Alingment issues with Icon UCA and ICON coilovers, Tie Rods Bottomed out
Discussion in 'Suspension' started by GTABurnout, Feb 6, 2017.
  1. Feb 6, 2017 at 12:52 PM
    GTABurnout
    GTABurnout [OP] New Member
    Quick run down. Installed a set of 2.5 CDC Icon Coilovers along with some Icon Uniball UCA.
    Ran the set up for a while no issues but noticed some bad inner tire wear so took it back thinking I mush have hit something and messed it up. I am good friends with the manager of the shop. That did the alignment.
    We threw it back on the rack to check it out. Looks like the issue seems to be in the adjustment portion.
    We can't get the truck to the recommended 0 degrees of camber without having the toe go way out. Then when bringing the toe in we ran in to the tie rods being bottomed out. So no more toe adjustment.
    I have a call in to Icon to see if they have ever had this issue. Haven't gotten a call back yet. I will update with what they say.
    My first thought was I need to lift the truck more (preload the coilovers). We mimicked that by using the air jack on the rack to lift the front of the truck a little to see if anything got better. It didn't. So for now I have a 1.5 or so of negative camber in the front to allow me to have the toe in good shape to protect my tires for now.
    Has anyone ran in to this? Do I need to cut down the inner tie rods? Is something off that I am missing?
    Thanks
  2. Feb 6, 2017 at 3:15 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We install these all the time and have never had any issues. Let me see if I can find an alignment sheet to a similar truck to give you some numbers. How much lift are you running? What size tires?
    Beesta, papasmurf and Cisko213 like this.
  3. Feb 6, 2017 at 3:28 PM
    TheBeast The Beach
    sub'd
  4. Feb 6, 2017 at 3:50 PM
    Vizsla
    Vizsla 2 = 2.5
    Can you post a picture of your alignment cams? I know someone with the same setup, and it aligns and works perfect.
  5. Feb 6, 2017 at 4:32 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Been trying to figure out what does that mean?
  6. Feb 6, 2017 at 4:33 PM
    TXMiamiFan
    Jose
    @jberry813 knows his shit. He might have some insight also.
  7. Feb 6, 2017 at 4:36 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Subscribed to the thread
    TheBeast likes this.
  8. Feb 6, 2017 at 4:39 PM
    TXMiamiFan
    Jose
    Got it. Thanks.
  9. Feb 6, 2017 at 4:48 PM
    TheBeast The Beach
  10. Feb 6, 2017 at 6:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Subbed
  11. Feb 6, 2017 at 6:43 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Funny thing Jose..........I never knew what it meant either. Now I do.
    TXMiamiFan[QUOTED] likes this.
  12. Feb 7, 2017 at 8:12 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    ICON tube UCAs or the billet ones with heims?
    No offense to you or your alignment guy, but I've met a lot of people that can't align a truck for shit. Can you take some pics of the eccentrics?
    dcsleeper408 and TheBeast like this.
  13. Feb 7, 2017 at 12:06 PM
    GTABurnout
    So talked with Icon guys for a few yesterday. Looks like they recommend lifting the front a little. I guess if the front is not lifted enough you will run in to this issue. I had the coilovers installed at the height they were shipped as.
    I will grab a pick of the settings as well. No point in ignoring helpful advice.
    Thanks guys.
    Beesta and TheBeast like this.
  14. May 16, 2017 at 9:02 AM
    GTABurnout
    So still fighting this. I have upgraded to total chaos cab tabs since I had a cam tab fold over on me during the alignment.
    What specs should a 3" lifted truck go for? I am having bad tire wear on the fronts. The outer edges are feathering pretty bad. truck drives fine. Just bad tire wear.
    Any help would be appreciated.
  15. May 16, 2017 at 9:36 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I've had these issues at the shop before and I usually end up swapping them to Camburgs. Icons are a very nice uca but I've had to swap a few due to alignment issues. Don't seem to have quite the right amount of adjustment for a 3+ inch lift on 35's, usually caster suffers. I do em on bilstein 5100 and fox 2.0 and never have a issue. Then again that's on 305/55/20 or 285/65/18 tires.
    With your issue I've had to shorten the tie rods to get the alignment perfect and tracking correctly
  16. May 16, 2017 at 9:36 AM
    joem1cha3l
    Albany, NY
    Super helpful info Tommy! Thanks
    TheBeast and Hattori[QUOTED] like this.
  17. May 16, 2017 at 9:39 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    No problem boss!
  18. May 16, 2017 at 9:50 AM
    Vizsla
    Vizsla 2 = 2.5
    It is hard to find a good alignment, so I do it myself. This is what ended up working best for me.
    Camber L -0.1 R -0.1
    Caster L 3.9 R 4.1
    Toe 1/8 toe in
    This will be almost no irregular wear, but the outside edge will always have a little more wear, it is a by product of making it drive straight.
    831Tun likes this.
  19. May 16, 2017 at 9:58 AM
    sdhq_offroad
    GILBERT, AZ
    Alignment specs will vary vehicle to vehicle because they aren't all the same. Might be ballpark, but not exact.
  20. May 16, 2017 at 1:35 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  21. May 16, 2017 at 2:15 PM
    GTABurnout
    That's what I am leaning towards. But that's an expensive swap with out knowing if its going to solve it.
    See the camber is always an issue. Its always negative. Almost a degree I believe. I honestly think the Icon arms are the issue never had this issue with stock arms and the spacer lift that was on it before.
    That's true. But there has to be a preferred spec to aim for. What is that spec? You can't just say make it drive straight and call that the spec.
    Thanks for all the input guys. The truck drivers great its just starting to feather the tires pretty bad.
  22. May 16, 2017 at 2:46 PM
    Vizsla
    Vizsla 2 = 2.5
    This is exactly what you want
    Camber - 0.0 degrees, I go -0.1 because tire wear is more important than feel.
    Caster - at 3" lift with big tires I like 3+ degrees with .3 degrees more on the right, i.e. L 3.0 R 3.3. Your arms control this number, stock allows 2 degrees, it would be ok, but not have good manners.
    Toe - .07 per side for total of .14
  23. May 16, 2017 at 8:16 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Following!
  24. Mar 27, 2018 at 9:13 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    So I am having the same issue. I added Camburg Uniball uca. I know they add a lot of caster but still should be able to align in spec and drive normal right?
    I got the numbers close but Caster is still high with the tie rods maxed out! Plus it just doesn’t feel right when turning full lock. Drives nice besides the steering wheel feeling like it’s going to rip out of my hands when turning.
    My next move was going to be trim down the tie rod ends but seeing what else I can find before doing that.
    Here are my final numbers. Lowest The shop could get the caster.
    Full lock at normal ride hight also is too damn close to the coil. Why would Camburg make arms with this much Caster!?
    dcsleeper408 likes this.
  25. Mar 27, 2018 at 10:44 PM
    TheBeast The Beach
    sell them. buy some TC. You are not the only one who had issues with this particular UCA.
    You could try another shop for alignments first though.
  26. Mar 27, 2018 at 11:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    IMO this is completely normal for Camburg UCA and I think 6* is a little too much, again just my opinion. I'm having similar issues but the other side of the coin, not enough caster and poor camber #s with Icon. I'm switching to MCM UCAs when Matt gets some more made. You should be able to get proper camber and about 4* of caster with his UCAs.
    joonbug and TheBeast like this.
  27. Mar 28, 2018 at 6:35 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Subbed for future reference
  28. Mar 28, 2018 at 6:50 AM
    blizz86
    blizz86 New Member
    I have camburg uniballs too with similar numbers but it drives great only my tires rub the uca, at full lock, because of my tire width and wheel specs.
    -.6 degrees camber on both sides with 6.7 degrees of caster and .07 degrees toe each side..
    Camber purposefully makes their arms have aggressive caster and slightly negative camber for more aggressive driving and to combat outter tire wear common with tires with big lugs. Mine tracks straight aside from road crown and has good steering feel.
    Getting new wheels in June, hopefully, that should be perfect with my setup.
  29. Mar 28, 2018 at 8:18 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've read about swapping tie rods side for side to get more clearance at the shock perch?
  30. Mar 28, 2018 at 8:22 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    @joonbug and I have the same UCAs and similar #s. I'm running coachbuilder tie rod ends and still can't get the camber right. -1.3* is the best they can get.
    joonbug likes this.
