Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Jan 22, 2020 at 9:47 AM
    #121
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Here's a picture of the XBs mounted on from a couple other Fellow Forum members! Cmon now.... how can you beat that look? they could've released this as a new truck looking like this! :) Don't get me started with that Sequential Flow-Style Turn Signal... :drool:
  2. Jan 22, 2020 at 9:48 AM
    #122
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
  3. Jan 22, 2020 at 11:00 AM
    #123
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Are you saying the DRL wire to the ignition or the factory DRL that can be disconnected behind the dash with the gray wire? I have the gray wire disconnected and the startup sequence still works. Matter of fact, when my PKE unlocks the doors either by PKE or remote the light bar flashes as well. BTW, I stacked codes and they still sent me the right version ($281 shipped:). Also, the sequence is fast, so if you are starting the truck and running out there, you will be missing it. Have someone else look.
    focal[QUOTED] likes this.
  4. Jan 22, 2020 at 12:23 PM
    #124
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I meant the entire harness that comes with the headlights. I did not hook any of it up, just the bulbs
  5. Jan 22, 2020 at 12:23 PM
    #125
    Beau
    Beau
    Yes, that has to be hooked into the ignition fuse to make the sequence work.
  6. Jan 22, 2020 at 12:24 PM
    #126
    focal
    Nikolai
    VA / NC
    gotcha, thanks. I just heard back from alpharex and they said the same.
  7. Jan 22, 2020 at 1:39 PM
    #127
    focal
    Nikolai
    VA / NC
    Dang, I’m sorry to hear man. I was able to get $100 and it seems they will let you do at least the $40 now. Time will tell, but still a good deal just $40 off. So far customer service and shipping was on point.
  8. Jan 22, 2020 at 1:44 PM
    #128
    Beau
    Beau
    Agreed, the customer service has been great!
  9. Jan 22, 2020 at 2:50 PM
    #129
    frieselu
    frieselu 13 years with a 1st gen; recent 2nd gen convert
    2008 Green CrewMax
    I just ordered a set of the black PRO's for my 2008 CM. Excited to get them installed! Totally modernizes the look of the front end (along with the Rock Warrior grill update I have planned). I can confirm that discount code stacking is not a thing any longer - I could only use one of the discount codes mentioned above. Any of them worked, but entering a new one replaced the previous one without any stacking.
    Also went with the Headlight Revolution H7 V.4 LED bulbs recommended above.
    rons23 likes this.
  10. Jan 22, 2020 at 4:44 PM
    #130
    SouthWestGA
    SouthWestGA New Member
    Guys i emailed Alpharex directly to see if they would offer us a group buy
    I’ll report back my interactions with them
  11. Jan 22, 2020 at 4:45 PM
    #131
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    :popcorn::popcorn::popcorn:
  12. Jan 22, 2020 at 4:47 PM
    #132
    focal
    Nikolai
    VA / NC
    How have the HR LED bulbs held up being sealed in the housing? I’ve been thinking about them but worried the fan would eventually only circulate hot air or draw in moist air as the headlight cooled after turning off. It also sounds like you had to trim the back of the round covers to get the LEDs to fit. Do you feel the fan is restricted? Thanks.
  13. Jan 22, 2020 at 4:49 PM
    #133
    Beau
    Beau
    x2 on this, I am thinking about doing this to mine as well!
  14. Jan 22, 2020 at 5:00 PM
    #134
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I doubt it. They did at the release. And Nelson Mann is petty active on FB Tundra Crew. But if they do give us another code, I'm all for it!!
  15. Jan 22, 2020 at 6:44 PM
    #135
    r0r0thegr8
    r0r0thegr8 New Member
    2007 Tundra Crewmax Limited 4x4
    Alpharex Pro Headlights
    I have the alpharex pro on 2007 tundra but I modified to use Headlight Revolution LED bulbs which look amazing but I didn’t cover the dust/water cap after the mod. I drove through the car wash once and now they don’t work. The DRLs and side marker LED’s do not turn on but the low beams and amber driving lights work. Does anyone know if I can have them fixed or a place that can modify them to get the DRLs working?
    Help me Tundra guys your my only hope!
  16. Jan 22, 2020 at 6:52 PM
    #136
    focal
    Nikolai
    VA / NC
    When I emailed them about my issue, they asked that I text the tech POC at +1 (626) 841-1965. They texted me back pretty quick.
    Curious, why did you not reinstall the caps?
  17. Jan 22, 2020 at 7:23 PM
    #137
    r0r0thegr8
    I was in a hurry going on road trip and I had to cut a hole in the cover for the led fan that stuck out as well as the wiring. Was going to make an add on cap and seal the whole thing up but it slipped my mind. Keep them sealed everyone.
    focal likes this.
  18. Jan 22, 2020 at 7:58 PM
    #138
    oogabooga289
    oogabooga289 New Member
    Did you use the V.4 H7's?
  19. Jan 23, 2020 at 4:37 AM
    #139
    r0r0thegr8
    Yes. The light output and color are amazing. They match the high beams perfectly.
  20. Jan 23, 2020 at 4:40 AM
    #140
    r0r0thegr8
    Only pic I have of low beam color
    Mountun Goat and oogabooga289 like this.
  21. Jan 23, 2020 at 4:42 AM
    #141
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    So HID's have to cut/drill a whole for ballast wiring.
    LED's may or may not fit. Anyone know how much room is inside the cap?
  22. Jan 23, 2020 at 5:01 AM
    #142
    r0r0thegr8
    No room. I had to cut a huge hole for fan to stick out. I was going to add a spray paint cap and silicone it all up but I didn’t and water got in an fried the DRLs and side marker LED’s
    focal likes this.
  23. Jan 23, 2020 at 5:10 AM
    #143
    focal
    Nikolai
    VA / NC
    Thanks for the heads up! It will help in planning the way forward.
  24. Jan 23, 2020 at 5:36 AM
    #144
    Beau
    Beau
    This is why I went with the race vision halogen bulbs. I'm sure they could be brighter, but they have been trouble free for me so far.IMG_9730.jpgIMG_7885.jpg
    YotaMan, Mountun Goat and Zebruaj like this.
  25. Jan 23, 2020 at 5:53 AM
    #145
    r0r0thegr8
    Wow those look great!
  26. Jan 23, 2020 at 6:40 AM
    #146
    jelloburger
    jelloburger New Member
    Those do look great. You guys are gonna get me divorced if I keep reading these threads. :) QQ for you guys: regarding the AlphaRex, what's the difference between the "Black" and the "Jet Black" versions?
    Mountun Goat and r0r0thegr8 like this.
  27. Jan 23, 2020 at 6:59 AM
    #147
    Beau
    Beau
    Black is apparently more of a flat "abs plastic" look while the jet black is a shiny black. Jet black is supposed to look more "modern."
  28. Jan 23, 2020 at 1:54 PM
    #148
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    The LED's are sealed in the housing. The caps took very little modification with a utility knife to clear the V.4's and they seal up tight. There is also a gap to the rear of the led and space around the perimeter of the fan except the one side I had to modify the cap on. HR warranties them for 2 years and they have a crazy high temp rating. There is quite a bit of empty space in the housing or air circulation. I can see it getting hot in a closed system, especially when it is still 105 at 11pm in Phoenix, but time will tell.
    Tip: Install the LED's before putting the headlights in. There is very little clearance behind them. Also, I dropped the entire LED leads and "ballast" into the housing for super clean install.
  29. Jan 23, 2020 at 1:56 PM
    #149
    Swatdude1
    Phoenix, AZ
    If I was spending that kind of coin, you should definitely check out the Morimotos as well. I went with jet black. There are close ups showing the difference on the Alpharex website.
  30. Jan 23, 2020 at 2:12 PM
    #150
    Beau
    Beau
    I was going to suggest the same, at $280 which I payed I am happy with them. I'd be disappointed in the DRL brightness at the cost you'd pay for the Nova. Also, OEM Sequoia LEDs are getting more reasonable.
