Alignment thought
Discussion in 'Suspension' started by hartebreak, Dec 13, 2017.
  1. Dec 13, 2017 at 10:51 AM
    hartebreak
    hartebreak [OP] New Member
    2017 Tundra Doublecab
    So last weekend I put my toytec 3/1 lift and TC uca on my 2017 DC. I had it aligned yesterday at a local shop that does alot of lifted trucks. The tech and I shot the craps for a bit about the lift, the UCA upgrade, which he said was a great choice. Anyhow, when we were on the subject of caster, I asked for him.to get as much caster as he could without sacrificing camber. He said that he doesn't buy into that thought process as many "keyboard warriors" suggest. He prefers to go between 3.2-3.6 of caster. The reason he gave is, that if you go more than 3.6, the amount of positive and negative camber during turns will cause bad cupping of the tires. His conclusion is 3.5-ish is the best compromise between stability and tire wear. My truck drives pretty much just like it did before the lift, no vague feeling like before the alignment. What are your thoughts?
  2. Dec 13, 2017 at 1:12 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    He is correct. If you are concerned about tire longevity. The more caster you get, when you turn, you gain negative camber. Good for handling and sports car etc but bad for the tires.. so its a give an take. If you only drive straight, the you will never see it.. turning is a different story. He sounds like he knows what he is talking about, I would trust him.
    Vizsla and Sunnier like this.
  3. Dec 13, 2017 at 1:35 PM
    COMiamiFan
    COMiamiFan SSEM #3. Don't forget to try the search bar. #PSL
    Jose
    Parker, CO
    2016 White Crew Max TRD
    For folks like me who had no idea about this.
    Learn something new on this forum. Tundras.com FTW.
    RMFTundra and Sunnier like this.
  4. Dec 13, 2017 at 1:45 PM
    COMiamiFan
    Jose
    Parker, CO
    My only question is that isn't the caster already predetermined by the engineers/factory? So why would a tire place want to or need to adjust the caster?
  5. Dec 13, 2017 at 2:28 PM
    Vizsla
    Vizsla New Member
    Dave
    Arizona
    2018 Cement Crewmax
    No caster is adjustable. The upper ball joint is fixed, the lower control arm goes in/out-adjusting camber, forward/backward adjusting caster. Lift, upper control arm, centering wheel in wheel well all play a factor in caster settings once lifted.
    COMiamiFan likes this.
  6. Dec 13, 2017 at 2:30 PM
    hartebreak
    because when you lift a truck by cranking the control arms, it changes the camber, then when the alignment person corrects the camber, it comes at the expense of the caster. Robbing Peter to pay Paul type of thing.
