Air Conditioning Not So Good
Discussion in '3rd Gen Tundras (2022+)' started by tcap23, May 26, 2023.
  1. Jul 23, 2024 at 1:40 PM
    #181
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    Just curious.. was that a 1k dealer oil change? My dealer said 10k..
  2. Jul 24, 2024 at 5:52 AM
    #182
    HulkHog
    HulkHog New Member
    2024 Limited Nightshade - 3” dealer lift w/ 20 in. wheels; Nitto RidgeGrappler 35x12.50R20LT
    Out of pocket decision based on some folks suggestions in the forum and given the issues with 22-23 recall stuff. Ended up being comped cause dealer was backed up and I waited 2 hours. I didn’t get the oil or send anywhere for any analysis though.
    Tomnola[QUOTED] likes this.
  3. Jul 30, 2024 at 12:06 PM
    #183
    HulkHog
    HulkHog New Member
    Sounds like swapping out cabin air filter to a K&N also helps - mine is on order and it’s probably suggested in another thread but wanted to mention here as well.
  4. Jul 30, 2024 at 1:37 PM
    #184
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    So I suppose it's no different than using a K&N under the hood in that you're trading filtration ability for higher flow?
  5. Jul 30, 2024 at 2:15 PM
    #185
    HulkHog
    HulkHog New Member
    Apparently? Not sure I’m only making the cabin filter change for now myself.
  6. Jul 30, 2024 at 2:29 PM
    #186
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I like their cabin air filters. I’ve used them for years. I can keep the Tundra at setting 3 and still be comfortable. Where as the factory filter was at setting 4 or 5. Gets hot in Texas.
  7. Jul 30, 2024 at 2:31 PM
    #187
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    These are not the drop in filters for the engine. My allergies see not difference between filters.
  8. Jul 30, 2024 at 2:32 PM
    #188
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    As far as airflow it made a difference. I’m in setting 3 in the Texas heat. Before it was on 4 or 5.
  9. Jul 30, 2024 at 7:32 PM
    #189
    HGParrish004
    HGParrish004 New Member
    Harry
    Raleigh, NC
    2023 Tundra SR5 - TRD Offroad
    TRD Factory 3" Lift Kit, CBI Front Bumper, Baja Designs lighting and Retrax Pro XR bed cover.
    Glad I ran across this thread. I had noticed the weak AC almost immediately in the 3rd Gen Tundra.
    AC got better on its own, but I probably changed settings and got lucky.
    Will get a Carista or similar and try those less accessible calibrations. A lot of things controlled via the ECU in these trucks. Manual dials and knobs are not present in this truck for many functions.
  10. Aug 10, 2024 at 8:40 AM
    #190
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    Sorry was out of town... I did the same and changed at 1k. I don't care what they say. There has to be micro metals in there that should be flushed out. 10k miles is a lot on first time oil. Can only help engine. Now I will do the 10k with amsoil though.
  11. Aug 10, 2024 at 8:57 AM
    #191
    HLR_NM
    HLR_NM New Member
    Harry
    I returned the Carista and bought a proper OBD bidirectional scanner (Autel) The Carista app is too limited IMO. Buy once cry once.
  12. Aug 10, 2024 at 8:59 AM
    #192
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Changed my oil at 1k and again at 5k. Will change at 5k from here on out. Been using Amsoil Signature Series and will do so for the long haul. Also cut my filters apart, nothing looked out place. I save a 100ml from each oil change into test bottles, label and store them.
    Tomnola likes this.
