Alignment
Discussion in 'Suspension' started by Sterlinglwood, Jun 12, 2018.
  1. Jun 12, 2018 at 3:55 PM
    Sterlinglwood
    Sterlinglwood [OP] Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Just took my truck in to get the alignment done. The guy tells me the rear passenger side bolt has seized up and needs to be cut off. They can’t get a new bolt from Toyota until tomorrow. Have any of you had this kind of issue before?
  2. Jun 22, 2018 at 6:05 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    It's not common, but it does happen if gunk gets in there
  3. Jun 22, 2018 at 6:26 PM
    ninjajay
    Spoolston, TX
    Oh damn I didn't read the year, that's gotta be a factory defect or something
  4. Jun 22, 2018 at 6:26 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    The shop was indirectly trying to say I tightened up the cam side instead of the nut side and that’s why it got galled. I know better and they took the hit for $27 adjustment bolt. The bolt had to be cut off. Worked out ok in the end.
    4x4_Angel likes this.
  5. Jun 22, 2018 at 6:29 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    The dude said it was common on Toyota which I wasn’t falling for. You could almost eat off of any part on my truck before the build...
    Watt maker and 4x4_Angel like this.
  6. Jun 22, 2018 at 9:20 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    You live in Cali. 93 hondas still look new out there lol. In New England all day.
    Which im going there next week to visit family
  7. Jun 22, 2018 at 10:17 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Everything looks good out here until you live here. A visit will be enough..
  8. Jun 23, 2018 at 2:28 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    I use to live in Garden Grove I know what its like. I miss the food
  9. Jun 23, 2018 at 11:01 PM
    250rdave
    250rdave like I told the guy on ABC DANGER IS MY BUSINESS
    David
    surprise az
    2014 blue trd dbl cab
    Borla cat back Airraid cai raptor grill pro comp at sport
    When I installed my lift kit on my 2014 with only 7500 miles on it the dr side rear felt like it was cross threaded when it was installed. The threads were all tore up when I finally got the nut off. I could not get the nut to move with my impact gun. I had to remove it with a breaker bar. I had no problem with the other ones.
    Sterlinglwood[OP] likes this.
