ALL RESOLVED: Pop and lock wiring & blown fuses
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Oct 4, 2023.
  1. Oct 6, 2023 at 9:28 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    and there was also a 7 1/2 amp Blown on the inside
  2. Oct 6, 2023 at 9:29 AM
    shifty` In South Dakota Trouble ain't hard to find
    Weagle[QUOTED][OP] likes this.
  3. Oct 6, 2023 at 9:32 AM
    Weagle
    Prattville, AL
    ha ha if you only knew. almost every project I somehow manage to sabotage myself just a little bit
    I decided I’m gonna take on the timing belt job. Already ordered the parts recommended in the sticky thread.
    the only thing I haven’t done on other cars is actually pulled the old timing belt and put the new one on
    my only reservation is the self sabotage dragging out the timeframe
    shifty`[QUOTED] likes this.
  4. Oct 6, 2023 at 12:18 PM
    Weagle
    Prattville, AL
    Following up to say that I’m returning the product.
    I finally did get it installed correctly, however, it is very inconsistent and locking and unlocking the tailgate, which makes it a liability since you can’t trust that it is locked without checking it
    that was a waste of two days minimum I could’ve been doing something productive,
  5. Oct 6, 2023 at 12:21 PM
    Weagle
    Prattville, AL
    Looks like I will be pursuing this angle
  6. Oct 6, 2023 at 12:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not that I necessarily wanted you to find anymore, I felt as mentioned earlier that was one that should have blown given what circuits were out.
    Good luck on the timing belt project, plenty of folks here to lean on.
