Alignment / speedometer tuning
Discussion in 'Performance and Tuning' started by Funky_Chef, May 1, 2023.
  1. May 1, 2023 at 5:35 AM
    Funky_Chef
    Funky_Chef [OP] New Member
    Andrew
    2019 limited
    I was wondering if I need an alignment and if I need my speedometer adjusted after I install a leveling kit?
  2. May 1, 2023 at 5:40 AM
    centex
    centex New Member
    Alignment yes. Speedometer only if you went with bigger tires and even then, not a big deal if you don’t.
  3. May 1, 2023 at 9:26 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    weirdly, my speedo went 3 mph off after lowering the truck, same stock wheels/tires. Would consistently read 45 on speedo, when radar signs clocked me at 42mph
  4. May 1, 2023 at 10:36 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    your stock speedo is probably actually off by +2 mph directly from the factory, so actually going up to 33" tires from the stock 32" size will bring it closer to true speed.
  5. May 1, 2023 at 12:13 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    You sound like a bot...? It's a certainty that it will effect alignment... on a Tundra by a lot.
