Air Intake Tube Alternative
Discussion in 'Performance and Tuning' started by JeffMac, Feb 26, 2021.
  1. Dec 29, 2023 at 10:06 PM
    #91
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    Awesome! I look forward to hearing what all worked for you!
  2. Dec 30, 2023 at 6:15 AM
    #92
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Able to share the parts list used?
  3. Dec 30, 2023 at 7:09 AM
    #93
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    Look at post #46 for the silicone boots, I bought blue ones but they are the same. The plastic piece between the boots is the Toyota part (roughly $50) but I didn't feel comfortable making my own and it was easy to use, post #36. Then all you need is the 15/32 hose, see link for product to find at local auto store. I did replace my band clamps with ones from Homedepot but that was personal preference.
    https://www.oreillyauto.com/detail/c/masterpro-hose-clamps/masterpro-hose-clamps-vent-hose/mhc1/cv1532?q=15/32+hose&pos=0
    Vr0ck[QUOTED] and bulldog93 like this.
  4. Oct 29, 2025 at 10:16 AM
    #94
    Andhon
    Andhon 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    @Shanet421 What 15/32ID hose did you use? I see your hose is prebent and looks pretty clean! I believe that hose is called the PCV hose?
  5. Oct 29, 2025 at 11:13 AM
    #95
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Intake tube hoses are common can be sourced all over. Summit racing, Amazon, hps etc
    Andhon[QUOTED] likes this.
  6. Oct 29, 2025 at 11:39 AM
    #96
    Andhon
    Andy
    Yeah i found a few online which ill resort to but the one that @Shanet421 posted has those two 90° bends that make it look pretty clean!
    also @reywcms, i know you have a supercharger but do you think its worth doing the SABM in a stock 5.7?
  7. Oct 29, 2025 at 11:40 AM
    #97
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    All those also available for 45- 90* bends.. Yep I did the SABM on mine prior to being supercharged worth it
    coTony, Mdl and Andhon[QUOTED] like this.
  8. Oct 29, 2025 at 11:41 AM
    #98
    Andhon
    Andy
    Noted for both, ill look into those hoses and doing the SABM! thank you @reywcms
  9. Oct 29, 2025 at 11:44 AM
    #99
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  10. Oct 29, 2025 at 4:02 PM
    #100
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    This is the the part number from Toyota but it’s costly!
    PTR03-00140-AE
    I have since changed up the look a bit with shaving off the resonator and using the stock tube with this PCV hose still.
    bulldog93 and Andhon[QUOTED] like this.
  11. Oct 29, 2025 at 4:08 PM
    #101
    Andhon
    Andy
    Thanks for the part numbe @Shanet421. It indeed is costly haha. Whyd you opt to chop off the resonator and use the factory tube?
    Side question; Does anyone know if the TRD Intake Air Tube Part Number: PTR03-00140-AC is made of plastic? I would assume it is? Would it be worth wrapping that in heat tape?
  12. Oct 29, 2025 at 4:17 PM
    #102
    Shanet421
    San Diego,CA
    Yes it is a ridged plastic. I ended up having a problem where that piece cracked under the pressure of the hose clamps and I also failed visual smog inspection here in Cali
  13. Oct 29, 2025 at 4:30 PM
    #103
    Andhon
    Andy
    Dang... thanks for the info! I might just swap out the tubes when I get my truck smogged, since I am unfortunately i am in Cali as well
  14. Oct 29, 2025 at 4:54 PM
    #104
    Shanet421
    San Diego,CA
    Ya it’s open to interpretation by the tech but definitely keep your parts
  15. Oct 30, 2025 at 4:08 AM
    #105
    NITEWULF
    NITEWULF Limit Pusher
    ROB
    Raleigh, NC
    2017 CREW MAX SILVER SKY TSS OFF-ROAD
    AFE CAI, TRD EXHAUST, OTT MILD/SPICY TUNE
    Ton of great info in this thread, loving the pics and experiences.
  16. Oct 30, 2025 at 6:43 AM
    #106
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Did it fail inspection because it was cracked?
  17. Oct 30, 2025 at 7:42 AM
    #107
    Shanet421
    San Diego,CA
    No because it wasn’t OEM and didn’t have a CARB compliant sticker. Kind of a godsend cause when removed is when I noticed the crack.
    bulldog93[QUOTED] and Andhon like this.
  18. Oct 30, 2025 at 8:06 AM
    #108
    bulldog93
    Jeff
    So gotta get that free CARB sticker for it then?
  19. Oct 30, 2025 at 8:24 AM
    #109
    Andhon
    Andy
    I dont think they make carb stickers for DIY intake tubes lol
  20. Oct 30, 2025 at 8:44 AM
    #110
    Andhon
    Andy
    @Hobbesdsm how did you attach the brass fittings to the pipe? is there a nut on the threaded side of the brass fittings?
  21. Oct 30, 2025 at 10:28 AM
    #111
    bulldog93
    Jeff
    They do for the TRD intake kit.
  22. Oct 30, 2025 at 10:35 AM
    #112
    Andhon
    Andy
    Indeed they do but i would assume they would only give you the sticker if you buy the TRD package? i could be wrong
  23. Oct 30, 2025 at 10:47 AM
    #113
    Shanet421
    San Diego,CA
    They definitely don’t make them but you could? Or try one of these? I don’t want to have to stand there with some underpaid tech and explain things so just easy to swap on/off
  24. Oct 31, 2025 at 4:13 AM
    #114
    NITEWULF
    ROB
    Raleigh, NC
    How much of a difference in sound did you notice with the helmholtz chamber removed while using the stock tubes?
    This is the route I went, pretty sure yours was less than $330.00.
    https://afepower.com/afe-power-55-12550-magnum-force-super-stock-pro-5r-cold-air-intake-system
  25. Oct 31, 2025 at 4:37 AM
    #115
    Shanet421
    San Diego,CA
    I would say it’s almost identical to what I had before with the silicone tubes. The corrugated or accordion type tubing doesn’t seems to slow down the flow.
  26. Mar 22, 2026 at 8:00 AM
    #116
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Has anyone use one of these cheap intake system? Just for the piping. Skip everything else. Pipe to factory airbox.
    https://ebay.us/m/X7HlIl
  27. Mar 22, 2026 at 8:12 AM
    #117
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    You still need the boots on either end of it. If you just want the piping, the straight piece for the TRD intake is only like 50 during the sales so you'd save money buying the OEM part.
    bulldog93 likes this.
  28. Mar 22, 2026 at 10:43 AM
    #118
    BrandonL812
    Brandon
    I figured the couplers from that kit would work? Have to trim down the pipe though and plug up the maf sensor's hole. Probably not worth it. The trd boots on either side of the pipe is red, would've been sweet if it was black.. I'll keep brainstorming and decide later..
    RobertD[QUOTED] likes this.
  29. Mar 22, 2026 at 10:49 AM
    #119
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    You just asked about the tube, so I was just saying if you are only after the tube the TRD would save you money. If you buy the TRD tube, it doesn't come with boots so you source those yourself. Can get them off Amazon.
    That kit doesn't look bad. I think I was in for 100 between the TRD tube and blue boots.
    BrandonL812[QUOTED] likes this.
  30. Mar 22, 2026 at 11:01 AM
    #120
    BrandonL812
    Brandon
    I think i will get the trd tube and look for thr black boots. I gotta go and and read the thread again to see what boots fit correctly. I can get the trd boot that goes to the throttle body and the engine cover will cover the red. I don't know. Look like i got 2 days left for the 25% off on keating toyota website.
