Air filter...what are you running?
Discussion in 'Performance and Tuning' started by Tundra234, Apr 29, 2021.
  1. Apr 29, 2021 at 11:56 AM
    Tundra234 [OP] New Member
    What are you guys using for an air filter? I was considering a K&N or an AFE Pro dry S. I'm still running the stock air filter along with my DD exhaust.
  2. Apr 29, 2021 at 12:42 PM
    Taco-Spike
    Two Trucks
  3. Apr 29, 2021 at 12:44 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    stock AF
  4. Apr 29, 2021 at 12:45 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    stock type paper
  5. Apr 29, 2021 at 12:54 PM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    AFE Dry. Mainly because it's good as new after I wash it out with the hose and blow dry it with compressed air. Don't really think I'm getting any noticeable performance gains though.
    Rocko9999 and 15whtrd like this.
  6. Apr 29, 2021 at 12:56 PM
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    WIX seems to be the best OEM style paper one i've found and always in stock for the tundy.
  7. Apr 29, 2021 at 1:05 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Will change to Wix once the factory one is due to be changed. I just can't rationalize a "high flow" filter because if it's letting more air through, then it's probably not filtering as much junk out...
    Just got a Wix charcoal activated cabin air filter to give a shot. Was really surprised how good Amazon's prices are on some of the Wix items for our truck though.
    2mchfun and Wynnded like this.
  8. Apr 29, 2021 at 1:08 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    WIX. Most air boxes are made for the best airflow possible from your motor from the factory these days.
    2mchfun, jordoncloutier and Wynnded like this.
  9. Apr 29, 2021 at 1:19 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    I dropped in a K&N in the Stock box along with TRD air dam. I'm running a DD exhaust as well. Before adding the exhaust I did this mod and you would hear the difference and feel a little better acceleration. After installing the exhaust it really opened up how much air it breaths now. Love the sound it creates. @Tundra234 I'll try and send you a video clip over the weekend.
    MTRock, Black Wolf and Tundra234[OP] like this.
  10. Apr 29, 2021 at 1:24 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Stock Denso. With just the two clips on the 3rd gen box you need a perfect fit for a good seal on the lower edge. I've heard some aftermarket ones have less than desirable gasket thickness.
    Still on the fence between buying another one or swapping in a used 2nd gen box for the bigger filter and a clip on every corner for more positive seal.
  11. Apr 29, 2021 at 2:49 PM
    eagleguy
    eagleguy New Member
    Played around with different types of air filters for my BBC. Found that the OEM paper had much better air flow and the engine sounded better when compared to K&N and similar with all the fancy wording making you think you were gaining horse power. That said the OEM one is fine and when replacement is due I will go with WIX/Nappa Gold paper like OEM, (same item).
    Wynnded likes this.
  12. Apr 29, 2021 at 3:11 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
  13. Apr 29, 2021 at 3:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I use the Afe Dry pro S. But I do keep a paper one on hand to take with me when I go off road. Try to run that in dirty environments because it filters better.
    Black Wolf and Wynnded like this.
  14. Apr 30, 2021 at 5:56 PM
    I'll install it tomorrow but I ended up getting the TRD filter from the dealership.
  15. Apr 30, 2021 at 6:07 PM
    Kuul. Very similar to the K&N in design and filter media. Basically identical. Both have better air flow than OEM. The OEM is more constrictive by design and will have a higher efficiency spec, but due to simple physics it will have less airflow. I like the reusable factor of the TRD/K&N but don't expect any hp gains at all unless you drive at near redline. Ha! I think you can use K&N oil and cleaner kit. Prolly cheaper than the Yota TRD kit.
  16. Apr 30, 2021 at 6:17 PM
    Yeah I had a K&N in the other truck along with the SABM. The TRD should flow well with the DD exhaust. I thought about doing the SABM on this one, but some have said that they had negative experiences after doing it. It's been a few months so I would have to get back into that thread. I didn't have any issues with it on my 2013.
  17. Apr 30, 2021 at 6:18 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I'm running the K&N, I always have. I have the cone in my 4runner but for the Tundra I just bought a drop in replacement. With how big the stock one is I doubt I'd have more surface area with a cone. Also got the cabin filter because it was a special at autozone.
    Black Wolf likes this.
  18. Apr 30, 2021 at 6:21 PM
    I have that SABM. Bought it several years ago and never installed it. It's in my storage unit somewhere with my cab mount chop plates I bought from Relentless Fab. Dang it.
  19. Apr 30, 2021 at 6:24 PM
    I can't find a discount on the K&N cabin filter. I change my cabin filter every 3 months. My local Advance Auto has the K&N cabin for $39.99. It won't let me use the 20% off code online. :frusty:
  20. Apr 30, 2021 at 6:27 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I took advantage of the $20 off $50 for online order pickup in store promo.
  21. Apr 30, 2021 at 6:31 PM
    Good deal. I may still go over to Advance Auto and pick one up. I change them out so often I might as well. Will pay for itself after 6 months. I've been paying close to $20 for the fancy Purolator charcoal cabins.
  22. Apr 30, 2021 at 6:32 PM
    Kelvin
    Kelvin New Member
    Even on my supercharged Lexus I ran Wix. Same with the cabin filter. Had a lot more pleats than the stock Denso.
    Wynnded likes this.
  23. May 4, 2021 at 9:47 PM
    Autom8ed
    Autom8ed New Member
    Is the WIX model for the 5.7 10085? On the wix website it says thats the model for my truck but Amazon says it doesn't fit.. the Fram option, which does fit according to amazon, is about 3/8" narrower and nearly 2 inches shorter.. ?
    I ask because I need to change mine out and project farm did a test on air filters and these were at or near the top
  24. May 5, 2021 at 1:46 AM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    Stock Toyota Paper for the Intake. The only Cold Air Intake that interests me is the Stillen CAI. It draws from the fender and also from a shroud beside the rad. But to be reasonable, you only really benefit from it if your revving past 4000 RPM. There is plenty of flow from stock and it draws from the fender well, so stock is a CAI. I prefer the paper filter, a friend is a mechanic and he stated you can see a difference in the oil running a high flow oiled filter, he went back to paper.
    I run a K&N in the Cabin.
    Toyota Tundra TruPower by STILLEN Cold Air Intake | Air Temperature Challenge - YouTube
  25. May 5, 2021 at 4:22 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    AFE Pro dry S in the factory Cold Air Intake, I don't off road or travel in dusty conditions, so the AFE filter is perfect for me.
  26. May 5, 2021 at 8:48 AM
    Rocko9999
    Rocko9999 New Member
  27. May 5, 2021 at 9:06 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Wix.
    I office in a dusty, 18 wheeler, train track having industrial environment on the Houston Ship Channel.
    I need filtration. project farm - said Wix....i use Wix.
    Wix cabin filter too.
    Rocko9999 likes this.
  28. May 5, 2021 at 11:44 PM
    Meanjoe
    Meanjoe BT3 USN
    Wayde
    Salem, Oregon
    SOLD: 2020 Tundra SR 4x4 Double Cab Super White Long Bed
    K & N is what I use !!!
  29. May 6, 2021 at 4:46 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I use Wix
  30. May 6, 2021 at 4:56 PM
    Professional Hand Model
    Hand Protectors
    You can feel the extra weight on the Denso. Better quality all around. The thicker baffles help calm air turbulence, as well.
    WILLINH likes this.
