Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Feb 13, 2020 at 9:17 AM
    #271
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    @Beau so just ignore the DRL harness and wire each LED lead to power?
  2. Feb 13, 2020 at 9:32 AM
    #272
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Yes, just disregard the harness altogether and wire them to the ignition fuse for power. Too EASY
    Zebruaj[QUOTED] and frieselu like this.
  3. Feb 13, 2020 at 9:44 AM
    #273
    FrogmanTundra
    FrogmanTundra New Member
    Nashville
    2013 Rock Warrior DC
    Have you opened up the DRL harness box? I wonder what's in there.
  4. Feb 13, 2020 at 9:59 AM
    #274
    Beau
    Beau
    I did, not sure what all the components are. They have been waterproofed so are all encapsulated. I'd imagine it is just some sort of relay and regulator which turns the DRLs on and dims them with headlights.
    Zebruaj likes this.
  5. Feb 13, 2020 at 12:32 PM
    #275
    Beau
    Beau
    Ask and you shall receive.
    FrogmanTundra[QUOTED] likes this.
  6. Feb 13, 2020 at 3:07 PM
    #276
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    ^^^ your tool box is a little too neat.
    TundraTRD08, Sas and FrogmanTundra like this.
  7. Feb 13, 2020 at 3:19 PM
    #277
    Beau
    Beau
    What can I say, I like to know where my stuff is:). Nothing like spending an hour looking for a tool!!
    TundraTRD08 likes this.
  8. Feb 13, 2020 at 3:23 PM
    #278
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    It’s raining out so can’t check right now, but do I have it right. The two brown wires coming out of the headlights are wired straight to the tap on the ign fuse?
  9. Feb 13, 2020 at 3:31 PM
    #279
    Beau
    Beau
    Yes. I actually used the part of the harness with the connectors in order to be able to disconnect them at a later date.
    focal[QUOTED] likes this.
  10. Feb 13, 2020 at 4:07 PM
    #280
    focal
    Nikolai
    VA / NC
    I gotcha. I plan to do the same. Thanks for taking time to figure this out.
  11. Feb 13, 2020 at 4:53 PM
    #281
    Beau
    Beau
    Ok guys, my bad! I guess I didn’t notice during the daytime (by myself) that the DRL was still dimming. I’m not sure what the harness does now or how to make it so the DRL doesn’t dim....again, sorry:anonymous:
    focal likes this.
  12. Feb 13, 2020 at 5:28 PM
    #282
    focal
    Nikolai
    VA / NC
    No harm, no foul. I think the “brain” gives the DRL more power only with the headlights off because when I didn’t install the harness, the ring did not light at all with the headlights off, but would still do half power with parking or headlights on. The half-power mode is powered by the headlight bulb plugs and the full power mode is powered by the harness.
  13. Feb 13, 2020 at 5:49 PM
    #283
    Beau
    Beau
    Straight from Alpharex via FB: "Sorry, but the DRL bar is design to be dimmer when parking light light is turn on, it's build in to the circuit board."
    DANG! Not only are they dimmer than the Morimotos, but they dim even more at night!
    FrogmanTundra and Zebruaj like this.
  14. Feb 14, 2020 at 6:30 PM
    #284
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I can say 4300k HIDs have way better usable visibility than 6000k LEDs for me and my environment. There's actual light on the snow and roads vs it being washed out.
    But it's too effin cold for silicone. I'll have to deal with condensation as it occurs until it's warm enough to apply silicone.
  15. Feb 14, 2020 at 6:39 PM
    #285
    Beau
    Beau
    Most good HID kits come with grommets for passing the wires through the dust cover.
  16. Feb 14, 2020 at 6:51 PM
    #286
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Yeah there is, but Alpharex says that's 1 cause of moisture. They silicone the gasket on the kits they sell prefitted with hids. They made the hid install directions private online now tho.
  17. Feb 15, 2020 at 6:07 PM
    #287
    frieselu
    frieselu 13 years with a 1st gen; recent 2nd gen convert
    2008 Green CrewMax
    I installed the Pro’s today on my ‘08 CM with the V.4 LED’s. Thanks much to the advice on this thread! Was a seamless install.
    You can see that clearance was very tight for the dust cap on the passenger side, so I had to trim the rim of the cap to avoid rubbing. I’m still confident it will be watertight as the rubber seal seats fine. On the driver side there was more clearance so I just shaved a bit off the interior of the dust cap ring to avoid putting lateral pressure on the LED housing.
    I wired the DRL harness up according to the suggestion above to splice both the red and gray wire into the add-a-fuse instead of going to the battery terminal with the red wire. Works just fine and is a cleaner install.
    Happy with the finished look! Now that it’s dark I need to go adjust them but I have a long Phillips head screwdriver that reaches the adjusters so I’m hoping it won’t be a bear.
    Happy to share more about the experience if anyone has questions.
    digdug, omgboost, SC_TRD and 7 others like this.
  18. Feb 15, 2020 at 6:28 PM
    #288
    TheBeast [OP] The Beach
    sharp looking !
    frieselu likes this.
  19. Feb 15, 2020 at 7:32 PM
    #289
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I had to crank my aim way up after the initial install.
    Does anyone notice their left/right adjuster doing anything. I turned both sides and gave up after awhile. Saw no left/right changes.
  20. Feb 15, 2020 at 7:55 PM
    #290
    frieselu
    2008 Green CrewMax
    Drivers side was way low and I had to crank it up. Passenger side too but less so. I did have lateral movement with the horizontal screw. Seemed to take longer than the vertical to see the effect. I also noticed a few times that in the dark I was turning the screwdriver but had shifted it enough to not actually be turning the adjuster knob, so I had to reposition my grip and then saw the movement.
  21. Feb 15, 2020 at 7:59 PM
    #291
    frieselu
    2008 Green CrewMax
    I’ve never had a vehicle with LED headlights before so the upgrade from halogen is pretty spectacular. High beams are like lasers, as mentioned above.
    First take at the adjustment. Good for now and will evaluate based on road reactions as much as anything. Dialed the driver side a bit lower.
    focal likes this.
  22. Feb 15, 2020 at 8:25 PM
    #292
    oogabooga289
    oogabooga289 New Member
    Is there shadowing like the poster in post #235?
    https://www.tundras.com/threads/alpharex-usa-headlights.53256/page-8#post-1619738
  23. Feb 16, 2020 at 5:20 AM
    #293
    frieselu
    2008 Green CrewMax
    I didn’t pay attention to that last night, but I’ll see if I can notice it next time I drive in the dark and post a pic.
  24. Feb 16, 2020 at 6:11 AM
    #294
    Beau
    Beau
    Looks great, nice write up.
  25. Feb 16, 2020 at 5:17 PM
    #295
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    4500k hids vs 6000k leds. Dashcam footage.
    4500k is easier/more natural to my eyes. It's more favorable and obvious for 4500k when the roads are wet or snow is flying.
    BrandonL812 and focal like this.
  26. Feb 18, 2020 at 2:31 PM
    #296
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I can find one quick at the local parts store!:rofl:
  27. Feb 18, 2020 at 2:38 PM
    #297
    frieselu
    2008 Green CrewMax
    oogabooga289[QUOTED] and focal like this.
  28. Feb 18, 2020 at 3:18 PM
    #298
    oogabooga289
    Thanks for the pic. I wonder if this is another reason why people say not to mix projectors and LED's?
  29. Feb 18, 2020 at 5:57 PM
    #299
    frieselu
    2008 Green CrewMax
    Yeah probably so. Worth it in my book tho! Overall I’m still very pleased.
  30. Feb 18, 2020 at 6:06 PM
    #300
    Beau
    Beau
    Agreed, the output is far superior to halogen bulbs. I may go HID at some point, but more than likely, will do the 2018 sequoia headlights upgrade instead.
    BrandonL812 and frieselu[QUOTED] like this.
