All of the Dash Cam discussions in one thread.....
Discussion in 'Audio & Video' started by csuviper, Jun 29, 2018.
What Dash Cam do you use that you are extremely happy with?
  1. AUBBC
    0 vote(s)
    0.0%
  2. Blackvue
    40 vote(s)
    24.5%
  3. Blueskysea
    1 vote(s)
    0.6%
  4. Cobra
    3 vote(s)
    1.8%
  5. Conbrov
    0 vote(s)
    0.0%
  6. DDPai
    5 vote(s)
    3.1%
  7. DOD
    1 vote(s)
    0.6%
  8. G90 Ambarella
    0 vote(s)
    0.0%
  9. Garmin
    45 vote(s)
    27.6%
  10. Genius
    0 vote(s)
    0.0%
  11. Goluk T3
    0 vote(s)
    0.0%
  12. Mini
    1 vote(s)
    0.6%
  13. Mobius
    1 vote(s)
    0.6%
  14. NSV
    3 vote(s)
    1.8%
  15. Street Guardian
    2 vote(s)
    1.2%
  16. Thinkware
    27 vote(s)
    16.6%
  17. Vantrue N2 Pro
    9 vote(s)
    5.5%
  18. VIOFO A119S
    21 vote(s)
    12.9%
  19. Xiaomi Mijia
    1 vote(s)
    0.6%
  20. YI
    3 vote(s)
    1.8%
  1. Sep 11, 2021 at 5:54 PM
    #241
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I want it to keep power so it can catch someone if they run into to my truck when it's parked, lots of people I work with get there trucks damaged in the parking lots and since there are no cameras, they're out of luck. It's the thinkware, so it only turns on when the vehicle is bumped
  2. Sep 11, 2021 at 6:42 PM
    #242
    TundraTool13
    TundraTool13 New Member
    2020 Tundra Platinum
    Might want to think about investing in the extra battery that blackboxmycar sells to get constant power to your camera so you dont kill your battery.
    jmdaniel and Sumo91[QUOTED] like this.
  3. Sep 11, 2021 at 7:10 PM
    #243
    Sumo91
    TN
    How likely is it that the battery will run down in 12 hrs? I drive my truck alot and my battery isn't old. I've read the extra batteries are for people who don't drive everyday or log alot of miles on their vehicles
  4. Oct 4, 2021 at 4:51 PM
    #244
    Kawboykev
    Kawboykev New Member
    21 tundra mgm
    XB headlights
    Hi how did you wire in the hot fuse for the camera to operate when the truck is off with the smart box?
  5. Oct 4, 2021 at 4:55 PM
    #245
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I just used an add-a-fuse in the main fuse box (I believe it was one of the 12v cigarette lighter fuses). That circuit is only on when the truck is on, but you can choose one of the fuses that has constant power if you want the camera to operate while the truck is off.
  6. Oct 17, 2021 at 2:13 PM
    #246
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    @IowaGuy
    IowaGuy likes this.
  7. Nov 10, 2021 at 8:14 AM
    #247
    tUNDRAPILOt73
    tUNDRAPILOt73 New Member
    hAMMEr
    Track Tango
    2021 Crew Max TRD Off-Road Premium
    Installed viofo a129 pro duo in mine, all good using the hardwire kit to the fuses like @TxLock21 used, used the bracket from TDS for the rear cam. Hid the cables along headliner, behind airbags for both A pillars. Parking mode works as it should and overall cam is great. I set Voltage cutoff to 12.4 for the colder months...although, i have the Trickle charger installed so when plugged in at work for extended periods that will keep the battery above that so recording in low bit parking mode set to infinity, should cover the Tundra for those days. CCTV at home so covered there.
    Thanks to all the others before me that posted their experiences! Greatly helped me! Cheers from North of the 49th.
    omgboost likes this.
  8. Dec 16, 2021 at 2:57 PM
    #248
    WawaLunar
    WawaLunar New Member
    2021 TRD Pro Lunar Rock
  9. Dec 17, 2021 at 8:05 AM
    #249
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I got the regular so it sticks down a bit. 2+ years and it's been solid.
  10. Dec 17, 2021 at 3:32 PM
    #250
    WawaLunar
    Thank you! And thanks for the pic!
    Dang, it's $85 to ship that bracket to Canada
  11. Dec 19, 2021 at 2:28 PM
    #251
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    To those that use the Dongar mirror power adapter, does that supply constant power to your cam even with the truck off?
  12. Dec 22, 2021 at 3:49 AM
    #252
    yonquixote
    yonquixote New Member
    ‘21 TRD Pro CM Lunar Rock
    no
  13. Dec 22, 2021 at 1:43 PM
    #253
    SpyderRC
    SpyderRC New Member
    Ok, Thank you :thumbsup:
  14. Dec 22, 2021 at 1:54 PM
    #254
    Il0kin
    Il0kin New Member
    2012 Tundra
    I am using a Garmin Dash Cam Mini 2 and am pleased with it. Simple to use and very low profile. In retrospect I would maybe get a rear facing model, or I may add a second for my rear window.
    I wanted to get a model from a company I actually knew with a customer service number. I trust the no-name Chinese stuff about as much as a fart after chili dogs. Rather have something that actually went through an engineering and QA process - if I need the footage, I NEED it.
    AircareTundra likes this.
  15. Jan 6, 2022 at 2:37 AM
    #255
    LKROOZR
    LKROOZR New Member
    Christian
    2017 Black Tundra Crewmax
    8" readylift on 37s
  16. Jan 14, 2022 at 11:18 AM
    #256
    bwh
    bwh New Member
    Anyone who has permanently installed - what fuses did you tap for both full time power and acc power?
    I don't remember which ones I used, but came out to the truck fully dead this morning. Used the viofo install kit, and left the cutoff pretty high, but battery is dead. Confirmed no lights or anything was left on, and its a 2021 truck, so that leads me to believe I chose the wrong circuits.
    Since it's cold, I'd rather be armed with a better plan on fuses before pulling things apart.
  17. Jan 14, 2022 at 2:06 PM
    #257
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I need to order the add a circuits for my dash cam. The fuse box under the dash, does it have regular fuses or the minis?
  18. Mar 8, 2022 at 6:04 AM
    #258
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    What’s the general consensus on resolution? Should I be looking at 4K? Or is 1080 HD producing good image resolution? Looking at different thinkware models, their only 4k is the U1000
  19. Mar 16, 2022 at 12:59 PM
    #259
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I just got the blackvue 900xplus 2channel 4k and with the lte module...amazing. ran 40 ft of cable to back window in my cap and it turned out great...picture quality everything is fantastic along with cloud feature, live view and tmobile hotspot.
  20. Mar 16, 2022 at 3:28 PM
    #260
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    The only thing wrong with it, it will drain your battery regardless of the software installed....software is shitty.
  21. Mar 16, 2022 at 3:30 PM
    #261
    The bad thing about the U1000 is that it permanently mounts to the windshield.
  22. Mar 16, 2022 at 3:35 PM
    #262
    dkrou
    dkrou New Member
    dan
    2019 tundra
    you have no clue as to what your talking about...this one you can set for 6 hour shut off or it has auto voltage shut down so you dont drain yr battery.
  23. Mar 16, 2022 at 3:40 PM
    #263
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    there are certain dashcams that will turn off after a certain voltage drop. I've been using my thinkware for a while like this, it connects to an ignition on source and constant so it can go into "parking" mode.
  24. Mar 16, 2022 at 4:36 PM
    #264
    GWill
    Willis
    2020 MGM TRD Pro
    Oof, yeah thats gonna be a no from me, dawg.
  25. Mar 16, 2022 at 4:41 PM
    #265
    angkorstrong
    I used one of those mirror mounts for radar detectors to mount mine
  26. Mar 16, 2022 at 4:44 PM
    #266
    GWill
    Willis
    2020 MGM TRD Pro
    How long before it shuts down? Im wondering if there is a set up where camera runs off a battery pack, then truck battery with shutoff based on voltage drop
  27. Mar 16, 2022 at 5:12 PM
    #267
    angkorstrong
    blackvue has a batterybox that u can purchase but at that price ur better off with a bigger battery. Im not sure how long it cuts off, mine doesn't cut off cus I have a solar panel wired to trickle charge the battery but it last overnight also.
  28. Mar 16, 2022 at 6:15 PM
    #268
    Roborob70
    Robert
    I do know what the hell I'm talking about, over the course of a month had it at different settings, even had to get a new battery because it kept draining my battery regardless of settings....otherwise its a good camera. software is junk.
  29. Mar 17, 2022 at 6:35 AM
    #269
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Mine shuts off no problem...have no idea what you are experiencing. I have an AGM battery too which probably helps.
  30. Mar 17, 2022 at 7:19 AM
    #270
    Roborob70
    Robert
    I'm not a very good artist !
