Alignment question
Discussion in 'Suspension' started by ToyotaTundraMike, Apr 4, 2016.
  1. Apr 4, 2016 at 12:07 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    So right now I'm running the 18" BBS rims with 255/70/18 michelins.
    I finally found a set of TRD Pro rims and they have the 265/70/18 michelins on em.
    Gonna let Toyota put my Pro rims on when I drop it off for a oil change on Thursday. Will I need an alignment after going up just one size in tires?
    Wanting to get the least amount of alignments as possible. I have Bilstein 5100's that I plan on putting on before the next time I get an alignment done. Was hoping I could put it off until I get some bigger tires (275/70/18) and just install the tires and shocks and maybe some 1.25" spacers at the same time and then get an alignment done.
    If I need an alignment after going up just one tire size, I may as well go ahead and get the shocks put on as well and then get an alignment again later when I install new tires + spacers.
    Thoughts?
  2. Apr 4, 2016 at 12:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Do this, unless your alignment is currently needing some help.
  3. Apr 4, 2016 at 12:55 PM
    ToyotaTundraMike
    2015 Tundra
    Thanks, that would be much easier. My current tires are wearing perfectly so it isn't a need at this time. Was just hoping that the next size up wouldn't throw it off much, which doesn't sound like it will be the case.
  4. Apr 4, 2016 at 3:38 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah changing tires normally dosnt require alignment. When you mess with your suspension or add substantial weight to the vehicle is when you need an alignment
    ColoradoTJ likes this.
