Air NOT blowing into cab
Discussion in '2nd Gen Tundras (2007-2013)' started by MtnBiker18, Jun 30, 2021.
  1. Jun 30, 2021 at 6:54 AM
    MtnBiker18
    MtnBiker18 [OP] New Member
    2010 Tundra Limited 4x4
    HI, I have an interesting problem. I haven't ran the AC in quite a while, but I'd like to. About a month, or more, ago, when I'd shut the truck off, after about 2 or 3 minutes, I'd hear like a moaning noise coming from under the dash. Flash forward to this week, when the Temps reached the low 90's, and I turned on the AC. I can hear the blower motor spin up, but nothing comes out the vents. I wonder if the 'moaning' I'm hearing has something to do with an actuator connected to a door that is stuck closed? If that is the case, how can I get the door opened?? If its not the case, then what do you thing would cause the issue (the air not coming into the cabin)? Yes, the AC does work. The issue is with the air not coming into the cab.
    Thank you for your time.
  2. Jun 30, 2021 at 7:29 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Let's hope it is an actuator issue and not a door issue. The door is in one until, not really serviceable. The doors run off or rods that turn and twist the door with it. I had an issue with my '14 and it groaned for a while when I tried to get floor heat. After a while it just stopped working (no floor air flow). Dealer asked if there were any smells (i.e., dead mouse blocking the door) and thought I had dropped something in the unit from the defrost vents. Nope, nothing in the unit. The shaft snapped so the entire unit had to be replaced.
    If your entire unit needs to be replaced it isn't pretty. See in this thread: https://www.tundras.com/threads/upd...seriously-pic-hvac-core-being-replaced.70864/
    See #1 below. This is for a 2010 Tundra limited.
  3. Jul 1, 2021 at 11:48 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Check your cabin Air Filter first before you tear into the system. It may be clogged with leaves and or a rat/squirrel nest.
    NueveTundra likes this.
  4. Jul 6, 2021 at 7:40 AM
    MtnBiker18
    Thanks for the info, guys. The Dealer said they wanted $1300, just to pull the dash.
  5. Jul 6, 2021 at 7:52 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Update us which ever way it goes.
  6. Jul 6, 2021 at 8:05 AM
    MtnBiker18
    Will do.
    Thanks.
  7. Jul 6, 2021 at 8:08 AM
    biebs96
    PA
    Following. I had an hvac issue on my 2nd gen and never got it fully resolved.
  8. Jul 6, 2021 at 8:21 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    You can check that and your blower by just taking the glove box out. Check the simplest things first K.I.S.S.
  9. Sep 12, 2021 at 10:29 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Sooo how did it goo??
  10. Sep 14, 2021 at 9:14 AM
    FWD Tundra
    Washington
    Any luck with your project?
  11. Sep 18, 2021 at 1:16 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    having the same issue in my '07. my mechanic told me it was the blower motor and that the whole dash will have to come out to replace it.
  12. Sep 18, 2021 at 1:49 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    It took me less than 20 minutes to replace mine in my 2012. It was out of state in an Autozone parking lot
    Black Wolf and Mike59 like this.
  13. Sep 20, 2021 at 7:25 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I can verify that your mechanic needs to be your ex mechanic. I had a little bit of a hard time popping off one of the wiring clips that needed to move a little to get the blower out, so I think it took me 21 minutes to replace mine a few weeks ago.
  14. Sep 23, 2021 at 2:07 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    hmm, maybe i'm mistaking some terminology then. it was almost two months ago. he said it's the motor way down inside that shifts the doors (or whatever) betweeen AC & defrost.
    what part was it that you two replace in 20 minutes?
  15. Sep 23, 2021 at 2:20 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    One can replace the blower motor in 20-30 minutes.
    The HVAC unit, that contains and controls the blend doors, is dead center on the dash down by the floor. And YES, then entire flipping dash needs to be taken out to replace that unit.
  16. Sep 24, 2021 at 1:21 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Then that’s what he said needs to be done. Was he wrong? I hear the same creaking and moaning and groaning coming from my dash every time I turn off my truck and I only get (ice cold) air through my defroster. Would that be a blower motor issue? Or the HVAC/heater unit? I would love it if it were a 20 minute fix.
  17. Sep 24, 2021 at 2:43 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    Does the air blow immediately from the defroster vents when you start the truck, or is there a delay?
  18. Sep 24, 2021 at 3:40 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    There’s a delay. If I start my truck with AC all the way up, coldest setting, blowing out the vents, it creaks for about 30 seconds and then starts blowing out the defroster.
    BenAZ likes this.
  19. Sep 24, 2021 at 3:48 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    I had the same problem but with my heater shortly after buying my 2007. These videos helped me fix it in less than an hour.
    https://www.youtube.com/watch?v=sXJLu8D0Cfo
    https://www.youtube.com/watch?v=Yo9HTgMO2tU
    Its not too difficult to try this and see if your servo can be re timed. It could also be a wiring issue. If it is, they sell just the harness for the blend doors as separate from the rest of the body harness. The second video shows how all the arms and gears need to be indexed.
    baraynavab and Black Wolf like this.
  20. Oct 19, 2021 at 7:44 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    both of those videos show access through the center console/shifter... i have a column shifter and bench seat. i'll have to look around for some videos with my "grade" SR5.
  21. Oct 19, 2021 at 11:41 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    I would think that would be a little bit easier. My 2016 was the same setup as yours before I did the center console swap. Remove the bottom center plastic piece under the stereo. In all fairness I have no experience on a second gen without the center console, although it is identical from what I can tell between second and 2.5 gen trucks.
  22. Oct 26, 2021 at 11:08 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    cool story bro. i think these things just tend to happen after 14 years and 250K miles.
  23. Oct 26, 2021 at 12:00 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    The servo motor on my 07 stopped functioning. I was quoted 2000 to fix it. I lived with it until they gave me 20k on trade to get me into a 17.
    MT Madman likes this.
  24. Dec 28, 2021 at 9:17 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    I think my AC/heater unit has mostly given up the ghost. The defroster, which was the only function that worked, has now stopped heating up quickly. Used to be I could start my truck in the morning with the defroster on full blast and come back to a warm cab in five minutes. Now it just blows cold air until I've been driving for 5-10 minutes. And even then it'll stop and start. Looks like I'll be purchasing a whole new unit soon :/
  25. Dec 28, 2021 at 9:19 AM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    Does the coolant come up to temp normally? It could be a thermostat issue.
  26. Dec 28, 2021 at 9:19 AM
    audiowize
    Paul B.
    I would not replace anything based on what you just said. How's your water pump?? If it's getting a little bit leaky and you've lost some coolant, you may not be getting coolant flow through the heater core and that may be your issue.
  27. Dec 28, 2021 at 9:46 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    damn, i'm glad I posted. now that you mention it, i noticed the other day that my oil temp was occasionally moving all the way to H while at a stop light. and my coolant reservoir (or something?) has a leak. i fill the reservoir and the next day or two it's down to less than an inch again and there's some splatter. all started happening in the last week or two.
  28. Dec 28, 2021 at 9:49 PM
    audiowize
    Paul B.
    Yeah, don't mess with the heating system till that's resolved.
    You could have a leaky water pump, a leak in the valley, or pieces of the radiator cap have broken off and have gone places they shouldn't be.
    If just the overflow tank has a leak, that would be super easy.
    For the other issues, you'll need to inspect your rad cap and possibly pressure test the system to see where it may be leaking.
  29. Jan 2, 2022 at 3:08 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    My water pump has about 65K miles on it. If there’s no coolant flowing through the heater core will it not blow hot air?
  30. Jan 2, 2022 at 3:09 PM
    audiowize
    Paul B.
    Yes, but you would likely also notice that if you rev up the engine you may very temporarily get some heat.
