alignment specs
Discussion in '1st Gen Tundras (2000-2006)' started by dboytheman, Nov 23, 2022.
  1. Nov 23, 2022 at 7:58 AM
    dboytheman
    dboytheman [OP] New Member
    Dany
    2006 Tundra accessCab 4x4 v8 HD
    A lot lol
    Hey guys
    Im new here.
    Cant seem to find a straight answer,
    I've got a Approx 2in lift with dobinsons struts and JBA upper control arms, Im wondering what caster spec did other JBA uca users has set caster to??
    Jba says around +3deg but i find my truck to be quite unstable on the highway. Everything suspension part is new in the last year and alignment was done twice.
    Im on 285/70r17
    Thanks!
  2. Nov 23, 2022 at 10:22 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    How fast are you going on the highway?
  3. Nov 23, 2022 at 10:25 AM
    dboytheman
    Dany
    A lot lol
    60mph-65. but the symptom is there even slower but its not as disturbing lol
  4. Nov 23, 2022 at 10:58 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What are your current alignment specs? Also, have you replaced the steering rack bushings?
    Any other non-oem parts specifically alignment cam bolts or lower control arms?
  5. Nov 23, 2022 at 12:22 PM
    dboytheman
    Dany
    A lot lol
    bearings and LBF are oem, Uca and Upper BJ are JBA, tierods are non oem, LCA are oem with moog bushings and cambolts, rack n pinion bushings has been replaced a month ago with moogs.
    Alignments specs are stock except for caster at 2.8, originally it was set at 3.6 with the jba and got it down hoping it would help me out, but did not make a difference.
    Only parts that were not replaced, are inner tie rods and rack n pinion but I cant find any play in them.
  6. Nov 23, 2022 at 1:07 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    What's the toe set to? You probably want about .15-.25 total toe-in.
  7. Nov 23, 2022 at 4:50 PM
    shifty` All my rowdy friends have settled down
    Alignment info you probably want is in this thread. Check the suspension section. Straight out of that guy's ^^ finger.
  8. Nov 23, 2022 at 4:58 PM
    dboytheman
    Dany
    A lot lol
    That, my friend, was helpful lol thanks a f***** lot :D
  9. Nov 23, 2022 at 7:32 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Do you have your alignment print out?
    Most around here will suggest always sticking with OEM Steering and Suspension Components.
  10. Nov 23, 2022 at 7:35 PM
    Not only that, but Moog had that big recall on their lower control arms, premature failure.
    Diablo169[QUOTED] likes this.
  11. Nov 24, 2022 at 4:56 AM
    dboytheman
    Dany
    A lot lol
    yeah well lower control arms are oem but with moog bushings lol Its going into the shop to check everything. I just cant properly check suspension by myself on the floor lol plus its getting cold... Ill look into the alignment specs and report later.
    shifty`[QUOTED] likes this.
