Alternator acting strange....
Discussion in '2nd Gen Tundras (2007-2013)' started by gihuff, Jun 14, 2018.
  1. Jun 14, 2018 at 7:14 PM
    gihuff
    gihuff [OP] New Member
    2008 Tundra
    2008
    4.7
    At startup.....volt meter on dash reads below center
    Voltage at battery (running) 12.5V
    after 45 seconds (checked this several times and is consistent)
    It sounds like a clutch kicks in and volt meter on dash goes to center
    and voltage at battery now at 13.8
    Now I know there is no clutch on the alternator right?
    Sounds just like a AC compressor clutch kicking in
  2. Jun 14, 2018 at 7:54 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    What accessories do you have running while you are performing this test? Simple way to find out would be to just have the charging system load tested. Oh, and welcome from CO!
    Black Wolf likes this.
  3. Jun 14, 2018 at 7:58 PM
    gihuff
    2008 Tundra
    Thanks for the welcome!
    Nothing on.....Just start and wait 45 seconds and you hear it kick in
  4. Jun 14, 2018 at 7:59 PM
    Exactly. Always test alternator under load conditions and monitor not the volts out but the current output.
  5. Jun 15, 2018 at 7:15 PM
    gihuff
    2008 Tundra
    I'll just replace it
  6. Jun 15, 2018 at 7:42 PM
    Vizsla
    Vizsla 2 = 2.5
    The air injection pump runs on start up for a bit, and has a noticeable electrical draw. Might be worth checking, can usually hear it running.
