Air blowing thru dash vents
Discussion in '2.5 Gen Tundras (2014-2021)' started by KCTundra, Dec 2, 2016.
  1. Dec 2, 2016 at 8:41 PM
    KCTundra
    KCTundra [OP] -Caeleb
    Caeleb
    Kansas City
    2016 Crewmax Platinum
    3/2 Ready Lift, 35" Nitto Trail Grapplers, 20x10 Fuel Assault Wheels (-18 offset / 4.75" backspace), BAM Budget Exhaust
    My vents will blow a small amount of air out of the dash vents when the floor option is selected (on high heat fan setting). It's not a large amount nor a small amount. Just enough to feel it on my hands while they're on the wheel. Is this normal?
    Truck is still under warranty and I can take it in but wanted to know if it's normal and by taking it in would be a waste of my time.
  2. Dec 2, 2016 at 8:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When recirculating is off, I think air always comes thru the dash vents. Even when everything's turned off.
  3. Dec 2, 2016 at 9:04 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I get the same thing brother. I thought I was trippin balls because my hands were feeling cold, but I had hot air blowing in my cab!
    thumper7799 likes this.
  4. Dec 3, 2016 at 5:30 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I don't like that Toyota determines what is best for me. If I want air out the floor only then make it floor only. If I want all air off, then turn it all off dammit. :annoyed:
    MatthewPTguy and thumper7799 like this.
  5. Dec 3, 2016 at 12:13 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Agreed!! What the heck. I noticed this the other day while running the heater for the first time.
  6. Dec 3, 2016 at 12:16 PM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    It is intended to keep the windows clear. With auto HVAC it will turn recirc off and blow out the side vents and defogger automatically when conditions are correct to keep the windows from fogging up.
  7. Dec 3, 2016 at 12:21 PM
    I thought I heard someone put if you hit the recirculating air button green light on and your AC is turned off no air blows through any vents
  8. Dec 3, 2016 at 12:58 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you hit the recirculate button it should stop. that's how my tacoma was but haven't tested it out yet on my tundra.
    It's designed like that to keep the windows and windshield from fogging up
    cdkenne likes this.
  9. Dec 3, 2016 at 1:21 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    @KCTundra, thanks for asking that question because I was having the same issue.
  10. Dec 3, 2016 at 3:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, correct
  11. Dec 5, 2016 at 8:25 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    I have same issue, I don't like it! I'm sitting in my 4Runner right now and it doesn't do that. :goingcrazy:
  12. Dec 5, 2016 at 8:55 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep. Normal as apple pie.
    You'll get used to it
    NewImprovedRon likes this.
  13. Dec 5, 2016 at 9:32 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Hey mrLaw,
    How is your mpg with level on 4.6? Just curious...
    Thinking about leveling mine with coilovers in front set at 2".
  14. Dec 5, 2016 at 9:40 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    weird...mine doesn't do this but i have a 2011. not that new fancy stuff you guys have..
  15. Dec 5, 2016 at 10:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Honestly, it didn't change all that much. Lost about 1-2 mpg with the 3/1 level AND going from a P rated 31 tire to an LT 33"
    Do it, it looks so much better than stock but hardly overkill.
    NewImprovedRon and 4RNR[QUOTED] like this.
  16. Dec 5, 2016 at 10:20 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Thanks
    Law323 likes this.
