Airbags on a TRD Pro for towing??
Discussion in 'Suspension' started by doggiecareman, Nov 9, 2018.
  1. Nov 9, 2018 at 6:00 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Had airbags installed on my 2013 DC previously as I tow an approximately 7800 pound trailer and with all the cargo, generator and fluids it totals a payload of close to 9k pounds give or take. This is my first TRD model. With the obviously elevated suspension made for off roading, would air bags interfere with the existing suspension or is it even necessary? I haven't hooked it up yet to try. I do have the weight distribution bars.
  2. Nov 9, 2018 at 6:04 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I vote you go airbags and sell me the suspension! In all seriousness though the suspension was tuned for off-roading, not towing. A lot of guys complain about the squat with the Pros, especially if towing that amount of weight. I don’t have a lot of advice for you but I know there are some towing experts on here who will likely chime in soon. I know a lot of guys recommend load equalizers, leaf packs, etc. I’ve heard the air bags really effect the ride quality. Congrats on the new pro!
    JoshuaA, doggiecareman[OP] and Vizsla like this.
  3. Nov 9, 2018 at 6:23 PM
    doggiecareman
    Eric
    North Central CT
    I am curious to know if I only inflate the airbags while towing and let out all the air when not if that would adversely affect anything one way or the other? I left 10 pounds in on my other Tundra and it stiffened the ride to some extent but not by too much and trailered the camper very well along with the weight distribution bars. There is an adjustment control on the dash you can make to point the headlights from 1 to 5 degrees down when the back end is lower. I would imagine they put that there for this reason. Not sure how long that option has been around, I know it will come in handy for me.
  4. Nov 9, 2018 at 6:33 PM
    KnuckleHD
    Yea the leveling motors definitely come in handy when towing. I’ve never run bags so I can’t really speak to the best option there. How often are you towing? I’m taging @ColoradoTJ I think he’s the local resource with these matters.
    doggiecareman[OP] likes this.
  5. Nov 9, 2018 at 6:37 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Airbags with cradles. Best of both worlds.
    Or Sumosprings and thread on superbumps when you don't need the carrying capacity.
    15whtrd and Watt maker like this.
  6. Nov 9, 2018 at 6:37 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Had a rear air bag set up on my f-150 before the Tundra, I used it a lot, worth every penny. Just my 2 cents
    I’ll be looking at bags for the Tundra or old man emu leafs
    Tundyfundy and OBXTundra like this.
  7. Nov 9, 2018 at 6:38 PM
    doggiecareman
    Eric
    North Central CT
    I have the camper which gets used currently VERY infrequently and hope to change that. I also have an 18' landscaping trailer that I haul a Grand L3940 Cab Kubota with loader and BH that all totaled is about 8500 to 9000 also, but that is only once a year or two. The other 2 trailers I have are under 3500 so no issues there.
  8. Nov 9, 2018 at 6:39 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Varying loads, airbags. With cradles.
    Watt maker likes this.
  9. Nov 9, 2018 at 6:40 PM
    doggiecareman
    Eric
    North Central CT
    Not familiar with cradles?
  10. Nov 9, 2018 at 6:43 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    See image. Uninflated they will not be pulled and effect wear/articulation. Varying loads this is IMHO the best solution to still maintain offroad capability. daystar-airbag-cradle-install.jpg
    PS. sorry....made by Daystar. I don't have them. But its what I would do in your situation.
    equin, 15whtrd, papasmurf and 3 others like this.
  11. Nov 9, 2018 at 6:45 PM
    doggiecareman
    Eric
    North Central CT
    THANKS!! Will look into having them installed.
    Inquiringone likes this.
  12. Nov 9, 2018 at 6:48 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Welcome. See you're from CT. I'm originally from Thomaston. Been west to east and around the world by now and ended up in NC.
  13. Nov 9, 2018 at 6:53 PM
    doggiecareman
    Eric
    North Central CT
    Originally from Mo and have lived in Co, Az, Utah, Ok, and Ma. Currently building a place in southern Vermont and own a place in southern Maine. Plan to settle into retirement in the place in Vermont. Living in CT currently but can't wait to get out of here quite honestly. If I were to live south of here it would be in the hills of NC. Been to Asheville and loved it.
    plumber802 and Inquiringone like this.
  14. Nov 9, 2018 at 7:13 PM
    I 3rd the motion. The cradles are a must.
    If you don’t have the cradles, whenever you get service on your trucks, inform the service manager so they can disconnect them to reduce the possibility of tears.
  15. Nov 11, 2018 at 4:52 PM
    doggiecareman
    Eric
    North Central CT
    What Manufacturer for the cradles and airbags do you recommend?
  16. Nov 11, 2018 at 4:54 PM
    Daystar might be one of the only manufacturers. That’s what I used.
  17. Nov 11, 2018 at 6:45 PM
    doggiecareman
    Eric
    North Central CT
    Thanks!
  18. Nov 11, 2018 at 6:59 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    I run a removal Firestone setup. I have it down to remove them within 30 minutes both bag and Daystar cradle.
  19. Nov 11, 2018 at 7:26 PM
    doggiecareman
    Eric
    North Central CT
    Thanks for the insight. I'll look into that. I am under the impression that Firestone airbags are popular? If there is any feedback on that subject it is very welcome.
    t3chnical likes this.
  20. Nov 20, 2018 at 10:25 AM
    t3chnical
    t3chnical New Member
    Chula Vista (Eastlake), California
    2017 Tundra SR5 CrewMax
    7” Pro Comp Lift 20” LRG on 37s
    :popcorn:Thanks op and all who responded, this was a similar question I had. Part of the reason why I chose to not go with TRD edition was my concern with how the suspension would be affected towing a toy hauler. I am considering the Firestone RideRite helper springs and one of the wireless command systems.
    Firestone Ride-Rite Rear Air Helper Spring Kit - 2445
    Def going to do some added research on the Daystar cradles now!
  21. Nov 25, 2018 at 2:22 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    BTW Vermont is a Constitutional Carry state! Welcome.
  22. Nov 28, 2018 at 12:47 PM
    doggiecareman
    Eric
    North Central CT
    I know!!! It's great for sure. Liberty for all in a true sense.
    plumber802[QUOTED] likes this.
  23. Nov 28, 2018 at 12:48 PM
    doggiecareman
    Eric
    North Central CT
    I'll be installing Firestones and cradles soon. Still debating on whether to do the built in compressor or not.
  24. Nov 28, 2018 at 12:55 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Yes daystar cradles are a must have, and this is a great setup used to have it before i went full retard with my truck, i loved it super easy and ran awesome on and off road!
  25. Nov 28, 2018 at 1:20 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    do it worth the extra effort... never know when you need to inflate them in a pinch.. nice to have the option
  26. Nov 29, 2018 at 5:15 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I use Roadmaster Active suspension springs. At standard setting give 1/2" lift unladen, reduce axle hop, better stability and significantly reduces sag, boosting the soft rear spring rates capability without the negative side effects of airbags.
  27. Nov 29, 2018 at 5:23 PM
    doggiecareman
    Eric
    North Central CT
    I wonder if that would stiffen the initial suspension travel too much on the Fox shock system when I am not towing?
  28. Nov 29, 2018 at 5:56 PM
    Bulldog9
    NOVA
    In my experience not really at all. If anything it feels more planted. I have the Bilstien TRD PRO suspension
  29. Dec 7, 2018 at 11:25 AM
    doggiecareman
    Eric
    North Central CT
    The Firestone airbag, compressor, interior gauge kit and cradles arrived today and will pick them up from the off-road speciality shop on Monday. Will be installed not too long after that. Will post pics, after installation.
  30. Dec 7, 2018 at 11:35 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I run airbags with cradles. They're awesome
