Air intake
Discussion in 'Performance and Tuning' started by scharring100, Apr 19, 2023.
  1. Apr 19, 2023 at 12:02 PM
    scharring100
    scharring100 [OP] New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Tired of poor mileage. What’s the best cold air intake for the money. I’m on a fixed budget. Retired. 5.7 4 wheel drive. 2016 crewmax
  2. Apr 19, 2023 at 12:03 PM
  3. Apr 19, 2023 at 12:03 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Is your intake box stock? If so then this is the best cold air intake option. I would upgrade the filter to a better unit if you have not done so already. For example an AFE
    fuzzamungus, Saltyhero13 and RobertD like this.
  4. Apr 19, 2023 at 12:07 PM
    What the!?
    What the!? New Member
    2017 Pro
    https://www.tundras.com/threads/sabm-review.48388/
    This may help you. That being said, I have the TRD one. Don’t waste your money. It’ll give you sound, but that’s about it.
    Nothing will give you better gas mileage in these trucks except a lighter foot.
  5. Apr 19, 2023 at 12:28 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The $300+ dollars wasted on a “cold air intake” would be better spent on more gas. I’d work on improving driving habits for the best improvement.
    Saltyhero13, prevent and reywcms like this.
  6. Apr 19, 2023 at 6:10 PM
    scharring100
    Houston, Texas
    How about a chip. I’m out of warranty
  7. Apr 19, 2023 at 6:15 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Not worth it. I’d also check tire pressures but again this is a truck that inherently doesn’t do great for mileage overall.
    Saltyhero13 likes this.
  8. Apr 19, 2023 at 8:59 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Slow down and use the smallest/lightest tires and wheels you can get away with. Ditch any extra weight from the truck that isn’t necessary.
    Nothing else will make an appreciable improvement. Cold air intakes are not an improvement over stock. A chip or programmer might get you a teeny improvement, but what? Maybe 1 mpg? That’s probably optimistic. I doubt you’re going to save enough on fuel to see any return on the investment. Same with an exhaust system. How many miles would you need to drive to recover fuel savings to offset the grand you’ll pay for the tailpipe and muffler.
    Make truck lighter. Small/light wheels and tires. Slow down your driving. Clean or replace air filter.
    reywcms likes this.
  9. Apr 19, 2023 at 9:18 PM
    MALIBU1794DC
    MALIBU1794DC New Member
    2019 Double cab 1794
    Pedal commander.
    Best mod for tundra.
    Lets you get up to cruising speed faster. I get maybe 0.5-1 mpg better with the pedal
    commander
  10. Apr 20, 2023 at 5:35 AM
    scharring100
    Houston, Texas
    Thank everybody for your replies, you’ve been very helpful
  11. Apr 20, 2023 at 6:06 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Does a Pedal Commander do something more than change the throttle application in relation to pedal position? I understand that it is similar to using Tow/Haul, but without the transmission control changes. In other words, isn’t it a placebo? I can’t see how making the throttle curve more aggressive would increase mileage.
  12. Apr 20, 2023 at 8:14 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Engineers spend a lot of time and brain power to make modern engines run as efficiently as possible (and they're smarter than people selling aftermarket bolt-on gimmicks). Manufacturers spend a lot of money to facilitate this R&D (some more than others).
    The stock air intakes on NA vehicles are not restrictive and do not starve the engine of air. Also, air is pulled into the combustion chamber via the piston sucking it in on the down stroke. It doesn't matter what filter or filter box you install, the air will not be any colder and the piston will not pull any more air into the combustion chamber.
    Stock paper filters work as well or better than any gimmicky aftermarket product and all you have to do is check them periodically and replace them when dirty. The only thing that will restrict flow is a clogged filter.
  13. Apr 20, 2023 at 8:17 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I bought my truck slightly used and the previous owner installed one of those. After playing with it, it seems to make the throttle more responsive, ie; dumps more fuel.
    My truck gets better fuel economy with it turned off. 2 mpg better on average, to be specific
