Alignment specs for leveled tundra
Discussion in 'Suspension' started by Srice80, Apr 5, 2017.
  1. Apr 5, 2017 at 3:31 PM
    Srice80
    Srice80 [OP] New Member
    2013 magnetic grey rock warrior crew max
    I have a 2013 rock warrior crew max, just did a 3" leveling kit, alignment was done to factory specs and the camber is still off and wearing tires. Anybody have any suggestions? Thank you
  2. Apr 5, 2017 at 3:37 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Get some upper control arms to fix it. Camburg , total chaos or spc.
    Backslider likes this.
  3. Apr 5, 2017 at 6:59 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I also recovered lost fuel economy after getting Zone Off-road UCAs to correct my caster after a 3/1 coilover level.
  4. Apr 5, 2017 at 7:18 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Umm....I've seen this thread before....
  5. Apr 5, 2017 at 7:24 PM
    Backslider
    Tooele, UT
    Sorry, you said Camber....
    Your camber shouldn't be off. If so there is something wrong with the level or the alignment. Caster should be the only thing that's tough to get in spec.
    joonbug likes this.
  6. Apr 7, 2017 at 12:18 PM
    Srice80
    Right, if your caster is off you have some structural damage. Camber was way off so was the toe, so far everything that has to do with the rock warrior is different . I appreciate the input, I'm actually doing the alignment myself at a local shop
  7. Apr 7, 2017 at 12:36 PM
    Backslider
    Tooele, UT
    Your caster can be off without structural damage..
    I would advise going to an alignment specialist. Good luck!
  8. Apr 7, 2017 at 4:36 PM
    Srice80
    Got it all figured out!
  9. Aug 7, 2017 at 5:21 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Care to share the result? Sorry to bring up an old thread, but I'm fighting Mr Tire for a shitty alignment. My camber is +.7 on both sides, theyre telling me not to worry about that.
  10. Aug 7, 2017 at 6:18 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Party foul! One does not claim success without sharing that which preceded it.
    1BadTundra likes this.
