Alignment on the Pro need skid plate removal?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Stuffs, Nov 15, 2017.
  1. Nov 15, 2017 at 9:53 AM
    Stuffs
    Stuffs [OP] New Member
    Does anyone know if you have to remove the TRD skid plate to do an alignment? Thanks
  2. Nov 15, 2017 at 10:21 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Shouldn't have to, but I guess it might depend on which skid plate you have...maybe
  3. Nov 15, 2017 at 10:36 AM
    Stuffs
    I notice both TRD Pro and the TRD Off Road (stamped steel) blocks the front alignment cam a little bit, enough where you can't fit fit a socket or airgun to it. But not sure if thats needed for an alignment or if they use like a long box end of some sort.
  4. Nov 15, 2017 at 10:39 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Couldn't tell ya, but mine weren't removed during my alignments. That's why I mentioned "it depends"
    NewImprovedRon likes this.
  5. Nov 15, 2017 at 10:44 AM
    Stuffs
    What kind of skid plate do you have?
  6. Nov 15, 2017 at 10:57 AM
    Eclipsed & Floating
    Voluptuous Whitey
    RCI
    TheBeast likes this.
  7. Nov 15, 2017 at 11:08 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I had an alignment on mine and there was no problem with the skid plate staying on the pro.
    NewImprovedRon and Stuffs[OP] like this.
  8. Nov 15, 2017 at 11:21 AM
    Stuffs
    Thanks, thats definitely good info since I can't seem to find anything on that on the web.
    The rear two lock nuts on the TRD Pro plates are "non-reuseable" according to Toyota (costs $85 for the hardware kit) so having to remove the plate for an alignment is just unnecessarily expensive.
