Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Sep 19, 2021 at 3:37 PM
    #721
    colbster4x4
    colbster4x4 New Member
    Colby
    2010 Pyrite Mica Tundra DC
    I was surprised when I received my headlights and there were no instructions. Thankfully I was able to find the install guide on their website. Here is a link for the install guide if anyone is looking for it.
    https://alpharexusa.com/installation-guide-for-07-13-toyota-tundra-08-17-toyota-sequoia-headlights/
    Also here is the DRL install guide
    https://alpharexusa.com/how-to-wire-the-drl-harness/
    RToad likes this.
  2. Sep 21, 2021 at 7:36 AM
    #722
    FrogmanTundra
    FrogmanTundra New Member
    Nashville
    2013 Rock Warrior DC
    I've had my set of Alpharex Pros since Dec 2019. I live in middle TN, we see plenty of rain here, and yet to have any issues with condensation. Also no issues with headlight/DRL function. I've been very happy with these headlights.
    12TUNDRA615 and TNTundra53 like this.
  3. Sep 21, 2021 at 8:22 AM
    #723
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    The cheap-o non Alpha Rex headlights I had previously didn't make it through a single carwash before filling with water. I emptied out about a two cups of water after that one. I dried those out and sealed around the edges and never had another issue. That said, I've taken the new Alpha Rex ones through the carwash and a few rain storms and have had no issues. They look well made, so I figured I would chance it for now.
  4. Sep 26, 2021 at 12:37 PM
    #724
    RToad
    RToad New Member
    South Carolina
    Currently installing these. I am getting myself confused but thought I would ask for clarity. The side markers, do I just unplug the aftermarket socket and plug in the original subbing the wire for where the bulb went?
  5. Sep 26, 2021 at 12:42 PM
    #725
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    That is correct. There is a built in LED in the housing. Be careful when turning that plug into the housing as there doesn’t seem the be a stop when twisting. Turn it 90 degrees and stop or else it will continue to spin.
    RToad[QUOTED] likes this.
  6. Sep 26, 2021 at 12:55 PM
    #726
    RToad
    RToad New Member
    South Carolina
    Thanks for the speedy reply, I was about 80% sure on that.
    I have one more question so far. The gray wire for the DRL goes to the ignition which by default is 10A. The fuse provided is 5A. Has anyone had any issues with that?
  7. Sep 26, 2021 at 12:57 PM
    #727
    apwisher
    apwisher New Member
    Everett, WA
    if they gave you the adapter, use the 10A for the ignition and the 5 for the headlight side of things
    should hold two fuses
  8. Sep 26, 2021 at 1:00 PM
    #728
    Shanet421
    San Diego,CA
    Correct as @apwisher said you need both fuses to make the DRLs work
  9. Sep 26, 2021 at 1:52 PM
    #729
    RToad
    RToad New Member
    South Carolina
    Ok guys. I have everything hooked up and I love them but I do have one issue. I am not noticing a change when I turn on the brights?
  10. Sep 26, 2021 at 3:53 PM
    #730
    RToad
    RToad New Member
    South Carolina
    Figured out the issue with the high beams. The connectors for those require you to really push them in hard and squeeze the clip hard to get them to seat.
    I want to say thank you to @apwisher for taking the time to answer my questions those things are a huge help.
    Note to EVERYONE. I pulled the trigger on these without doing all my homework. I learned during today's install that I could have purchased the headlights with the auto adjusters. I am brand new to Toyota. Had I known earlier I would have order the model with auto adjusters.
    Now here are some photos HUGE improvement!
    WVI, kbark, omgboost and 4 others like this.
  11. Sep 28, 2021 at 9:52 AM
    #731
    Sanoman
    Sanoman New Member
    Do the lights come with all the necessary items to get the DRL to function or do I need to make an additional purchase.
    I’d been debating dropping big coin on the Sequoia LED conversion, but my truck is an ‘08 and to drop $2k on headlights is tough.
    if the Alpharex pro lights are good quality and straight forward installation, I may go with these instead.
    thanks
    omgboost likes this.
  12. Sep 28, 2021 at 9:58 AM
    #732
    FrogmanTundra
    Nashville
    The Pros come with everything you need. They come with a harness for the DRLs and the install is very straight forward. They're a pretty decent headlight for the price, even better if you upgrade the low beams.
    RToad likes this.
  13. Sep 28, 2021 at 12:55 PM
    #733
    Sanoman
    Sanoman New Member
    Thanks. I really want the sequoia lights, but man that price at close to $1800 all in.
    I just have concerns about all the moisture/condensation issues i’ve read about with the alpharex. I bought some aftermarket housings for a Tacoma about 10 years ago and they immediately condensated. After that I told myself OEM only for light housings.
    Tough decisions
    toyofan87 likes this.
  14. Sep 28, 2021 at 1:35 PM
    #734
    FrogmanTundra
    Nashville
    Agreed, the Sequoia lights are my favorite by far but cost too much for my blood. I've had the Alpharex Pros since Dec 2019, they've seen over 100 inches of rainfall since then with no issues.
  15. Sep 28, 2021 at 1:51 PM
    #735
    RToad
    RToad New Member
    South Carolina
    This is on point. Didn't take much to install, pretty easy. Absolutely love the results. They are beautiful.
  16. Sep 28, 2021 at 3:22 PM
    #736
    FrogmanTundra
    Nashville
    For everyone's reference, I shared this back in early 2020 when I upgraded the low beams, but it would be worth sharing again for those of you making the upgrade to the Pros.
    Below is a side by side of the stock Alpharex Pros (from Dec2019 they may have changed since then) and the upgraded low beam. Stock drivers side is the included halogen bulb and passenger side has a LED for low beam. EDIT: LEDs are GTR Ultra 2s
  17. Sep 28, 2021 at 6:07 PM
    #737
    Sanoman
    Sanoman New Member
    Which brand/model LED did you use?
  18. Sep 28, 2021 at 6:21 PM
    #738
    FrogmanTundra
    Nashville
    I'm using GTR Ultra 2 LEDs, a bit pricey but I like them and they have a lifetime warranty.
  19. Sep 28, 2021 at 6:35 PM
    #739
    Sanoman
    Sanoman New Member
    do you have a link to them?
  20. Oct 13, 2021 at 9:26 PM
    #740
    Sanoman
    Sanoman New Member
    My dads 2007 tundra does not have factory DRL. Is there a way to work the alpharex in his truck with a DRL function?
  21. Oct 14, 2021 at 5:04 AM
    #741
    Shanet421
    San Diego,CA
    If you use the supplied harness yes you will have DRLs
    apwisher likes this.
  22. Oct 19, 2021 at 8:41 AM
    #742
    Sanoman
    Sanoman New Member
    Got them hooked up along with installation of the sequoia grill.
    Hard to believe this truck is 14 years old lol
    zachzap361, RToad, omgboost and 6 others like this.
  23. Oct 19, 2021 at 8:14 PM
    #743
    Sanoman
    Sanoman New Member
    One of my DRL’s is flickering. I reached out to alpharex and will report back.
    RToad and chaosbooboogunner like this.
  24. Oct 21, 2021 at 2:22 PM
    #744
    Sanoman
    Sanoman New Member
    I contacted Alpharex 2 days ago about my brand new out of the box faulty drivers side headlight. They have not responded. Has anyone had experience with dealing with their customer support? Good or bad? Do they have a phone number I can call?
  25. Oct 21, 2021 at 4:50 PM
    #745
    apwisher
    apwisher New Member
    Everett, WA
    I contacted them through email and they replied the next day.
    When you say your light is flickering, you don't mean hyper flashing correct? I hit my bulb sockets with contact cleaner and they seemed ok, as I also had a bit of poor connection. Also make sure your ground is good. Does it change if you smack the enclosure?
    G/L
  26. Oct 21, 2021 at 5:25 PM
    #746
    Sanoman
    Sanoman New Member
    it’s a random flickering that only happens on the drivers side when running the full brightness DRL. I sent alpharex two videos. It won’t let me post the video on this thread or I would.
    no response to bumping the light or wire connection wiggling. I thought maybe it was a low battery problem so I topped it off and confirmed full voltage output. Problem remains.
    hopefully Alpharex gets back to me. I don’t like being ignored, and was already hesitant to order these based on some of the issues I’ve read about with others. I decided to roll the dice anyway, and here we are…
  27. Oct 22, 2021 at 8:45 AM
    #747
    SouthWestGA
    SouthWestGA New Member
    Have you tried their Facebook page?
  28. Oct 22, 2021 at 1:07 PM
    #748
    Sanoman
    Sanoman New Member
    I just sent them a message on facebook. Thanks for the idea. I will report back.
  29. Oct 22, 2021 at 2:52 PM
    #749
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I didn't go with them just cause of all the issues I heard of but another idea is to call headlight revolution they are great they will help you out even if you didn't buy from them
  30. Oct 30, 2021 at 4:29 AM
    #750
    RToad
    RToad New Member
    South Carolina
    Where did you buy the grille? Does it come painted?
