Air conditioner control panel lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bretta73, Mar 17, 2020.
  1. Mar 17, 2020 at 6:51 PM
    Bretta73
    Bretta73 [OP] New Member
    Savannah
    2016 SR5 Crewmax 4x4
    Has anyone ever had a problem with the air conditioner control panel lights not working on a 2016 tundra SR5 crewmax? If so does anyone know what the fix is?
  2. Mar 18, 2020 at 6:09 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Need more info, new or used,original radio?,did they ever work? Check the panel fuse 7.5 amp it is in the fuse panel inside by the e-brake.
    good luck, john
    BravoDeltaRomeo likes this.
  3. Mar 18, 2020 at 6:37 PM
    Bretta73
    Savannah
    Bought the truck new 4 years ago. Put a pioneer double din radio in the same day I bought it. This problem just occurred this past weekend. I’ll check the fuse inside the truck next to the e brake . Thank you John.
  4. Mar 18, 2020 at 6:54 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    That’s weird. Let us know what it is!
  5. Mar 18, 2020 at 7:01 PM
    Bretta73
    Savannah
    Hey John thanks a lot!! I never knew that fuse box was there.. that was the problem. Working now
    NewImprovedRon likes this.
  6. Mar 18, 2020 at 7:03 PM
    Bretta73
    Savannah
    I assumed all of the fuses were under the hood.
  7. Mar 18, 2020 at 9:43 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    But! Why did the fuse blow in the first place? How do you like that pioneer radio?
  8. Mar 19, 2020 at 7:02 AM
    Bretta73
    Savannah
    Don’t know why it blew. It blew the new one this morning. I’m going to have to dig a little deeper to figure out what’s causing it to blow. Love the pioneer radio.
  9. Mar 19, 2020 at 2:40 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Need to check all plugs/connectors for any that are loose, I have blown a lot of fuses for the power outlets when I had plugs that were loose fitting when plugged in. A lot of people complain about the stock entune radio, but I think it sounds ok for me and when out camping I open the doors and crank up the radio and it sounds great!
  10. Mar 19, 2020 at 5:58 PM
    Bretta73
    Savannah
    I’m going to do that this weekend when I have some time off. I’m hoping that that’s all that is wrong and it’s a easy fix. I’ll let you know what I find.
  11. Aug 16, 2020 at 11:27 AM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Did you ever figure out what the problem is? I just got a 2014 SR5 Crewmax and am experiencing the same thing. The interior fuse labeled "panel" was blown. I replaced it, and it immediately blew again. Stock radio, and my radio won't dim when the headlights are on.
  12. Aug 16, 2020 at 1:15 PM
    Bretta73
    Savannah
    No I have never figured it out. Can’t find the problem I’ve searched and checked everything. Keeps blowing the fuse .
  13. Aug 16, 2020 at 3:59 PM
    swallace
    Steven
    Tri-Cities, WA
    Do you by chance have an aftermarket trailer brake controller?
  14. Aug 16, 2020 at 4:35 PM
    Bretta73
    Savannah
    No I don’t. I have a factory brake controller.
