AJT Designs... What have you done?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Apr 5, 2021.
  1. May 13, 2021 at 5:24 PM
    #61
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I got in on the preorder so probably had one of the first runs of it. My precollision sensor worked very infrequently with the relocation bracket. It would turn off often on clear days with no bad weather…..i even got it recalibrated at the dealership. 15 minutes after I left sensor turned off. It went like that for weeks….tried adjusting with no access. Took it off and ordered the jomax - no problems since
  2. May 13, 2021 at 5:44 PM
    #62
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    who makes that switch panel and how hard was it to relocate the rear window switch?? I like that a lot!
  3. May 13, 2021 at 7:43 PM
    #63
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    CN Designs sells the switch plate, but there's also a file floating around if you know someone with a 3D printer.
    Accessorides sells the harness. Those two pieces and a blank switch cover to plug the hole in the dash and you're set.
    Pull the dash panel and remove/unplug the switch, plug the harness into the end and run it behind the dash and down under the console, install the switch panel (this will require permanently cutting that piece out of your console), install the switch into the new plate, plug it in and that's about it. There's a couple of more detailed how-tos on here with pics.
    Toe404[QUOTED] and TunBrun like this.
  4. May 24, 2021 at 7:08 AM
    #64
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Just ran across this thread and would like to do this. The AccessoRides website indicates the harness fits 2011-2017 Tundras. I see you have a 2020, so I'm assuming this would work for 2019 Tundra also. Can anyone confirm? Thanks.
  5. May 24, 2021 at 4:32 PM
    #65
    OnespeedTRD
    Don
    San Diego
    Yep, all the same up to 2021.
  6. Jun 10, 2021 at 10:41 AM
    #66
    gibby11
    gibby11 New Member
    Andrew
    Las Vegas
    Does anybody know if they usually run an Independence Day sale?
  7. Jun 10, 2021 at 11:19 AM
    #67
    Taco-Spike
    Two Trucks
  8. Jun 10, 2021 at 12:04 PM
    #68
    cvakwolfpack15
    cvakwolfpack15 New Member
    2016 Tundra TRD Pro
  9. Jun 10, 2021 at 12:18 PM
    #69
    gibby11
    gibby11 New Member
    Andrew
    Las Vegas
  10. Jun 10, 2021 at 1:33 PM
    #70
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I wonder if he could modify the design so that its a solid oval that "custom fits" fits to the logo, yet the end user could easily modify to remove the oval, leaving the mount behind? A couple of snips and some sanding of flash?
  11. Jun 10, 2021 at 1:36 PM
    #71
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Wow that’s awesome. A lot going on in that picture. Looks amazing.
  12. Jun 10, 2021 at 1:48 PM
    #72
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Wawaweewa Please explain this.
  13. Jun 10, 2021 at 2:01 PM
    #73
    Taco-Spike
    Two Trucks
  14. Jun 11, 2021 at 12:00 AM
    #74
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    He does have a flat oval Emblem Overlay with his own logo on it.
    But it really isn't aesthetically pleasing as the OEM Toyota emblem cover he was making..:(
    Emblem Overlay (ajtdesign-llc.com)
  15. Jun 11, 2021 at 6:12 AM
    #75
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    0FCB326E-AACD-4CE5-9D2E-952EFAA921E6.jpg 2739EC8E-AC47-453F-A02C-E6F4E1793324.jpg 1F6C5E9F-3544-4142-B0FB-872BD5F30CD7.jpg I did the whole chrome delete. Love it.
    TX-Vato, gkelm, WILLINH and 1 other person like this.
  16. Jun 11, 2021 at 6:13 AM
    #76
    TommyTundra
    Long Island NY
    2019 PRO
    Also had the shifter knob laser engraved62F38DC8-49A5-4153-B6B5-0D7648A87DC9.jpg
    Jcmf52 likes this.
  17. Jun 11, 2021 at 6:36 AM
    #77
    TommyTundra
    Long Island NY
    2019 PRO
    7F653E2D-BBBC-48AD-B45A-C8D60C0EBFFB.jpg 150055B6-DA4B-49A7-B148-509FA548ABDB.jpg While i was at the laser engraver i also had my Sig 226 engravedC3E552CE-B8AC-44A3-920F-69E058FCBD75.jpg
    WILLINH and cochese like this.
  18. Jun 14, 2021 at 11:42 AM
    #78
    cvakwolfpack15
    2016 Tundra TRD Pro
    I installed a Phoenix automotive Tesla style head unit. I took it apart to paint the trim piece black. Before I installed it, I took the entire center console out and also painted that black. The two steering wheel trim pieces were also removed and painted black. Everything else is from the AJT chrome delete kit.
  19. Aug 28, 2021 at 7:44 PM
    #79
    CorpsTundra
    CorpsTundra New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    Did the eBay emblem overlay work out well for you? The only other one from eBay that I could find confirmation on is out of stock.
    #79
    ToyoMafia[QUOTED] likes this.
  20. Aug 28, 2021 at 9:26 PM
    #80
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    #80
    CorpsTundra[QUOTED] likes this.
  21. Aug 28, 2021 at 9:48 PM
    #81
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I’m personally not a fan of any of AJT’s stuff aside from their door handle covers. They look to tactical/mall ninja for me. I personally painted all my pieces black or replaced them with trim components from the SR
    gkelm likes this.
  22. Oct 8, 2021 at 6:56 AM
    #82
    Crazzy450z
    Crazzy450z New Member
    I see multiple people with the vent rings installed.. I went to do mine on my 2018 DC SR5 this past weekend, and the ones in the light gray center section do not push up tight to the chrome ring. They fit fine on the outer vents with the dark dash surrounding it.. But on the center two, the dash tapers and this taper is keeping the rings from going tight to the chrome. Anyone else have this issue? Are they all supposed to be the same size? What is that size supposed to be?
  23. Oct 8, 2021 at 7:01 AM
    #83
    ToyoMafia
    Magic carpet.
    I sent out many sets of these and have not heard of this issue.
  24. Oct 8, 2021 at 7:05 AM
    #84
    Crazzy450z
    I did check your page.. Your's look slightly different than the AJT design.. Maybe yours are not larger then the chrome.. Maybe i got the wrong size. I'm not sure.. Just trying to figure out what i should do.. lol.. I'll try to post a couple pics tonight.
  25. Oct 8, 2021 at 7:05 AM
    #85
    ToyoMafia
    Magic carpet.
    Gotcha.
  26. Oct 27, 2021 at 6:31 AM
    #86
    gkelm
    gkelm New Member
    DFW
    Do you happen to know the part numbers For the black SR dash panels and steering pieces?
  27. Oct 27, 2021 at 7:08 AM
    #87
    RobertD
    Robert
    DFW, Texas
    Cl8NL likes this.
  28. Oct 27, 2021 at 9:41 AM
    #88
    gkelm
    gkelm New Member
    DFW
  29. Oct 27, 2021 at 9:49 AM
    #89
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Anyone try the dash mat from them (late models)? I am ok with the price but the shipping is a kick to the soft stuff to get it over your northern border.
    Lucky to get a few things from them before the Toyota police dropped the hammer. Found the items to be of great quality. I sent them a note that even the small zip lock bags they came in were the thickest bags I'd ever seen, I saved them for something that comes up in the garage.
    BravoDeltaRomeo likes this.
  30. Nov 12, 2021 at 8:13 AM
    #90
    gkelm
    gkelm New Member
    DFW
    I wish (along with perhaps others) that AJT would offer a more standard look set...not so industrial/techie.
    Legga400 likes this.
