Alpine Halo9 iLX-F309TND?
Discussion in 'Audio & Video' started by CJpe007, Mar 3, 2019.
  1. May 13, 2019 at 8:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have a kenwood so maybe its different. But I have a maestro RR in my 2015 platinum and I can see tire pressure and tire temperature on one of my screens. The only issue I have with the maestro gauges/ vehicle info is the fuel % doesnt work at all
    Beastmode1794 likes this.
  2. May 14, 2019 at 2:02 AM
    Dorf13
    Dorf13 New Member
    Installing mine Friday! Is it automatic dimming at night or does that have to be done manually?
  3. May 14, 2019 at 4:14 PM
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    It has a light sensor adjust to the ambient light.
    Dorf13[QUOTED] likes this.
  4. May 14, 2019 at 4:24 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    I agree. I'm loving mine. Dont pay 1400. I got mine for 800 and installed it myself. I have the control module, the camera module, and a bypass.
    plumber802, ntg, tAcomaPueblo and 2 others like this.
  5. May 14, 2019 at 4:26 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    How did you change the picture? I havent found an option on how to do that?
  6. May 14, 2019 at 6:00 PM
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    Plug you phone into hdmi it will go into DeX mode then set your background it's not for the regular menu screen
  7. May 15, 2019 at 9:08 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    Oh ok, right I knew about that part. That's why I put on the bypass, it kicks you out of Dex/HDMI when you start driving.
  8. May 15, 2019 at 9:17 AM
    Beastmode1794
    Yup gota have that bypass
  9. May 16, 2019 at 7:31 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I am going to wait till they come out with the 65" model.
  10. May 17, 2019 at 11:07 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
  11. May 18, 2019 at 4:44 AM
    Beastmode1794
    Looks good and I like the shift knob !!
  12. Jun 26, 2019 at 6:39 PM
    johnwe85
    johnwe85 New Member
    Looking at purchasing this hi for my truck. I have the column shifter. Can anyone tell me how far the front of the screen is from the dash? The tundra column shifter is so long I’m worried it won’t work in my truck.
  13. Jul 5, 2019 at 10:22 AM
    cprx7
    cprx7 New Member
    randy
    2019 Limited
    Hello everyone, first time poster here. I just picked up a 2019 Platinum Tundra and so far I love it and think its def an upgrade from my previous 2018 Ram Laramie.
    However, I'm not thrilled with the back up camera resolution and with the fact that it has no Carplay. I am looking into installing this Alpine headunit but would like to ask couple questions to those who have it :
    how is the backup camera resolution? does it track?
    is warranty voided when changing head unit?
    Thanks in advance
  14. Jul 5, 2019 at 7:42 PM
    Rubberdown
    There’s no way to make this control a couple slave monitors in the back in the headrest is there? Would like to be able to run the movie in the back for the kiddo.
  15. Jul 6, 2019 at 3:36 AM
    rawn027
    rawn027 New Member
    2019 Black Tundra Limited
    Backup cameras are 480p, this display is 480p. The backup camera resolution is not great. That being said, how often do you look at your backup camera?
    I believe our backup cameras have lines in them already, so you can either enable or disable the lines on the Alpine. I don't know if it has steering tracking.
    Warranty is not void when installing a head unit. Warranties on cars are handled differently. It is not a single thing.
    If you broke something because of the head unit install, they wont fix it for free. They also wont fix your after market head unit.
    But if your engine breaks you wont be out of luck.
    RoseKnight likes this.
  16. Jul 6, 2019 at 3:38 AM
    rawn027
    rawn027 New Member
  17. Jul 6, 2019 at 1:59 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    There are no turning guides... Those would be your side mirrors. The OEM camera has a grid in the video. Then you can overlay the Alpine to match or simply turn it off. I never depend on the rearview camera for anything except distance to a wall, and the radar warns me plenty about that too. I back into my driveway which is an "S" pattern with a slight downhill and large rocks flanking the bends... I use my side mirrors only. I honestly think the only reason to look at the backup camera is to see clearly what's directly behind you or in your blind spots... That's it! Check it, then use your mirrors. I don't think the resolution is great at all in the Alpine, but I am not disappointed because it serves it's purpose, you can see what is there.
  18. Jul 7, 2019 at 4:27 PM
    rawn027
    rawn027 New Member
    Exactly, and the resp
    This ^^^
    Toyotoholic[QUOTED] likes this.
  19. Jul 8, 2019 at 8:45 AM
    #49
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Turn lines on these backup cameras are just eye candy. If you were to use them exclusively to back into a spot, I am sure you would hit something. Totally useless feature that I would not base my purchase on.
    Toyotoholic likes this.
  20. Jul 9, 2019 at 12:32 PM
    #50
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    This is for the OEM or aftermarket cameras?
    I’m deciding between this alpine one, pioneer 8500 and the Tesla style. Don’t know which I want.
  21. Jul 9, 2019 at 12:43 PM
    #51
    rawn027
    rawn027 New Member
    Caution, My Opinion Only:
    1. I _highly_ recommend against the Tesla style because knobs to adjust air conditioning don't kill people. Touchscreens do.
    2. Also A knob is tactile, and fast. Digital buttons are not.
    3. Alpine has a big and great reputation, the tesla radios do not.
    4. I don't trust Android operating system security.
    I had a Pioneer NEX in the past, was not happy, had reliability and performance issues.
    The Alpine 207 is another cheaper alternative.
    Kenwood 906S is another choice.
    Kung, JAMES and ATHiker like this.
  22. Jul 9, 2019 at 1:08 PM
    #52
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    That's the only thing I miss from my OEM radio is the volume knob. The alpine has capacitive touch buttons....however steering wheel controls work perfect
  23. Jul 9, 2019 at 1:10 PM
    #53
    rawn027
    rawn027 New Member
    Yeah, losing the volume knob sucks. Learning the SWC is fine. Sony makes a CarPlay unit that has a knob, but its less-good IMHO.
  24. Jul 11, 2019 at 9:33 AM
    #54
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    I've got the 8500NEX and really like it. Haven't had a lot of time to learn all the in and outs of it.
    JTL likes this.
  25. Jul 11, 2019 at 6:44 PM
    #55
    rawn027
    rawn027 New Member
    Any ILX F309TND user here or did everyone just buy the F309? I want to know if the secondary display functions and displays song info, thanks!
  26. Jul 12, 2019 at 3:13 AM
    #56
    rawn027
    rawn027 New Member
    I had a long phone call with iDatalink Maestro support last night. The Alpine Perfect Fit units such as the F309TND have a modifier version of the Maestro firmware. It is locked out of having certain features changed. When I went to flash mine to disable factory amplifier (something James let me know about because otherwise fade wouldn't function) I saw that the secondary display functionality was disabled (and could not be enabled). Hence the question above.
    I am not super motivated to rip my dash apart and find out I dont have the functions I bought the unit for. It is kinda insane because Alpine's website specifically states secondary display.
    There is also no limitation of the F309, and on a vanilla Maestro, these features can be enabled and function just fine.
    I'll be calling Alpine today.
    For future readers: ILX-F309TND shipped with Maestro firmware v2.2, current available firmware was v2.6
    The ALP- prefix on the maestro hardware means you have a special Maestro unit that Alpine handles all the firmware builds etc. Maestro is not able to provide as good of tech support on these units because they are "locked".
    JAMES, Toyotoholic and Migraine like this.
  27. Jul 12, 2019 at 3:16 AM
    #57
    rawn027
    rawn027 New Member
    Did you buy the ILX-F309TND or just the ILX-F309. If you got the vanilla ILX-F309, which dash kit did you use, Metra or Scosche? It looks lined up perfectly, there are some images where that is not the case.
  28. Jul 14, 2019 at 1:22 PM
    #58
    cprx7
    cprx7 New Member
    randy
    2019 Limited
    Just had mine installed with Maestro MRR Idatalink and HRNRRT02 harness for the toyota tundra. Everything seems to work well and overall i'm happy with the unit. Def an upgrade not only in features but in sound quality as well.
    plumber802, ntg and TundraLaw like this.
  29. Jul 14, 2019 at 1:26 PM
    #59
    cprx7
    cprx7 New Member
    randy
    2019 Limited
    Was told TND means everything required for "diy" is included in the kit. The head unit is the same, idatalink cables included. The higher price is due to the dashboard piece which seems to be of better quality than the Metra brand. The Metra kit doesn't line up perfectly and does not quite match the color tone however, the difference is minor and it really doesn't bother me at all
  30. Jul 14, 2019 at 1:36 PM
    #60
    cprx7
    cprx7 New Member
    randy
    2019 Limited
    side angle
    rawn027 likes this.
