All dash lights went out at the same time
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra-Tom, Sep 14, 2018.
  1. Sep 14, 2018 at 11:19 AM
    Tundra-Tom
    Tundra-Tom [OP] New Member
    All dash lights went out at the same time, except for gear selector, radio, clock, recycle air button and cargo light button.
    I checked ALL the fuses and they are okay. I did notice the gas gauge light went out about two months ago but thought nothing of it. What should I check next?
    I have also noticed that the high beams do not work when turned on; however, they do work when the turn indicator is pulled, then they go off when the indicator is released. The driving lights do not work either.
    I know it’s an old truck, but this is the first problem I have had with it. IT'S AN AWESOME TUCK. Great job Toyota!
    Any and all suggestions as to what to check or replace are welcome.
  2. Sep 14, 2018 at 11:20 AM
    COMiamiFan
    COMiamiFan Wanna pet my Woobie?
    Jose
    Parker, CO
    2016 White Crew Max TRD
    Welcome from CO and sorry for your troubles. Experts will chime in.
  3. Sep 14, 2018 at 11:27 AM
    because_wumbo-truck
    because_wumbo-truck TTC #036
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    3rd gen taco TRD OR wheels, flowmaster 44, LEDs and stickers
    Maybe a bulb came loose? If even one bulb was missing from the main gauge cluster on my Tacomas, the entire cluster would lose power because the circuit was broken.
  4. Sep 14, 2018 at 11:36 AM
    Twinky
    07 double cab work horse
    Custom speed dent. Saving up for matching driver side speed dent.
    Some vehicles do have odd warning features similar to what you described. The handful ive come across it was a tail light/blinker/driving lights had burnt out.
    Nissan altima was one of them. Blinker i think. Either way, its one messed up way to tell you a light burnt out. Since one is out, lets turn all the inside ones off too!.
    Seriously, it may be something simple. Like a parking light, or the headlight/highbeam issue you mentioned.
  5. Sep 14, 2018 at 11:59 AM
    Tundra-Tom
    because_v8 Are you suggesting that I take the instrument cluster out and make sure each bulb is seated correctly?
  6. Sep 14, 2018 at 12:01 PM
    Tundra-Tom
    Twinky -- Turn signals, parking, high & low beams all work. If there were a bulb problem, it would be apparent, right?
  7. Sep 14, 2018 at 12:11 PM
    Twinky
    Yeah, it should be. It might not be about your lights but it may still be something minor.
  8. Sep 14, 2018 at 12:15 PM
    Twinky
    I hate to ask, but i gotta just incase.
    You have definitely checked the dimmer switch?
    Check and see if a penny or something lodged its way in to a cigarette lighter. Never know.
  9. Sep 14, 2018 at 12:37 PM
    Tundra-Tom
    Twinky -- Dimmer was the first thing I checked. I do have a phone charger in the cigarette lighter, let me pull it and see if that might be creating a short. I will also unplug and replug all the lights on the truck. One might be loose.
  10. Sep 14, 2018 at 12:39 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Check the wiring connectors while you're in there to see if one or more has come loose and is maybe corroded.
  11. Sep 14, 2018 at 12:51 PM
    Twinky
    I know you checked your fuses but for reference, or anyone else, heres a pic of the fuses to check first.
    Pretty sure thats the right gen.
  12. Sep 14, 2018 at 12:56 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Do you park your truck outside? Even if you don't, there could be mice or chipmunks getting into your truck and chewing wires, I had some problems with them last winter.I set traps inside the truck and caught 3 mice in 1 week!
  13. Sep 14, 2018 at 2:15 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    As a last resort. Then again you said one bulb went out first so you gotta replace it anyway
  14. Dec 17, 2018 at 3:30 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Probably a relay fuse OR just the instrument fuse since all the lights went out at same time. Or, a chewed loose wire or bad ground. OP you get this fixed?
