Air filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by GNX6, Nov 30, 2017.
  1. Nov 30, 2017 at 7:40 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    Anything good/bad as far as an air filter out there? I am NOT leaning towards a K&N as I operate the truck in a pretty dusty area. Thanks!
  2. Nov 30, 2017 at 7:51 PM
    GNX6
    2014 Crewmax
  3. Nov 30, 2017 at 8:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Stick with the OEM filters. No gains to be had other than noise from aftermarket.
    Not sure about difference between the 2 filters. But someone here will
    SouthBoundSteve likes this.
  4. Nov 30, 2017 at 8:58 PM
    Pudge
    CT
  5. Nov 30, 2017 at 8:59 PM
    Pudge
    CT
    Is it possible that one of those part numbers is for the CABIN air filter?
    Or maybe for different engine sizes? 4.7, 5.7, maybe even V6 4.0?
  6. Dec 1, 2017 at 6:35 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I would use an OEM replacement filter or a Wix filter. I bought a Wix filter for my last F-150 and it was made far superior to the OEM version, the paper pleats were much bigger for more filtering area. So when the time comes to replace the one in my truck I will compare it visually to a Wix and go from there.
  7. Dec 1, 2017 at 12:50 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    17801-0P100 should be the one you need.
  8. Dec 1, 2017 at 1:49 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    AFE dry drop in has been independently proven to provide a few ponies.
    15whtrd and SouthBoundSteve like this.
  9. Dec 1, 2017 at 2:00 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I run an AFE Pro Dry S in mine. I can't say that I've seen any noticeable gains from it but I havent seen any negative affects either. Not having to buy another air filter will save me some money in the long run.
    14burrito and SouthBoundSteve like this.
  10. Mar 4, 2018 at 3:22 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    After reading all the comments I can’t tell if it’s just a waste of money or it helps even a tad bit?
  11. Mar 4, 2018 at 6:31 AM
    Marine1
    Marine1 New Member
    Fair Lawn, NJ
    3rd Gen... 2014 Tundra SR5
    K&N filter, LED interior light kit, Rhino Liner, LED head&driving lights, Rough Country Tri fold Tonneau cover. LED Brake, Turn & Back Up Strip
    I the first 3 days of ownership put a K&N insert got rid of that paper shit filter, but in the near future I will be putting in TRD remote air intake that is designed to fit right inside your engine bay and connect extremely easy. Provides nice little growl under full acceleration but it is very tame when driving normal. For an additional note I am adding TRD dual exhaust also designed to fit perfectly both can easily be done in the driveway in a couple hours
  12. Mar 4, 2018 at 6:45 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    I have the Volant intake. The filter is prob one of the best that I have seen.
  13. Mar 4, 2018 at 11:16 AM
    duece292
    Greg
    Green Bay, WI
    I wouldn't consider it a waste of money. Better filtration isn't really measurable but is better for your motor over time. Slightly better air flow might equate to a negligable mileage gain, but a gain none the less. In the end, if you change your filter twice a year at $25 a pop you'll have invested about that much in a K&N or AFE but you'll save that $50 every year after that.
    15whtrd likes this.
