Alignment after changing wheels
Discussion in '2.5 Gen Tundras (2014-2021)' started by Efrainea, Mar 12, 2019.
  1. Mar 12, 2019 at 8:53 PM
    Efrainea
    Efrainea [OP] New Member
    Efrain
    None
    I have a 2018 tundra, can someone help me answer this question. I recently bought 285/65/18's. But my strongst wheel is shanking when I reach 50mph. Do I need an alignment, or did they not balance my tires when they put them on. What should I check first?
  2. Mar 12, 2019 at 8:56 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Not alignment. Final answer
    15whtrd and JohnLakeman like this.
  3. Mar 12, 2019 at 8:56 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Balance
    15whtrd likes this.
  4. Mar 12, 2019 at 9:03 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Balance
  5. Mar 12, 2019 at 9:04 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I'm fighting a similar issue. Subscribing.
  6. Mar 12, 2019 at 9:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Imbalance, out-of-round tire, lug-centric wheel when you should have hub-centric, (not sure if you have aftermarket wheels) or if it’s only for the first few miles of a trip, it can be the joys of a stiff 10ply rated tire on a lighter truck, especially in cold weather.
    The only way it could be alignment is if the tires are cupped / worn unevenly and then causing a shimmy.
  7. Mar 13, 2019 at 6:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It's very likely a bad tire that is heavy in one area and CAN NOT be balanced to specification. It will take too much weight, clearly visible, to balance the tire. Tire tech likely has instructions to pass it on, the tire dealer hoping it won't be immediately noticeable to you. If it's not the tire, then you have a bad wheel. Take it back to them.
  8. Mar 13, 2019 at 8:43 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Balance and/or defective tire. Take it back. It should work well up front right where it is. I would mark the rim so that you can tell if they move it. If they are able to improve it but cannot rebalance the tire perfectly, it’s a defective tire. It could also be a bad rim... but less likely. Mine came marked at the factory (red dot) to correspond with recommended mounting orientation on the rim.
    JohnLakeman likes this.
  9. Mar 13, 2019 at 9:10 AM
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    I am having the same issue the tire guys balanced with sand I didnt even know that was a thing Ive heard of airsoft pellets but when I get up around 65 its got a shimmy I rarely am over 45 so I did not notice it until the other day.
  10. Mar 13, 2019 at 9:38 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I get an alignment every time I change tires. That being said your issue sounds a lot like what the general consensus says - balance/lemon tire. Did they do a road force balance?
