Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Feb 17, 2023 at 5:05 AM
    #901
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Can you tweak the high beams? I thought they were built in and no way to mess with
  2. Feb 17, 2023 at 5:11 AM
    #902
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    I hadn’t noticed there were two silver adjusting locations to use with the Phillips screw driver? One is to mess with the vertical alignment of the low beam. What’s the other for?
  3. Feb 17, 2023 at 5:32 AM
    #903
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Did you have to drill the cap to be able to get it to seat or was there enough space as is?
  4. Feb 17, 2023 at 6:48 AM
    #904
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    How have you liked these thus far ?
  5. Feb 17, 2023 at 6:54 AM
    #905
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    These are 90w, which worry me. Did I read somewhere on here that anything above 35w would melt the projector?
  6. Feb 17, 2023 at 7:36 AM
    #906
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Seems like, they only have one guy doing customer service. It’s hard to get ahold of him. He’s very nice and helpful when you do get to talk to him though.
    RToad[QUOTED] likes this.
  7. Feb 18, 2023 at 1:45 AM
    #907
    RToad
    RToad New Member
    South Carolina
    Agree, good guy. Stretched thin.
  8. Nov 2, 2023 at 9:24 AM
    #908
    jgm253
    jgm253 New Member
    I get this from a couple years ago but I have the same issue on my truck, did you ever hear back from them about this?
  9. Aug 1, 2024 at 1:38 AM
    #909
    Knievo
    Knievo New Member
    2011 Silver Tundra
    Need advice.
    I bought alpharex headlights in 21. I have seen reviews of how moisture gets in but never had an issue. Last week my headlight went out, I took the cap off to get in and replace it, swapped it out and put the cap back on.
    Yesterday I got a car wash and noticed my daytime running light not on. Popped the hood, and immediately noticed the cap was not sealed tight. Then saw moisture in the light. Since then the DRL started flickering were super low in light just on the one exposed to moisture and now both DRL do not work. Everything else works. Any idea what it could be? Fuse, wiring harness or just new headlights? It's a 2011 Tundra. I appreciate your time.
  10. Aug 2, 2024 at 4:31 PM
    #910
    TheBeast [OP] The Beach
    @Knievo
    I would check the DRL fuse. Probably fried. Mine did when moisture got into my morimotos headlights. Dry the faulty headlight then change fuse. Usually a tap in fuse for DRL on our gen 2s.
  11. Aug 2, 2024 at 5:28 PM
    #911
    Knievo
    Knievo New Member
    2011 Silver Tundra
    I changed the fuses that go to the headlight etc...No luck. Is there a fuse in the headlight somewhere?
  12. Apr 18, 2025 at 6:32 AM
    #912
    Rica25
    Ricardo
    Tulare
    Have any of you had the issue where the headlights were cracked when purchased on eBay? Also issues with them switching from amber to white on there own when truck engine is off and the truck ignition is on as well as them flickering when the ignition is on the on position only?
  13. Apr 18, 2025 at 10:42 PM
    #913
    Rica25
    Ricardo
    Tulare
    installed the Alpharex luxx series the only issue is that the sequential and blinker won’t light up I did add led blinker bulbs with load resistors and I can not get them to flash when locking and or unlocking can anyone help.
  14. Aug 2, 2025 at 11:42 AM
    #914
    xx3xil3xx
    xx3xil3xx New Member
    Aj
    2018 tundra sr5
    Stock
    Just installed the proseries with halogen projector....everything works. Tried some cheap led h7 replacements and noticed that I lost the width of output but my fogs covers that anyways. Tried auxbeam and hikari..hukaris a little better. Tried the luxster punisher and for $60, i was surprised on how much output and width compared to the other 2. Im waiting for some gt3 to try but the punisher will stay there for now..ill try to get some pics up at night time.
