All weather tires for lifted truck?
Discussion in 'Wheels & Tires' started by reefcomber, Feb 14, 2019.
  1. Feb 14, 2019 at 3:54 AM
    reefcomber
    reefcomber [OP] New Member
    New England
    2018 Platinum
    Gathering information ahead of a desire to have a 3-4 inch lift on my 2018 truck. With regard to tires, I have a couple of questions:
    1) is there a lift height at which the stock tires will look awkward (I am not planning on doing any off-road driving)?
    2) is there a larger all-weather tire that will look more appropriate with that lift, and that will actually raise the chassis off of the ground to give more clearance?
    Mountun Goat likes this.
  2. Feb 14, 2019 at 5:19 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I had these on my 88 gmc 3/4 ton 4x4. Cant wait to put them on my tundra.prod_1391008012.jpg
  3. Feb 14, 2019 at 5:19 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    3" lift and 275/65/18 tires looks a bit akward. A 275/70/18 looks better. Look at the Michelin LTX tires, I am running the LTX AT 2's. 3" front lift, 1 1/2" rear and 275/70/18.
    Mountun Goat and TOYOTRD8 like this.
  4. Feb 14, 2019 at 5:32 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    2inch lift. 275/70/r18. Falken Wildpeak A3’s. 10 ply, snowflake rated. Awesome tire and best of all. Quiet on the road at speed. Sell locally for $230. Delivered to my door by Amazon for $160 each.
    36FE69BD-A911-450E-A144-DEF941A02CC3.jpg AB96031C-CBF8-465A-A13B-BEBF5E9A233D.jpg
    kparrow, Toothpick, onetohunt and 5 others like this.
  5. Feb 14, 2019 at 6:02 AM
    reefcomber
    New England
    2018 Platinum
    Searching across the Internet... I have the Platinum trim with stock wheels (20”) and I suspect that if I want to go with a sidewall with a bigger than 60% ratio, I may have to get new wheels. Does anyone know of a reputable manufacturer that makes a 20” tire with a higher than 60% sidewall?
  6. Feb 14, 2019 at 6:10 AM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    With no lift you can run 2 different types one for mileage one for traction.
    Stock no lift on my 2 Tundras. I just took the 20's off my new truck and put some 18's on. The 20's make for a rougher ride. Kind of like my runflat tires on my C-5 Vette. Mambo143 has a nice setup. Those would fit a stock setup.
    275/70/R18. 33"
    275/60/r20 .33"
  7. Feb 14, 2019 at 6:44 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'm currently leveled up front at 1.57" lift and nothing in the back; running the OEM Sport rims 275/55-20. It already looks awkward. LOL , My truck will have a 3" lift up front and 1.5" shackles in the rear. I will be running Falken Wildpeak AT3s 305/65-18 on 18x9 +25.
    Use
  8. Feb 14, 2019 at 7:20 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Personally, I'd dump the 20" rims. They make no sense on a truck (unless its lowered and setup for performance). 18" wheels will give you a better ride and be less expensive. Better yet, go 17" wheels for an even better ride and lower cost.
    As for the tires themselves, unless you don't care about mileage, I would pay a lot of attention to the weight of the tires you get. Falken Wildpeak's tend to be one of the heaviest tire in their class/size range. I wouldn't worry about Mountain Snow Flake rating unless you live in a area that gets a lot of snow. I would care more about wet traction as it doesn't matter where you are, you will be driving in rain. Look for tires that have unobstructed circumferential grooves (which most AT tires do not have).
    Considering all the factors (i.e. traction, performance, tread life, weight and cost), I think the Cooper AT3 XLT is the best tire out there for a daily driver that sees little offload work. I've run the non XLT version on my last two vehicles (Silverado and 4runner) and have been very pleased do that's what my Tundra will be get (the XLT version) when the time comes.
    Just my $.02
    Stormtrooper81 likes this.
  9. Mar 3, 2019 at 3:40 PM
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    3" toytec coil over lift
    Done, came to the same conclusion and put the on my 18 CM in 315-70RX17 on 6 speed ICON's. Love these tires
    Cooper's made in Ohio USA. Falkens made in Japan. Just sayin'
  10. Mar 4, 2019 at 5:11 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    Looks sweet man! How's the brake caliper clearance? What did you do lift wise and how's the ride?
    I just took my 4runner in over the weekend to for a tire rotation/balancing and the guy at the tire shop commented on how well the Coopers are wearing. I've got around 40k mi's on them and they still almost look new.
  11. Mar 4, 2019 at 6:15 AM
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    These wheels were made for the tundra so clearance is not an issue. I am leveled at 3/1 with toytec coilovers and rear 1" blocks. Ride is DRAMATICALLY better than the 295-60x20 set up I had on my previous tundra. And I love the tread/sidewalls
    SuperSilverTundra likes this.
  12. Mar 4, 2019 at 6:22 AM
    Loving my Cooper Discoverer ST Maxx, quiet on the highway too
    Pjholt and Stormtrooper81 like this.
  13. Mar 4, 2019 at 3:17 PM
    Woodtickmp
    Woodtickmp Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
    I'm running 295/70/ 17r Mickey tompson Baja atz p3 on mine with 3in in the front and 4in in the rear
    Pjholt and Sinkos like this.
  14. Mar 4, 2019 at 3:32 PM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    3" Kings suspension
    295/70-18 AT2 Toyo
    You're going to rub a little on the front (just a little )
    Stroke250, Pjholt and Sinkos like this.
  15. Mar 4, 2019 at 3:43 PM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
  16. Mar 4, 2019 at 3:51 PM
    Sinkos
    Sinkos Tuna slayer
    M
    Grey rw
    Toyo open country A/T’s are the best.
  17. Mar 4, 2019 at 5:28 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    I've found my Toyo Extreme A/T's lacking on wet roads. Very poor grip.
    Running Michelin Defender LTX M/S on the work truck which is a F-150 extended cab V8 4x4 with a couple tool boxes on the sides of the bed. The tires have been very good. Good traction for dirt roads and very good road manners wet and dry. I've heard they can be a bit rough in the back if you don't have any weight in the bed.
  18. Mar 5, 2019 at 5:14 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    :cheers:
  19. Mar 12, 2019 at 1:11 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    How are you liking the Wildpeaks? I'm considering the same tire next after a level (no rear lift) w/same wheels with a BORA 1.25" spacer. Thoughts?
    mambo143[QUOTED] likes this.
  20. Mar 12, 2019 at 1:30 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    Exactly same setup as me (I am running 1.25 SpiderTrax spacers). Love the tires. Great on road, dirt, snow, mud (so far). About 6k on the tires.
  21. Mar 12, 2019 at 2:01 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    What he said. They were fine with the 6112 level kit at 1.7. They rubbed the front mud flap thingy which I heated a little and bent forward. I love the tires. Great in snow here and quiet on the road. I hardly notice them. They are 10 ply and heavy but a real truck tire. Good for cornering.
    I am going to add wheel spacers this spring for a slightly wider stance and to add fender flares. It’s a lot of tire for the money.
  22. Mar 12, 2019 at 2:03 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    And... I think they look as badass as any AT tire I have seen
  23. Mar 12, 2019 at 2:57 PM
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    I like the Falkens, but I love the Cooper AT3 XLT's even better, and the fact that the Cooper's are made in Ohio USA vs the Falkens being made in Japan by Sumitomo sealed the deal for me. Just my $.02
    Rica25 likes this.
  24. Mar 12, 2019 at 5:58 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    I have been thinking about these coopers also however every picture I see there seems to be rocks stuck in treads? Is this just bad photo ops for the tire or me looking too hard
  25. Mar 12, 2019 at 6:08 PM
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    Well, I've been in the car business (service side) for 41 years and I have yet to find a tire, especially a truck tire, that especially when new, would not pick up some rocks. Especially when I just drove up my gravel driveway and parked...
    Joe Dirt likes this.
  26. Mar 12, 2019 at 6:33 PM
    Darren509
    Darren
    Dayton NV
    I realize that, I was inquiring about them being stuck in the treads. Every tire in the world picks them up
  27. Mar 12, 2019 at 7:09 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    I hate the BFG ko2's on.my truck now for this very reason! I feel like they somehow even pick up rocks on the opposite side of the road I am driving on. I always hear the sounds hitting the wheel wells and undercarriage of my truck and the paint chips on my trailer are sure signs to that they sling several.
  28. Mar 12, 2019 at 8:25 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I'm partial to ProComp A/T 10 ply's. No 10 ply rides better than a 6 or 8 ply tire that I have found... but if you drive in West Texas often, 10 ply is the only way to roll offroad. Those jagged rocks love to feast on tread and sidewall's.
  29. Mar 13, 2019 at 8:09 AM
    r1-superstar
    DB
    UTAH
    Right here!!! Falken Wildpeak AT3s!
    TOYOTRD8 and mambo143 like this.
  30. Sep 23, 2019 at 2:17 PM
    offroaddude
    offroaddude New Member
