Air bags for 22 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by moe.morrison, Jun 1, 2022.
  1. Aug 30, 2022 at 1:55 PM
    #61
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Airlift for my '07 and '08 4Runners they had a goofy downward exit for the airlines, required drilling into LCAs https://www.youtube.com/watch?v=RRLz1j5Le3g
    I don't know if Airlift for other Yota rear coilsprings will differ, but I won't do airlines hanging down under the axle when Firestone airlines thread through the top of the bumpstop and are easily wire-loomed and ziptied out of harms way. As always, YMMV.
  2. Aug 30, 2022 at 1:58 PM
    #62
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    I looked over the install instructions for the new kit on their site to see some detail pics of the kit. The lines exit the top side. They are also external to the coil springs on the 3rd gen. The brackets bolt to the frame and replace the factory bump stop. It's really more comparable to the the firestone ride rite bags for the previous gen tundra.
    Acedude[QUOTED] likes this.
  3. Aug 30, 2022 at 2:04 PM
    #63
    Acedude
    Acedude New Member
    Colorado Plateau
    Interesting, kinda like the Timbrens for the 3G?
  4. Aug 30, 2022 at 2:13 PM
    #64
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Bustedandrusted likes this.
  5. Sep 1, 2022 at 2:20 PM
    #65
    StillNervous
    StillNervous New Member
    Hi I am new for tundra and looking LoadLifter 5000 Ultimate or Timbren SES, actually wondering will installing them void my warranty or not?
  6. Sep 1, 2022 at 2:22 PM
    #66
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Nope. Unless the install somehow causes a failure and that can be proven by the dealer/manufacturer, then they can deny a warranty claim. They cannot void the entire warranty though.
  7. Sep 1, 2022 at 2:48 PM
    #67
    StillNervous
    got it, Thank you. I heard toyota would void the warranty for suspensions if we install a aftermarket kit. do you know should we prove if the failure is not this kit causes or they will prove it is. lol
  8. Sep 1, 2022 at 3:53 PM
    #68
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    I've never had to deal with an issue like this but I believe the laws put it on Toyota to prove the aftermarket components or install caused the failure you are trying to warranty.
  9. Sep 1, 2022 at 4:03 PM
    #69
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    crikeymike, Acedude and rideandfly like this.
  10. Sep 1, 2022 at 11:20 PM
    #70
    StillNervous
    Got it, that helps a lot! Thanks, I appreciate it.
  11. Sep 3, 2022 at 8:26 PM
    #71
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Henry1jg, Acedude and H20-bar like this.
  12. Sep 10, 2022 at 9:46 AM
    #72
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Properly equipped torsion bars do wonders for trailering. Yes air bags raise the rear back up but torsion bars actually transfer weight and take a lot of sway out, versus just using bags.
    Here’s a pic of my set up from this morning, completely stock truck with 3700lb trailer and 5600lbs of shingles in it. So total of 9300lbs and just using torsions bars, ride quality is fantastic.
    Henry1jg, Terndrerrr, =JSG= and 2 others like this.
  13. Sep 10, 2022 at 3:05 PM
    #73
    porterbc
    porterbc New Member
    Brandon
    I do love this set up, I will hold out as I might be trying heavier springs front and rear. If not I believe this is the way I’ll be going. 5000lb bags are not required. If they are however, you would be extremely to far past the GAWR for that truck. Start shopping for a dually lol
    1500lb air assist to the coils that seem to work quite well, and will be more then enough.
  14. Sep 15, 2022 at 1:32 PM
    #74
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Curious what WDH you're using?
  15. Sep 15, 2022 at 2:37 PM
    #75
    porterbc
    porterbc New Member
    Brandon
    Curt 14k with sway control
    Dfrink[QUOTED] likes this.
  16. Sep 15, 2022 at 5:11 PM
    #76
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    After of lot of back and forth I decided to get some Timbrens. I'll update once I get them installed and loaded (late October) if people are interested.
    Kap1, Dfrink and porterbc like this.
  17. Sep 16, 2022 at 7:49 AM
    #77
    Scruffy_Nerf
    For those of you who are planning to install Timbrens, I did confirm with the manufacturer that the fasteners should be torqued to between hand tightened and 15 foot pounds. Hopefully the install is as easy as the instructions make it look.
    Sorry for hijacking a thread about airbags to talk about a non-airbag product but I thought it might be relevant.
  18. Sep 26, 2022 at 11:02 AM
    #78
    porterbc
    porterbc New Member
    Brandon
    Had about 14 trees blow down from hurricane Fiona… borrowed my buddy’s excavator. May have exceeded the tow capacity a touch today.. haha
    still waiting for some heavier spring to try out
    Henry1jg, =JSG= and JeremyTRD like this.
  19. Oct 18, 2022 at 4:41 PM
    #79
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Well I’ve had bad experiences with my Firestone 4164’s. I did two 2,000 mile round trips and my right side developed a leak. Got in there and the bag was cut. I am in the process of moving states and paid to have another bag installed and it lasted for about 600 miles and leaked flat. Then the other one blew out violently on the road while towing. I’m pretty sure that one bag was b/c I exceeded the weight limit so now I have ordered OME 2864s to see how those do.
    I have my truck fully loaded with my off-road gear as we are moving and I was towing my wife’s car with a U-Haul carrier.46BB9F70-DEBC-40D4-BD79-AA817864EC03.jpg
    It rode great and basically level with both bags working as pictured here
    =JSG= and Scruffy_Nerf like this.
  20. Oct 19, 2022 at 7:24 AM
    #80
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    This is my worry with the coilrite bags. I like that they are pretty transparent when at minimum pressure and don't limit the already meager wheel travel when off pavement, but I'm worried about durability. I'll be bringing a spare bag with me on long trips with the camper and probably run them until I have a failure like this. Thanks for sharing!
  21. Oct 19, 2022 at 7:51 AM
    #81
    Scruffy_Nerf
    I feel bad for liking this post based on what you’ve had to deal with but this is incredibly helpful information. Thanks!
    PapaDave418[QUOTED] likes this.
  22. Oct 19, 2022 at 8:00 AM
    #82
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Well we live and learn and we are all trying to figure out how to modify our trucks based on our use case. And I was hopeful my $46 bags I got off Amazon would work till I figured my next step. But alas $46 turned into $270 (to have one replaced by a shop) which now has turned into $242 OME 2864 springs!
    Can’t win them all I guess!
    Scruffy_Nerf[QUOTED] likes this.
  23. Oct 19, 2022 at 8:42 AM
    #83
    Scruffy_Nerf
    That’s a good attitude! I would be very interested in hearing about how you like the OME 2864 springs. If you remember, it would be great to hear about the install process, unloaded ride quality impact, and general impression after you get some miles on them. Thanks!
  24. Oct 19, 2022 at 9:21 AM
    #84
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I'd like to hear an update on the OME springs as well!
  25. Oct 26, 2022 at 4:22 PM
    #85
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Well as promised I am reporting back after my triple air bag failure. I did 4500 miles in 6 weeks and had a leak (cut airbag), replaced that side, leaked again then blow out on the other side while towing a car hauler. So the Old Man Emu 2864’s springs went in and they handle the weight really well. It has about 1” rake over the Westcott 3” lift up front, the rear 2” spacers are removed. Idk what it rides like yet unloaded but it’s currently at about 525-550 lbs.
    All of my stuff in the world is in transit to North Idaho so I just have photos for reference and no measurements.
    C7D1193D-D08A-417F-A4FA-CE172EBAABAA.jpg 3F9167E1-1617-42C2-91B1-94932766E3F4.jpg
    Before the 2864’s my fist was almost touching the fender flare. In hindsight the springs are only $242 at Desert Rat in AZ. I know bags allow for adjusting the ride but wish I would have just started there.
    6A91E49D-C4A2-4AE7-AB50-5ABF6AFE9AEF.jpg 3C22678E-8E5E-4BC9-8E5E-5F68F64A3A4C.jpg
    Kap1, TrimTab and Scruffy_Nerf like this.
  26. Oct 26, 2022 at 7:09 PM
    #86
    Scruffy_Nerf
    Thanks for the update! Glad to hear they are working for you.
  27. Nov 5, 2022 at 1:14 PM
    #87
    JohnnieBoy
    JohnnieBoy New Member
    2022 Army DC 4x4
    Icon Stage 3 Method 316's on 275/70/18 Ko2's NYTOP bumper w recovery's Leer 100XR
    Exactly why I finally chose to go with the Air Lift 5000 Ultimate bags. I just ordered them and will do a write up after install and some real time usage.
    FYI: SD Truck Springs is having a sale on both 5000 kits. I got out the door (shipped) for $467 on the Ultimate kit.
    https://www.sdtrucksprings.com/inde...SnxsXttzLTqRtzFmOcpQ8bOUaVcjv5EwaAt58EALw_wcB
    PapaDave418[QUOTED] and Kap1 like this.
  28. Nov 5, 2022 at 1:26 PM
    #88
    JohnnieBoy
    2022 Army DC 4x4
  29. Nov 5, 2022 at 1:50 PM
    #89
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    My bags should be here next week, got em on sale through SD as well…just a heads up, they are saying they are a couple weeks out from having stock unless something changed…I ordered mine a couple weeks ago…I’ll also have an install video on my channel if it’ll help anyone, they look legit!
  30. Nov 5, 2022 at 2:45 PM
    #90
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    I do not have the airlift bags.
