Alignment help
Discussion in 'Suspension' started by MJ_19Tundra, Mar 23, 2019.
  1. Mar 23, 2019 at 8:29 AM
    MJ_19Tundra
    MJ_19Tundra [OP] Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    2019 crewmax with 6" lift, 20s and 35s....
    *****Can someone help me out with some numbers on an alignment. Taking to get aligned today and want to make sure its within the correct numbers before I leave.
  2. Mar 23, 2019 at 8:32 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    There were my numbers.
  3. Mar 23, 2019 at 8:33 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Seems to be good?
  4. Mar 23, 2019 at 8:35 AM
    Sas
    OKC, OK
    Yep, no issues.
  5. Mar 23, 2019 at 8:37 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Lift kit didnt come with any numbers .
    And I dont know anything about alignment.
    Watt maker likes this.
  6. Mar 23, 2019 at 8:39 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Those #s are pretty good. Ideally you want .05 toe ea. side. 0* camber and as much caster as you can get, within reason. To compensate for road crown I like roughly .5 more caster right side.
    Your caster being around 4 is great IMO. I like 4* left and 4.5 right.
  7. Mar 23, 2019 at 8:41 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Why .5 more on the right?
    831Tun[QUOTED] likes this.
  8. Mar 23, 2019 at 8:42 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    So 0 camber, 3 caster, and how much toe in?
    I'm thinking about giving them numbers before they do it so I ain't gotta wait for them to redo it
    831Tun likes this.
  9. Mar 23, 2019 at 8:42 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    To compensate for the center of the road being higher than the sides of the road. If it doesn't pull, it's not an issue.
  10. Mar 23, 2019 at 8:43 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    I did a backyard alignment when I put the lift on. It drives strait now but my steering wheel is off. And I'm not sure about camber.
  11. Mar 23, 2019 at 8:44 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Sad thing is, It doesn't pull after i did an alignment with a tape measure. So I'm hoping that it wont pull after alignment and they will straiten my steering wheel.
  12. Mar 23, 2019 at 8:46 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  13. Mar 23, 2019 at 8:48 AM
    TundraDude4x4
    TundraDude4x4 New Member
    2010 Pyrite Mica V8 4x4 DC
    I know this doesn’t relate but what rims are those? I really like them
  14. Mar 23, 2019 at 8:53 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Procomp series 42
    4wp had or maybe still has a wheel and tire bundle. I paid 1400 for the procomp series 42 20" wheels with 35 MTs. Just couldnt pass it up
  15. Mar 23, 2019 at 9:13 AM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Here’s my numbers, just had it done yesterday. Can’t tell you if they’re good or not though. Had a 3/1 readylift with 35x11.5r20s installed.
    831Tun likes this.
  16. Mar 23, 2019 at 9:18 AM
    Tundra$
    Las Vegas
    I only have about 30 min of driving since but it felt good. Is the low caster what they do to help minimize big tires rubbing? I know the can do something with the castor right ?
    831Tun likes this.
  17. Mar 23, 2019 at 9:20 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I would imagine your steering wheel doesn't find center by itself very well 'cause the caster is so low.
    joonbug likes this.
  18. Mar 23, 2019 at 9:21 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Depends where it's rubbing. Generally they increase caster in the LCA which pushes the bottom of the wheel forward. This gets (helps) you off the cab mount.
    joonbug and Watt maker like this.
  19. Mar 23, 2019 at 9:29 AM
    Tundra$
    Las Vegas
    Honestly didn’t notice. Def will test that today. Thanks for the info
  20. Mar 23, 2019 at 9:31 AM
    Tundra$
    Las Vegas
    It isn’t rubbing and I spent like 15 min trying to make them rub so seems good so far but the tire gets like within a centimeter of the cab mount.
  21. Mar 23, 2019 at 9:52 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    No rub with 35s? I'm rubbin in reverse
    831Tun likes this.
  22. Mar 23, 2019 at 9:55 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That could be do to your wheel offset.
    joonbug likes this.
  23. Mar 23, 2019 at 9:55 AM
    Rubbing the front splash guards? Or that mini mud flap in front?
  24. Mar 23, 2019 at 10:11 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    If my steering wheel is off will the traction light come on and precollision come on? Says visit dealer
  25. Mar 23, 2019 at 10:22 AM
    Tundra$
    Las Vegas
    35x11.5r20 +20 , removed mud flaps on front and the plastic behind fog lights. Just barely missing cab mount, plenty of room between tire and stock uca
  26. Mar 23, 2019 at 10:27 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Removed the mini mudflap....I'd have to check but it's only when its fully turned
  27. Mar 23, 2019 at 4:07 PM
    Tundra$
    Las Vegas
    Drove it for about a hour today. You’re right though. Ride feels good and all but my wheel only goes about 95% to center after a turn and then I need to slightly help it. Think it’s something worth bringing it back in for ? Will adjusting possibly cause it to rub the cab mount that I’m really close to already ?
  28. Mar 23, 2019 at 4:58 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No, more caster will get you farther away from the cab mount. More caster also makes it want to track straighter so it's a bit easier on long drives.
    joonbug likes this.
  29. Mar 23, 2019 at 6:09 PM
    Tundra$
    Las Vegas
    Is there any reason why they would have set the castor the way they did then? I’m confused to their reasoning for setting it that way then even gave me a printout of how they set it wrong ?
  30. Mar 23, 2019 at 7:05 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't know what the deal is with alignment shops these days, close seems to be good enough. I don't think alignment techs, as a general rule, are the most skilled guys out there, at least in my recent experiences with 3 different shops. Clearly you're out of spec, hence the red. Why is beyond me. I don't know what alterations you've made to your front suspension either.
    Honestly, I think it's just a lack of skill/patience on the part of the tech. If you ever watch 'em do it the machine is VERY touchy. Every time they touch one thing it effects something else so it's a lot of fussing to produce exact #s. Camber gets set first which changes when they set the caster so they've gotta go back and re-set the camber which changes the caster. So, it's back and forth incrementally 'til you get where you wanna be. Very few have the patience or punctiliousness.
    jeremyd, Vizsla and joonbug like this.
