worked for my 2017 tundra, genie pro opener
    Thanks a bunch!
    Bigjoe20 and Netmonkey[QUOTED] like this.
  22. Aug 10, 2020 at 3:34 AM
    Bigjoe20
    Bigjoe20 New Member
    Thank you for posting
  23. Aug 10, 2020 at 4:22 AM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    As an add on for future problems, I recently found that LED bulbs have interference with the remote signals on the Genie Belt drive units. Some put out a frequency that interferes with the signal reception from the head unit on the opener. I had to change the LED bulbs on the opener to "Low Interference LED" bulbs in order for the homelink to work consistently. The remotes always worked, just the homelink was limited. The Homelink worked intermittently, and was driving me nuts.
  24. Aug 10, 2020 at 7:09 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have a problem with mine too. When I use the wall mounted opener to open the door when I leave in the morning or any time if I don't pull out right away when I get out of the garage and hit the homelink to close it it will not close and I have to get out of the truck to close it on the keypad mounted on the outside of the garage. Anyone else with this problem ?
  25. Aug 10, 2020 at 3:39 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    I haven't tried linking mine yet nor will I ever. The truck stays on the driveway so I don't want anyone breaking in the car and have access to my garage. I have thousands of dollars worth of tools in there. What I do is I have MyQ so I just use the app to open the garage. Also the LED is true, it does interfere with the opener. I even heard some people are having problems using their truck remote from opening or locking due to them putting LED bulbs on the bed/3rd brake light .
  26. Aug 10, 2020 at 3:52 PM
    jclaffee
    jclaffee New Member
    Durango, CO
    This. But first make sure you follow the instructions for how to clear the Homelink in the truck before you try to connect to your opener.
    Edit: I found the instructions...To clear the Homelink settings in the truck, hold down the two outside buttons (i.e. #1 and #3) simultaneously for 20-30 seconds until the indicator light flashes.
  27. Aug 10, 2020 at 4:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This method to clear the Homelink is common for all vehicles. Hold the two outside buttons until the indicator flashes.
  28. Aug 10, 2020 at 4:21 PM
    jclaffee
    jclaffee New Member
    Durango, CO
    edit: never mind, I re-read your post.
