ALCAN SPRINGS soon to be installed.
Discussion in '2nd Gen Builds (2007-2013)' started by GHOSTTUNDRA, Aug 25, 2020.
  1. Aug 25, 2020 at 11:45 AM
    GHOSTTUNDRA
    GHOSTTUNDRA [OP] New Member
    Jonathan
    2012 Tundra Crewmax 4x4
    Bilstein 5160/6112 Toytec Shackles VTX Off road Nitto trail grapplers Front Runner Slimline roof rack and bed rack. GFSR Rooftop tent
    Just received my leaf springs from Alcan leaf springs. Could this been installed myself or is it recommended a shop install it.
    Would I need upgraded bump stops?
    4x4WarriorOfRocks and Rex Kramer like this.
  2. Aug 25, 2020 at 11:56 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I installed mine by myself. It's a pretty basic install. Just make sure you put the right side to the front.
    rockmup likes this.
  3. Mar 16, 2024 at 12:13 PM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    I am curious about this leaf spring kit. Would you mind sharing what you paid and what you think of them? Thanks!
  4. Mar 22, 2024 at 1:06 AM
    Bluutundra
    Bluutundra New Member
    Oregon
    2008 Naut. Bl Tundra Limited
    -295/70r18 on KMC’s -Ironman Foam Cell Pro Struts & Rear Shocks 3.5inch lift -Rear air bags
    I am intrigued as well… I just threw on the Ironman 4X4 leaf springs AUS steal. And they are stiffer than I ever could’ve thought. These look beefier, please update on your op.
  5. Mar 22, 2024 at 6:03 AM
    It's easier with 2 people but you can do it yourself. Make sure you disconnect the brake line and ABS wire brackets from the rear axle. Also make sure you replace the ubolts. I swapped to Timbren bump stops on mine since I have a lift.
  6. Mar 22, 2024 at 6:05 AM
    Call them and ask for Lew. He can tell you the total shipped cost. Mine were around $1200 if I recall. They are great springs. A few of us have them. They can build them with lift or support for additional bed weight.
  7. Mar 22, 2024 at 6:08 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Me wonders how these PU bushings behave in cold? I can't remove Hi-Lift handle keeper in winter, for example. Noticed the same thing with other polyurethane products: they shrinks a lot in cold weather.
    I'm planning to upgrade leafs soon, but think will go with the OE rubber bushings.
  8. Mar 22, 2024 at 12:37 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I installed by myself.
    Do you have OEM shackles? I have CBs and was told by David to use their bushings with the Alcans.
  9. Mar 22, 2024 at 12:58 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not on the track currently, but, yes, I have them somewhere.
  10. Mar 22, 2024 at 3:38 PM
    blenton
    blenton New Member
    My experience running PU vs OE rubber bushings in the cold... The OE rubber bushings always had more of a weird rear shimmy when it dropped below 25F. I ran CB +1 shackles with his PU bushings for 120k miles or so; they transferred more of the road feel when cold, but had less of a jiggly shimmy than the rubber ones, if that makes sense. I changed them out for Energy Suspension's PU leaf spring bushing last year when my CB shackles froze up and I had to swap the stock shackle back in. They seem to be the best of both worlds with very little jiggle or shimmy. BUT... the jiggle/shimmy was always worse with an unloaded bed, and my bed hasn't been unloaded for years. I've also changed a few things (shocks, then Icon 3 leaf pack, then 3 Leaf pack and extra special add a leaf with Air bag temporary delete...) so it's not 100% apples to apples. Even still, I still prefer the PU leaf spring bushings over the OE even in the cold, with the Energy Suspension bushings seeming to work best for me.
  11. Jul 11, 2024 at 7:08 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    what were the specs on your springs?
