Alternate part # for sunroof motor?
Discussion in '1st Gen Tundras (2000-2006)' started by pm07, Apr 9, 2021.
  1. Apr 9, 2021 at 7:23 AM
    pm07
    pm07 [OP] New Member
    Shane
    2006 Black Tundra
    SO I'm trying to get my sunroof closed all the way. Was going to replace the motor but everywhere I looked they are $500. Does anyone know of a replacement that doesn't cost an arm and a leg? The part # is 63260-0C010.
  2. Apr 9, 2021 at 7:35 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Someone just had this issue... On a newer model.. You can try the other sunroom/ moonroof motors off the Celica 03+ since they're for glass moonroofs much better/stronger motor, Camry, Prius at a salvage yard, you may have to go pull it yourself as some may charge you the same as stealership prices..
  3. Apr 9, 2021 at 8:27 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    You feel confident your motor is culprit ? If it attempts to close and goes back or simply is sluggish when it attempts, it may mean the rails/tracks simply need to be cleaned of all debris/old lubricant and relubricate. Just finished maintenance on mine that’s not used often. When I first started it was sluggish and would not close without backing up. Cleaned it all up and now it opens and closes like new !
    FrenchToasty likes this.
  4. Apr 9, 2021 at 11:28 AM
    pm07
    Shane
    2006 Black Tundra
    It wasnt sluggish, it stopped working. I had to close the glass by hand. The motor doesnt work at all when the buttons are presseed.
  5. Apr 9, 2021 at 11:49 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have you checked the 25amp moon roof fuse ? Just curious if you have done other testing and are simply looking for a cheaper motor. If so, I'll skip posting ways to test it and even rebuild it.
    pm07[QUOTED][OP] likes this.
  6. Apr 9, 2021 at 2:03 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'd love those tips for mine!
    pm07[OP] and BubbaW[QUOTED] like this.
  7. Apr 9, 2021 at 2:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Ask and you shall receive :)
    I want to remember yours was squeaking and won't go all the way back. How did your guides/rails look ?
    pm07[OP] likes this.
  8. Apr 9, 2021 at 3:13 PM
    pm07
    Shane
    2006 Black Tundra
    Bubba , Yes Sir. Everything else was checked. 99.91% sure its the motor.
    BubbaW[QUOTED] likes this.
  9. Apr 9, 2021 at 3:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Keep us up to date on how it goes. These folks also luv pics of what folks find.
  10. Apr 14, 2021 at 5:58 PM
    pm07
    Shane
    2006 Black Tundra
    Does anyone know is the sunroof motor for the 2001-2007 Sequia will work? I found some on Ebay that look the exact same as my tundra one.
  11. Apr 15, 2021 at 3:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
