Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Dec 16, 2020 at 7:37 PM
    #451
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I was looking at them, I'm not sure what to think about their new tail lights:cool: I would think their fitment would be a lot better than Spyder, my Nova headlights fit very nice.
  2. Dec 17, 2020 at 2:45 AM
    #452
    DRIFTSC
    DRIFTSC New Member
    2008 Tundra
    Don't mind if I do!
    Upgraded with GTR Ultra 2 H7 bulbs and GTR Armor Switchback turn signal bulbs
    New vs Stock comparison
    And the modification required to fit the bulbs:
  3. Dec 18, 2020 at 3:02 PM
    #453
    Torogi
    Torogi New Member
    Reece
    2011 Crewmax Rock Warrior
    Thanks for this. I made quite a few mistakes last night. I did the sequential signal step (per instruction) on my PROs so yep, no signal light. Pulled it and now I have turn signals.
    I don't have a high beam/flash so that is what I was trying to figure out last night. I did the install from work so I had to put back everything without high's (not that I needed it luckily). So I will give this a try today.
    MTRock[QUOTED] likes this.
  4. Dec 18, 2020 at 3:41 PM
    #454
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    The pins looked fine.. Just slightly bent inwards so the pins wouldn’t fully insert. Hold both connectors next to each other so you can look into them at the same time and you should be able to tell if the pins need adjusted..I should have taken a picture!
  5. Dec 18, 2020 at 4:24 PM
    #455
    Torogi
    Torogi New Member
    Reece
    I hear you, so I just got outside. The Right (passenger) side was a success. I did notice that the plug was not fully inserted. I did make sure the click was audible. High and pass works!
    The driver side, not so much. I reversed the polarity on the LED H7, no light, that means I had it right first time. the 2 plugs are mated properly (1 has like side fins, 1 was smooth). Both were fully inserted, clicked. The plug that had the fins on the side I noticed that the internal pins were slightly gapped closer compared to the other plug. not unusual I dont think.
    No high on driver side, but on pass (low beam off), the low beam comes on ---- and on the passenger side both low and high comes on which I presume should be the normal.
  6. Dec 18, 2020 at 4:28 PM
    #456
    SouthWestGA
    SouthWestGA New Member
    If you had the plugs reversed,and you turned the switch on,then I suggest checking for blown fuses under the hood.
    When mine were backwards plugs,I blew fuses until I figured it out
  7. Dec 18, 2020 at 4:33 PM
    #457
    Torogi
    Torogi New Member
    Reece
    Thanks for that. I dont have my voltmeter with me tonight, but will def do it tomorrow. Thank you gentlemen.
  8. Dec 18, 2020 at 5:39 PM
    #458
    Blasterrr
    Blasterrr New Member
    Anyone have the new TRD pro style headlights yet?
  9. Dec 18, 2020 at 5:47 PM
    #459
    MTRock
    MTRock 1889
    Montana
    Sequoia yes..New Tundras TRD’s won’t fit the 07-13.
  10. Dec 18, 2020 at 6:21 PM
    #460
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    I swapped form the Alpharexs to the sequoia TRD style. Here is a pic for comparison
    TheBeast[OP] and Trident like this.
  11. Dec 18, 2020 at 6:25 PM
    #461
    Torogi
    Torogi New Member
    Reece
    How much those Sequoia TRD run you?
  12. Dec 18, 2020 at 6:29 PM
    #462
    Beau
    Beau
    $300 for each headlight plus $100 for the filler panels underneath and $110 for the harness. Best $800ish that I spent on the truck so far!! Huge difference and much newer looking.
    TheBeast[OP] likes this.
  13. Dec 18, 2020 at 6:33 PM
    #463
    Torogi
    Torogi New Member
    Reece
    I bet man, that looks really really good. The strip on the alpharex (like the PROs I have now) looks like turned off =) lol. But I am coming for my OEM circa 2011 light. So I can't complain.
  14. Dec 18, 2020 at 6:37 PM
    #464
    Beau
    Beau
    Agreed, when I went from my 08 stock headlights to the Alpharex ones I was stoked....but then I kept seeing pics of the new sequoia lights and finally caved:). My truck is paid off and looks like a $65k 2020 model. At least, that was my rationale for splurging on more new headlights. I’ll be honest though, the alpharexs were great besides the DRL bar during the day.
  15. Dec 18, 2020 at 6:47 PM
    #465
    Torogi
    Torogi New Member
    Reece
    when I paid off my 2011 back in 2016 sometime, I almost almost! got sucked into buying a supercharger =D, at that time there were only a few left in the market.
    So, instead, I bought a TRD rear swaybar. lol. big compromise, but the big man in me talked me out of it. work, home, weekend with the kids, not really needed. Slowly though, building an overlander.
  16. Dec 19, 2020 at 9:12 PM
    #466
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Where did you buy these parts?
  17. Dec 20, 2020 at 10:12 AM
    #467
    Beau
    Beau
    Headlights were from eBay, filler panels from sparks parts, and harness from @xrunnerdude67. The headlights are hit and miss on eBay. When they come up for a good price, they go pretty quick. I had a search saved and each time a new one was listed, I'd try to look at it right away. There is one seller that has them pretty consistently for about $440 each shipped if you don't want to wait. The harness took about 2-3 weeks after I ordered it but it both necessary and highly convenient for the install. Hope this helps!
    mtndds98 likes this.
  18. Dec 20, 2020 at 10:14 AM
    #468
    Beau
    Beau
    It looks like alpharex and Morimoto had a baby on this design. I like the sequential turns signals. Are the DRL bars any brighter than the first gen? It doesn't look like they are and that was my biggest complaint with the alpharex.
  19. Dec 20, 2020 at 10:35 AM
    #469
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Thanks will start checking eBay.
  20. Dec 20, 2020 at 10:41 AM
    #470
    Beau
    Beau
  21. Dec 20, 2020 at 11:04 AM
    #471
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
  22. Dec 23, 2020 at 2:45 PM
    #472
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Hey people. I am interested in buying some alpharex headlights. Is the price on their website for one headlight or for a set? Thanks.
  23. Dec 23, 2020 at 2:48 PM
    #473
    rons23
    Ron
    Kill Devil Hills
    Price is for set. Which set you looking at?
  24. Dec 23, 2020 at 3:40 PM
    #474
    mtndds98
    mtndds98 New Member
    I am looking at the PRO series projector w/ auto leveler. The model number is 880711. Are they any good?
  25. Dec 23, 2020 at 5:29 PM
    #475
    rons23
    Ron
    Kill Devil Hills
    There are some members running the Pros and are the cheaper route than going with the Nova's. I went with the Nova's, because the insurance paid for them :D They are great headlights which ever one you pick. Light output is great and fitment is good. Read the whole thread, you can pick up some info on the Pros. I believe Alpharex just come out with the Pros with the sequential turn signals. Good luck
  26. Dec 23, 2020 at 6:01 PM
    #476
    MTRock
    MTRock 1889
    Montana
    Yep! Lowbeams aren’t the best but brights are way better...Many buyers replace the lowbeam bulbs, I haven’t got around to it! Search around you should be able to find then for under $400...Unbeatable for the price
  27. Dec 23, 2020 at 6:34 PM
    #477
    mtndds98
    mtndds98 New Member
    Thanks everyone for the feedback. I just want to update the look a little. I think these lights will do that. Merry Xmas!!
  28. Dec 23, 2020 at 6:44 PM
    #478
    rons23
    Ron
    Kill Devil Hills
    They will , might as well get their new tailights that just come out. MERRY XMAS :thumbsup:
  29. Dec 24, 2020 at 5:12 AM
    #479
    tjinaz
    tjinaz New Member
    2011 RW
    MTRock likes this.
  30. Dec 24, 2020 at 5:25 AM
    #480
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    If these are the lights you go with then i highly recommend the retrofit source or headlight revolution. As far as the lights them selves i debated between these and the Morimoto XBs for months. Eventually got to see these in person which swayed me to the Morimotos. They seem to be nice headlights, just weren't quite what i was looking for.
    Whichever ones you choose i would definitely use the retrofit source or headlight revolution though!
