Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. May 3, 2022 at 6:20 AM
    #871
    FredB32
    FredB32 New Member
    2011 TRD RW
    What do you have against circle jerks? Toyota drivers are such prudes. :duel:
  2. May 3, 2022 at 8:22 AM
    #872
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    There's got to be a regulation regarding swordplay/circle jerks on this very public forum...
    I NEED A MODERATOR!!!
  3. May 11, 2022 at 3:36 AM
    #873
    RToad
    RToad New Member
    South Carolina
    Looked at your photo, seems like a really nice option. Do you get ppl flashing their brights at you?
  4. May 11, 2022 at 5:09 AM
    #874
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I took the time to align them and aim them where they should be. No unwanted flashing from oncoming traffic.
  5. May 14, 2022 at 12:16 PM
    #875
    RToad
    RToad New Member
    South Carolina
    Who installs headlights and doesn't aim them?
  6. May 14, 2022 at 12:47 PM
    #876
    Shanet421
    San Diego,CA
    My guess is many more do not
  7. May 15, 2022 at 10:39 AM
    #877
    chrisf111
    chrisf111 New Member
    I had to reverse the ploririty of the connector. Tech support said it happens quite often because the stock bulbs will work either way a lot of them come from the factor with the wires switched. Could always give them 12v straight from the battery to test the lights and eliminate the harness. Just remeber leds can only be wired one way.
  8. Jul 6, 2022 at 2:46 PM
    #878
    RToad
    RToad New Member
    South Carolina
  9. Jul 20, 2022 at 9:26 PM
    #879
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Okay, I’ve had the worst headache with my 2008 Tundra’s headlights. I tried calling to buy some retrofitted ones (AWFUL) with HID’s in them. I’m looking at AlphaRex Pro’s now. I do want HID bulbs (6,000k). How hard is it to put HID bulbs in these? I’ve been shocked twice by these headlights somehow and I’m done. Is good visibility with a nice, white light to much to ask for?!
  10. Jul 21, 2022 at 1:18 AM
    #880
    RToad
    RToad New Member
    South Carolina
    According to Headlight Revolution this kit is plug and play. I have retrofitted HID on my 1998 Jeep and they are superior to anything else I have had. I have the Pros on my Tundra and was thinking about going this route. Not impressed with LED in these housings.
    https://www.headlightrevolution.com/H7-Ultra-Series-HID-System_2?quantity=1
  11. Jul 31, 2022 at 12:51 PM
    #881
    009m
    009m New Member
    2010 Black Tundra Platinum
    Tuner, cold air intake, catback exhaust
    Can anyone please guide me to a place where I can have a headlight repaired? I noticed a few weeks ago that my drivers side DRL on my Alpharex Pro's was not working, I went digging and found that my level adjuster was loosely connected and that my upper dust cap was also loose and that water had gotten into my headlight (I assume damaging the DRL or control board). To no avail drying it out did not work. I reached out to Alpharex via the contact form on their website just to see if they happen to do repairs, but I haven't heard back. Otherwise I have been busy working out of town and taking care of my wife who had surgery so I have not had the time to call. Other than the DRL and level adjuster not working, the headlight and blinker is just fine so I am getting by for now. I do love the look of my Pro's and would like to just get mine fixed if at all possible.
  12. Aug 2, 2022 at 6:02 AM
    #882
    cswinson23
    cswinson23 New Member
    Just installed Apharex PRO Series headlights on my '07 Tundra and everything looks great but the turn indicators no longer flash when I unlock using the key FOB. Has anyone else noticed or had the same issue? I installed the DRL harness using the online instructions and everything works great with the exception of the flash when unlocking and also when I turn on the Hazard indicators, with the truck off, the front lights no longer flash. Thoughts?
  13. Aug 11, 2022 at 8:53 AM
    #883
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    how can i tell if my stock headlights have the level adjusters?
  14. Aug 11, 2022 at 1:01 PM
    #884
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
  15. Aug 11, 2022 at 1:05 PM
    #885
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    so that's what that is, i couldnt tell what it was doing. thanks alot.
  16. Sep 20, 2022 at 4:04 PM
    #886
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    2008 Radiant Red Double Cab SR5 TRD Off-road and now 2020 TRD Pro Army Green Crew
    The hazards don’t come on if the truck is off. Also, the headlights don’t blink when you unlock the truck. Anyone else have this problem?
    I guess the lights don’t do anything when the ignition is off.
    Other then that I love them!
  17. Sep 21, 2022 at 1:15 AM
    #887
    RToad
    RToad New Member
    South Carolina
    No I do not have that issue. Sounds like something isn't hooked up right.
    Chrslefty likes this.
  18. Sep 21, 2022 at 6:30 AM
    #888
    Chrslefty
    Chrslefty New Member
    08 dubble cab
  19. Sep 21, 2022 at 7:15 AM
    #889
    Shanet421
    San Diego,CA
    Check post #810 here
    This is an often common overlooked step
    Hope it helps
  20. Jan 15, 2023 at 1:35 PM
    #890
    RToad
    RToad New Member
    South Carolina
    Update after about 16 months of ownership.
    I have always preferred HID lights to LED or Halogen. I replaced the halogen that came in the AlphaRex Pros with LED but did not care for them. I had a lot of dead space in the middle of the road and many people flashed their brights at me although I had the low beams on.
    I ordered a good set of GTR H7 HID lights that were plug and play for the AlphaRex Pro. The only mod to make is you have to drill a 3/4" hole in the back of the low beam cover to accommodate the rubber grommet for the HID light bulb wiring. Didn't think much of it but the very next day my lights were filled with condensation. They are ruined now.
    Hope this saves someone the headache I have. I am going to spend more money now on a higher quality setup.
    Chadwicktr and PhotoNerd like this.
  21. Jan 16, 2023 at 12:09 AM
    #891
    Chrslefty
    08 dubble cab
    I dont get why people are mad that they have condensation when that have made a way for water to get in.
    Mine are still bone dry, i left the bulbs that it came with alone.
    This is with car washes and being left outside the whole time.
  22. Jan 16, 2023 at 2:43 AM
    #892
    RToad
    RToad New Member
    South Carolina
    I'm not mad, at all. I am just giving others a heads up. They will offer you a "plug and play" HID kit and when you install it the lights will be junk. Leave the ugly yellow halogen bulbs in and you probably won't have a problem.
    It's called sharing your experience so you can save others some pain, try it.
    Anyhow, I won't be worrying about it anymore. I have Morimoto XB LED's on the way. I should have bought them the first time. :)
    Blang805 and texasrho83 like this.
  23. Jan 16, 2023 at 5:54 AM
    #893
    Chrslefty
    08 dubble cab
    I didn't realize the hid kit was from them.
    I like the ugly yellow ,personally not a fan of led's of headlights . But to each there own.
    Hope the new ones server you well.
  24. Jan 16, 2023 at 6:19 AM
    #894
    COTundie
    Trey
    Pretty things
    You know, yellow HID kits are available if you prefer yellow AND better light output :D
    I think you'll like the Morimotos. Did you go with amber or the white DRLs?
    Either way, really good looking headlight with performance to match.
  25. Jan 16, 2023 at 6:24 AM
    #895
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Damn that's a hard lesson to learn.
    I learned it myself years ago. I never make extra holes in HLs now lol.
  26. Jan 18, 2023 at 7:06 PM
    #896
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have Morimoto HIDs in mine. Drilled the cap to make the hole to pass thru the wiring. Added Silicone around the hole and the hid grommet. Haven't had any moisture problems.
    kbark, RToad, Chrslefty and 1 other person like this.
  27. Jan 28, 2023 at 3:19 PM
    #897
    RToad
    RToad New Member
    South Carolina
    Happy for you.
    I now have Morimoto XB LED and matching Fogs.. My biggest regret is that I settled for the AlphaRex the first go. The Morimotos look better and perform much better. They are definitely much higher quality.
  28. Jan 28, 2023 at 4:18 PM
    #898
    Nemesis
    Nemesis New Member
    Depends on which model you go with. If the Nova series (like I have) the Morimotos under perform.
  29. Feb 17, 2023 at 4:59 AM
    #899
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Do you have a link from the HID kit? Can’t find it
  30. Feb 17, 2023 at 5:01 AM
    #900
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    What bulb set do you have in these?
