Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Sep 5, 2020 at 7:49 PM
    #421
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hair dryer or heat gun on low. Also before you seal it back up put some silica packs in the headlights. You can get them from TRS. :thumbsup:
    https://www.theretrofitsource.com/silica-gel-moisture-packs-A-SILICA?quantity=1
    YotaFan05[QUOTED] likes this.
  2. Sep 9, 2020 at 7:02 PM
    #422
    cfe4130
    cfe4130 New Member
    Yes, it will clear up. Maybe remove the back cap that you drilled through to let the air in. What does the hole look like that you drilled through? I drilled a hole through the cap, pushed a rubber tapered grommet through it, drilled a hole through it, and pushed the wires through. It wasn't easy but it survived drive through car wash today.
  3. Sep 10, 2020 at 9:26 AM
    #423
    KJJ2007
    KJJ2007 New Member
    Kris
    Earth
    2007 Tundra RCSB
    S@B Cold Air Intake, Lowered 8" in the rear, 4" in the front, Tented taillights.
    Did you get this fixed?
  4. Sep 10, 2020 at 9:37 AM
    #424
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    I've currently got the dust cover off of the headlight to see if it'll dry out. So far, no change I'll probably need to use a heat source to help. I'll update later.
  5. Sep 13, 2020 at 6:32 PM
    #425
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Update on this; I did successfully get all of the moisture out of the headlight by removing the headlight housing from the truck and leaving the dust cap off for a few days. Still not positive how the moisture got into the headlight, I did silicone the hid wires pretty good.
    Unfortunately, my led DRL light tube is not working now. I don't know if it was not working right before all of this, but I tried re installing everything tonight and it won't work. I emailed Alpharex to see what I can do. Hopefully there's a warranty. I'll update when I hear more.
    KJJ2007 and omgboost like this.
  6. Sep 25, 2020 at 4:50 PM
    #426
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Alpharex replaced my headlight, it was a relatively easy process. Great customer service! Got the new headlight installed tonight and everything is back to normal now.
    Quebec likes this.
  7. Sep 28, 2020 at 6:27 AM
    #427
    MilesToEmpty
    MilesToEmpty New Member
    Charles
    2007 DC 4x4 Linited
    Does anyone have photos of the chrome housing on a silver truck? My 07 is silver with the great big chrome grandpa grill with chrome accents. I don’t like chrome, but I think they would look better then black.
  8. Oct 5, 2020 at 9:18 AM
    #428
    MilesToEmpty
    Charles
    2007 DC 4x4 Linited
    Well I got my headlamps installed over the weekend.
    I would like to get some brighter low beans. Also think I have them aimed a bit low, the cut off seems pretty close and found myself switching from Low to high non stop on back roads.
    Does anyone have a recommendation for LED turn signals?
    toyofan87, KJJ2007 and Chrslefty like this.
  9. Oct 8, 2020 at 8:26 AM
    #429
    07bigsalsa
    07bigsalsa New Member
    Does anyone have any promo codes for alpharex pros?
  10. Oct 9, 2020 at 12:00 PM
    #430
    MilesToEmpty
    Charles
    2007 DC 4x4 Linited
    Im unaware of any codes, so I bought mine on Amazon.
  11. Oct 21, 2020 at 3:46 PM
    #431
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    Would someone mind posting a close up photo of the DRL bar? I am on the fence with these or the morimotos and am concerned the DRL bar may look cheap or "plasticy" in person like some of the cheap ebay lights, if that makes since.
  12. Oct 21, 2020 at 3:56 PM
    #432
    rons23
    Ron
    Kill Devil Hills
    Check their Facebook page :D
  13. Oct 21, 2020 at 4:11 PM
    #433
    rons23
    Ron
    Kill Devil Hills
    The Alpharex are well made, and the DRLS are plenty bright. If you try to run your amber running lights it will dim them. If you leave them off they will be at maximum output. I can't speak for the Morimoto XB, but a lot of members run them. Imop you can't go wrong with either brand. The output on my Nova's are insane. They are night and day compared to the spyders and anything else for that matter. Check around on their website or Facebook page for possible discounts.
    Here's a pic with amber and without. Sorry not the best pics. Hope this helps
    KJJ2007, TheBeast[OP] and omgboost like this.
  14. Oct 21, 2020 at 4:16 PM
    #434
    cygan1008
    When it isn't illuminated, does that DRL look like a white piece of plastic diffuser or is it tinted, textured any way? I have been looking on their facebook as well some photos make it look almost silver or metallic some make it look like just a white plastic.
  15. Oct 21, 2020 at 4:31 PM
    #435
    rons23
    Ron
    Kill Devil Hills
    It's not tinted or textured. Its not cheap plastic looking. Not sure what your asking. There well made headlights. I got mine wired via fuse tap to ignition source.
  16. Nov 2, 2020 at 3:18 PM
    #436
    davids_1718
    davids_1718 New Member
    2014 blizzard pearl platinum sequoia
    Alpharex nova gen 2 headlight Diode Dynamic ss3 pro fogs Dasaita head unit Blacked out interior silver panels Color matched rain visors, bug shield and oem fender flares AFE cold air Dirty Deeds 8" catback system
    Hello everyone new to the site. I have an 08 sequoia platinum and am dying to upgrade my headlights. Is it just me or are the factory turn signals a major eye sore with the alpharex headlights. Does anyone know of anybody customizing these to have sequential turns?
  17. Nov 3, 2020 at 9:19 AM
    #437
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    The Morimoto XB give you the option to have sequential turn signals.
    TheBeast[OP] likes this.
  18. Nov 4, 2020 at 2:19 PM
    #438
    jk715
    jk715 New Member
  19. Nov 4, 2020 at 2:20 PM
    #439
    davids_1718
    Totally understood, besides tge price factor on the morimoto's i'm really digging the activation sequence. That will make my 08 look more modern. I guess thats the only thing we sequoia and tundra owners got going for us is the body style hasnt changed. Just bumpers and internal dash and steering wheel changes is all we had over the years.
  20. Nov 4, 2020 at 2:41 PM
    #440
    FrogmanTundra
    FrogmanTundra New Member
    Nashville
    2013 Rock Warrior DC
    Yes, many of us started swapping in LED H7 bulbs at the beginning of the year which can be found in this thread, my post is #192 on pg7. There was talk of compiling a list of bulbs that would clear the dust cover but I'm not sure if that ever happened. However a quick look back at the beginning of this thread should show a few different LED bulbs that clear the dust cap.
  21. Nov 19, 2020 at 1:59 PM
    #441
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Installed Alpharex pros today..Everything works except the high beams?? Fuses are good and double checked the connections..Anyone have this problem?
    Edit..Fixed called Alpharex said it may be reversed polarity? When I was going to swap the pins they looked like they were bent too close together. I slightly spread them out and now all is well! Also when you connect the highbeams to the harness you should feel it click in place, mine wouldn’t until I spread the pins, it looked like it was connected but not quite.
    Quebec and omgboost like this.
  22. Nov 19, 2020 at 3:42 PM
    #442
    KaneDog
    KaneDog New Member
    2012 Black SR5 TRD FFV
    Don't mean to hijack this thread on the alpharex headlights but has anyone purchased and installed the alpharex tail lights recently? Was initially looking to get the syder tails but saw the alpharex tails and would like to get those to pair with my headlights.
    MTRock and TheBeast[OP] like this.
  23. Nov 19, 2020 at 4:33 PM
    #443
    Quebec
    Quebec New Member
    I don't have Alpharex's yet but I like reading reports that people are happy with the product and customer service. I hope as a company they are here to stay.
  24. Nov 19, 2020 at 5:26 PM
    #444
    MTRock
    MTRock 1889
    Montana
    These? Look good!
  25. Nov 26, 2020 at 5:44 PM
    #445
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    So to clarify, we buy H7 led bulbs for a 2011 tundra with alpharex pro headlights?
  26. Nov 26, 2020 at 5:58 PM
    #446
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Yes. Low beam takes a H7 bulb
    Cmaccullen[QUOTED] likes this.
  27. Dec 2, 2020 at 1:28 AM
    #447
    davids_1718
    Just wanted to be the first to let everyone know that i just heard from Aplharex that in the next ciuple months they will be releasing a newer version of headlights for our trucks with sequential turn signals. Who knows maybe if we act on it fast we can inquire a little more and get a group buy for this newer version. I was told could be in as little as a few weeks to 2 months. Thats the only way im getting these if they have the sequential turns.
    TheBeast[OP] and MTRock like this.
  28. Dec 2, 2020 at 8:52 AM
    #448
    TheBeast [OP] The Beach
    nice ! keep them coming. the more the merrier
  29. Dec 15, 2020 at 8:12 AM
    #449
    DRIFTSC
    DRIFTSC New Member
    2008 Tundra
    Good looking out! My new set showed up two days ago and has the sequential turn signals, so it looks like I'm one of the first to get them! The specific color/option that I bought was backordered on the site, so I'm not sure if all colors/options are available with sequential turn signals yet, or just the ones that I got.
  30. Dec 16, 2020 at 10:40 AM
    #450
    well time to post some pictures :)
