Alpharex headlights bulb position
Discussion in 'Lighting' started by 1Tundra5, May 15, 2023.
  1. May 15, 2023 at 10:35 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    So my headlights don’t project very far. I called Alpharex and they said LEDs had to be positioned at 2 and 8. Is this right?
    I know he works for the company, but just want to make sure he didn’t have a brain fart and meant 3 and 9. (Which I already did, but lights don’t shine far)
    I have the pro-series.
    Anyone else have this issue?
  2. May 15, 2023 at 10:41 AM
    The Leds should face the curvature of the reflector.
  3. May 15, 2023 at 10:43 AM
    1Tundra5
    Junior
    2015 White SR5
    sorry, don’t know what that means.
  4. May 15, 2023 at 10:47 AM
    Ok those are projector housings. Are the bulbs that you are replacing halogens that are in the low beams?
  5. May 15, 2023 at 10:55 AM
    1Tundra5
    Junior
    2015 White SR5
    I replaced halogens with LEDs.
    I thought the chips of the flat surface were supposed to face 3 and 9 o’clock.
  6. May 23, 2023 at 5:44 PM
    silversurfertundra
    silversurfertundra New Member
    2021 Silver Tundra Platinum
    I’m having trouble getting the sequential blinkers to work. Any advice?
  7. May 23, 2023 at 8:58 PM
    1Tundra5
    Junior
    2015 White SR5
    I had to call Alpharex for help. it was a year ago so I don’t remember what they told me, unfortunately
  8. May 23, 2023 at 9:56 PM
    AdamK
    AdamK New Member
    Yes, I found it impossible to get decent performance out of my Alpharex Pros with LED lamps installed - I tried three or four different designs, all high quality lamps, installed in various orientations. I finally ditched the LEDs and installed some high wattage Hella halogens.
  9. May 24, 2023 at 10:35 AM
    1Tundra5
    Junior
    2015 White SR5
    In your opinion, are the halogens better for the pros?
  10. May 24, 2023 at 11:54 AM
    AdamK
    AdamK New Member
    Yes, that would be my opinion. From my perspective, LEDs in reflector housing are just a workaround and as with any workaround, your mileage will vary. The Pros were designed for halogens, so they naturally work better.
  11. May 25, 2023 at 10:11 PM
    1Tundra5
    Junior
    2015 White SR5
    Don’t your headlights come with a projector?
  12. May 26, 2023 at 8:22 AM
    AdamK
    AdamK New Member
    Yes, sorry I mis-stated - Alpharex Pros are (halogen) projectors. Projectors designed for the design of halogen lamps. LEDs in halogen projectors are a workaround, just as LEDs in reflectors are a workaround.
    Thanks for calling that out & getting it cleared up.
  13. Jul 18, 2023 at 6:19 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    I know I'm writing almost 2 months later but I have the alpha rex pro series headlights in my 07 and upgraded the old crappy halogen bulbs to gtr lighting 2.0 led bulbs. I think when I put them in they were facing 2 and 8 like the alpha rex employee stated and they work amazing I couldn't be happier. Not sure if the projector housing differs between the 07-13 year headlights and the 14-22's but if you guys are still wanting to upgrade I'd highly recommend gtr lighting.
    I can't remember if I had the high beams on in this photo but the high beams don't change the total volume of light bellow the projector cut off line anyways.
    I know they aren't the greatest pictures but I'll try to get another soon to showcase to you all if you even still care about the lighting on your trucks XD
    1Tundra5[OP] likes this.
  14. Jul 19, 2023 at 6:37 AM
    1Tundra5
    Junior
    2015 White SR5
    Has any moisture gotten inside the housing?
  15. Jul 19, 2023 at 7:07 AM
    Black Beauty 5.7
    Cannon
    Nope not at all. I’ve had them in there since the end of last summer and they’ve never given me any problems and with this nebraska weather we have lots of drastic changes in temperatures outside that usually results in the moisture buildup in headlights and tail lights but not these!
  16. Jul 19, 2023 at 8:07 AM
    1Tundra5
    Junior
    2015 White SR5
    I actually noticed some in mine, but might have been because I used a power washer.
  17. Jul 19, 2023 at 5:36 PM
    Black Beauty 5.7
    Cannon
    I'd recommend to just take off the cap on the back and check to make sure there's no dust or dirt on the rubber seal. I should say that I have had to replace my drivers side assembly before because I got a faulty assembly and my DRL went out but the customer service for alpha rex just sent me a new one that best matched the one I had. I think it shipped in like 3 days which was pretty nice.
  18. Jul 20, 2023 at 9:35 AM
    1Tundra5
    Junior
    2015 White SR5
    It’s was both, one more than the other.
