All of the Dash Cam discussions in one thread.....
Discussion in 'Audio & Video' started by csuviper, Jun 29, 2018.
What Dash Cam do you use that you are extremely happy with?
  1. AUBBC
    0 vote(s)
    0.0%
  2. Blackvue
    40 vote(s)
    24.5%
  3. Blueskysea
    1 vote(s)
    0.6%
  4. Cobra
    3 vote(s)
    1.8%
  5. Conbrov
    0 vote(s)
    0.0%
  6. DDPai
    5 vote(s)
    3.1%
  7. DOD
    1 vote(s)
    0.6%
  8. G90 Ambarella
    0 vote(s)
    0.0%
  9. Garmin
    45 vote(s)
    27.6%
  10. Genius
    0 vote(s)
    0.0%
  11. Goluk T3
    0 vote(s)
    0.0%
  12. Mini
    1 vote(s)
    0.6%
  13. Mobius
    1 vote(s)
    0.6%
  14. NSV
    3 vote(s)
    1.8%
  15. Street Guardian
    2 vote(s)
    1.2%
  16. Thinkware
    27 vote(s)
    16.6%
  17. Vantrue N2 Pro
    9 vote(s)
    5.5%
  18. VIOFO A119S
    21 vote(s)
    12.9%
  19. Xiaomi Mijia
    1 vote(s)
    0.6%
  20. YI
    3 vote(s)
    1.8%
  1. Apr 5, 2019 at 8:36 AM
    #61
    Pip395
    Pip395 New Member
    Albuquerque, NM
    2017 Toyota Tundra Platinium
    6” lift, 35x12.50x20 Fuel Rims, Cooper Discoverer SST Pro’s, Rick sliders, 6” extended steel braided brake lines, rotor & brake upgrade, Flowmaster Outlaw Exhaust, icebox intake, Rigid hood Pod lights
    I have this set up in my CM. The front is mounted in front of my mirror so it is out of sight and obstruction. A must in order to be legal to drive on base as they will get you for hanging an air freshener from your mirror. The rear camera I ran the wires down through the door sills and then up behind the seat. I mounted the actual rear camera using the sticky pads to the hard plastic where the seat belt comes out of the rear seat. Been working great for almost a year now.
    TxLock21 likes this.
  2. Apr 5, 2019 at 9:11 AM
    #62
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Never had a single issue at all going back and forth on base with my front cam mounted in the front windshield. I work on base. Retired military as well. Most of the time there are nothing but young kids working the gates.
  3. Apr 5, 2019 at 9:17 AM
    #63
    G10dra
    G10dra Not a New Member
    Alamo2016TSS likes this.
  4. Apr 5, 2019 at 9:28 AM
    #64
    Pip395
    Pip395 New Member
    Albuquerque, NM
    I never had an issue on any other base except here at Kirtland. There is actually an AFI about it that I had them find and point out to me cause I was arguing bout how stupid it is.
  5. Apr 5, 2019 at 11:59 AM
    #65
    TundraTSS19
    San Antonio, TX
    I see. May also depend on who is working the gate and is really looking for dash cams. Lackland, Randolph, Fort Sam Houston and Camp Bullis don't care.
  6. Apr 11, 2019 at 9:45 AM
    #66
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    How'd you mount this?
  7. Apr 11, 2019 at 10:53 AM
    #67
    TundraTSS19
    San Antonio, TX
    It's just been mounted with good 3M double side tape. Been there since I got the truck 5 months ago and has never fallen off. If also see some people get a small piece of aluminum and bend it into an L shape and screw it through the liner and mount camera that way.
  8. Apr 11, 2019 at 11:13 AM
    #68
    cooper4x4
    2016 Tundra SR5
    Don't want to drill through the headliner. Does the camera move around and create shaky video?
  9. Apr 11, 2019 at 11:17 AM
    #69
    TundraTSS19
    San Antonio, TX
    None at all
  10. Apr 11, 2019 at 12:03 PM
    #70
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
  11. Apr 11, 2019 at 2:38 PM
    #71
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    Vantrue T2. Love it. Been with Vantrue for 4 years now. Never had issues with the camera itself. Once I cut the charging cable by accident after having the camera over a year. Customer Service sent me a brand new charger free of charge. Window mount got weak, again..sent me new one free of charge.
    McYoda, GELCW and TxLock21 like this.
  12. Apr 29, 2019 at 10:41 PM
    #72
    Alamo2016TSS
    Alamo2016TSS New Member
    BW
    2016 Red TSS
    TundraTSS19: where is your power cord? How is it routed? Thanks.
  13. Apr 30, 2019 at 5:52 AM
    #73
    TundraTSS19
    San Antonio, TX
    I have a battery back up behind the left foot kick panel that is wired through fuse taps (ground, 12v+, 12v accessory). From the battery backup it has a 12v cigarette plug that the camera system plugs into and I just routed the rear wiring across the edge of the headliner and seal. I did the same thing for the front camera. Routed wiring across the top headliner to the mirror cap. The battery back up is specifically for dash cams. It's a fast charge and charges when the truck is running and then powers the camera system when I shut it off. Regular battery packs aren't built for this as they don't support pass through charging.
    Alamo2016TSS[QUOTED] likes this.
  14. May 1, 2019 at 6:15 PM
    #74
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Bringing the thread back to life.
    I'm getting the Vantrue N2 Pro suction mount for the rear and the Viofo A129 single for the front.
    Here is my idea.
    With the Vantrue N2 Pro point front cam to the rear and the rear cam point to the front, I can attach it to the window with the suction in case i need/want to run the window down (not while parked)
    I can get a semi park mode in rear and sides.
    Mount the A129 at the rearview point front and get ok parking mode for the front.
    This should cover me, I think.
    What do y'all think?
    GELCW likes this.
  15. May 1, 2019 at 6:58 PM
    #75
    TundraTSS19
    San Antonio, TX
    Not making any sense at all. The Vantrue is meant to be a rideshare camera. It doesn't have parking mode so that is useless. As far as the A129, it doesn't have true parking mode either. You have to manually turn it on for it to work and if you want that to work, it has to be hardwired. My opinion is poor choice. A suction mount as well for the rear window doesn't make sense because you have to remember to remove it just to roll the window down
  16. May 2, 2019 at 3:34 PM
    #76
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    After reviewing a little more I'm getting the Blackvue DR900S-2CH-IR. The IR will go on the back window facing forward to catch side views and maybe even a bad cop, who knows.
    And Im getting the Blackvue DR900S-1Ch for the back window facing to the rear.
    Both will be hard wired
    The DashCam Store has a cool Tundra rear window mount
    LKROOZR, theraven and Bongskie like this.
  17. May 2, 2019 at 4:35 PM
    #77
    TundraTSS19
    San Antonio, TX
    DR750 performs better and low light than the 900. The 900 has also had overheating issues due to the the 4k processor 1080p is still great quality and the 750 is cheaper. If you want to even take advantage of the parking mode the Blackvue has to offer, you're either going to need a voltage regulator or a battery backup such as a cellink or Blackvue backup
  18. May 2, 2019 at 6:28 PM
    #78
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    :thumbsup:
  19. May 9, 2019 at 3:15 PM
    #79
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Got these in, confused me at first but i got it.
    Drop the top window rubber and then it all makes sense.
    The window is free to operate as designed.
  20. May 10, 2019 at 11:29 AM
    #80
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Update.
    The rear window bracket does good on smaller cams.
    If you have a larger cam, it will bounce, a lot.
    I cannot recommend this bracket for a large cam.
  21. May 20, 2019 at 6:31 AM
    #81
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
  22. Jul 18, 2019 at 8:32 AM
    #82
    2019_Sport_4×4
    2019_Sport_4×4 New Member
    Jeff
    UPSTATE South Carolina
    2019 Black Tundra Sport 4x4
    Rough Country 3" Lift 20" XD Misfits Micky Thompson Baja 305/55/20
    Hey Guys I just ordered this Dash Cam. Do you guys have any feed back on if you like it or not? did you hard wire it? Dash Cam.jpg
  23. Jul 18, 2019 at 8:46 AM
    #83
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I can't speak to that particular dash-cam, as I am running a kenwood cam directly to my head unit. However, in our RV I have a usb powered dash-cam that I hardwired using this kit. I don't like wires hanging around everywhere. I wired it to the fuse box, but I considered wiring it to a dome light, but I didn't want to mess with the tiny wires up there.
  24. Jul 18, 2019 at 9:37 AM
    #84
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  25. Jul 18, 2019 at 9:42 AM
    #85
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I just got my A119 v3 yesterday (Prime deal) and have been playing with it a little bit. Will hardwire this weekend when I get my fuse taps. I will probably switch over to the A129 duo 4K comes out as well and put the other in my daughters 4Runner.
    JoshuaA[QUOTED] likes this.
  26. Jul 18, 2019 at 9:50 AM
    #86
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Nice! I'm using a A119 right now
  27. Jul 18, 2019 at 9:51 AM
    #87
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    There’s 549 people who apparently have feedback on whether or not they like it
  28. Jul 18, 2019 at 9:55 AM
    #88
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I need a dash cam but can’t mount on my windshield because of my tint. What options do I have?
  29. Jul 18, 2019 at 10:13 AM
    #89
    greener
    greener New Member
    2019 TRD off-road MBM
    I’m using an action cam I had laying around for now. Makes going for groceries feel like I’m doing something extreme lol 3C7D7F77-5367-416F-8040-4A383D98F7F6.jpg
  30. Jul 18, 2019 at 10:18 AM
    #90
    BobaChris
    BobaChris New Member
    2017 Cement Grey Tundra TRD Pro
