Alignment vs. Steering Wheel
Discussion in '1st Gen Tundras (2000-2006)' started by jpink, Apr 14, 2025.
  1. Apr 14, 2025 at 5:33 PM
    jpink
    jpink [OP] Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    I cannot find the thread, but I am certain I read something...somewhere about the advice when steering wheel is maybe not center dead on and you need an alignment.
    I removed the steering wheel at one point to swap out the stalk for foglights and I'm somewhat confident I got it back on exactly how I took it off but I'm no longer certain.
    Should I
    • Drive the truck straight into a parking spot (wheel "crooked") and then reposition the steering wheel....or....
    • Leave it alone, get the alignment, futz with it after?
    xoxo @FirstGenVol is a ho
    bmf4069 and FirstGenVol like this.
  2. Apr 14, 2025 at 5:52 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If you pulled the steering wheel without doing anything for the suspension/steering and it's now off. Then you can just pull and reposition. It's probably just 1 spline off.
    jpink[OP] likes this.
  3. Apr 14, 2025 at 5:55 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    This. It's the only way to know. Especially if you're not sure that you got it right.
    When was the last time it was aligned?
    jpink[QUOTED][OP] likes this.
  4. Apr 14, 2025 at 7:19 PM
    jpink
    Knoxville
    August 2021 during the suspension job. We couldn't get center bolt back in the steering rack and I've been driving it that way since. Finally got everything all fixed with that, bolt back in all proper, and need an alignment.
  5. Apr 14, 2025 at 8:10 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Agreed.
