Air bags for 22 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by moe.morrison, Jun 1, 2022.
  1. Jul 19, 2022 at 6:29 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    I have no idea. I have zero experience with spacer lifts of any kind. I'd ask them.
    PapaDave418[QUOTED] likes this.
  2. Jul 22, 2022 at 1:14 PM
    Greenhorn
    Greenhorn New Member
    I contacted Firestone and about the 2022 Tundra and when the actual size would be available, and they told me at best it would be 4th quarter 2022 or 1st quarter 2023 when they are available to the public.
    I can also confirm that the firestone 4164's work on the 2022 Tundra SR5. I installed my kit today after seeing this post and it took me about an hour or so. I did not take the back suspension apart when installing mine. I took a sawzall with a long blade and just cut the bump stop where the directions said to cut it, pushed the airline into the bag, and the fed the airline up through the bump stop and then pushed the airbag into the spring. If your going to use my method with the sawzall, be very careful not to cut anything you don't want to cut. I put my air nozzles on the left side of my license plate because I felt like it was the best spot and easily accessible. I have pumped up to 15lb's right now while I monitor for leaks and then I will probably go down to 8 or 10lb's. The ride a 15lb's doesn't feel much different than stock, but it did raise the back of the truck a little.
  3. Jul 23, 2022 at 9:49 PM
    Simpas1986
    Simpas1986 New Member
    2022 Tundra SR5 TRD offroad
  4. Jul 25, 2022 at 1:59 PM
    Oem1
    Oem1 New Member
    Doug
    Battle Ground Wa.
    2022 SR5
    2" Leveling kit, 20" wheels, 35 x 12.50 tires, step bars
    I just installed these this weekend.
    20220723_115450.jpg 20220723_115517.jpg 20220723_142231.jpg 20220723_134001.jpg 20220723_133945.jpg 20220723_133306.jpg 20220723_133156.jpg
    Henry1jg, Acedude, TrimTab and 2 others like this.
  5. Jul 25, 2022 at 3:33 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Did you jack the truck up at all, or just do it all on the ground?
  6. Jul 25, 2022 at 7:56 PM
    DexterL
    DexterL New Member
    My bump stops look very different from everyone else’s I have seen- all black
  7. Jul 26, 2022 at 5:24 AM
    ThundraTim
    ThundraTim New Member
    1 3/4" front leveling kit , 34" ridge grapplers ,bed step , fuel Wheels rebels 6
  8. Jul 26, 2022 at 6:57 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Yours look the same as mine. OR package.
  9. Jul 26, 2022 at 8:45 AM
    DexterL
    DexterL New Member
    That would make sense. Im going to try the sawzall cut method and am nervous not knowing exactly where to cut.
  10. Jul 26, 2022 at 9:47 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Just follow the instructions. May the force be with you!
  11. Jul 26, 2022 at 11:14 AM
    Oem1
    Oem1 New Member
    Doug
    Battle Ground Wa.
    2022 SR5
    I dropped the axle and removed the springs.
    korslite likes this.
  12. Jul 26, 2022 at 5:59 PM
    MetalManEd
    MetalManEd New Member
    Oem1 likes this.
  13. Jul 26, 2022 at 7:44 PM
    DexterL
    DexterL New Member
    Adding oem vs aftermarket is usually way more expensive and not as solid- aftermarket airbags if they fail are cheap and easy to replace
  14. Jul 27, 2022 at 3:17 AM
    MetalManEd
    Yeah I knew it was gonna be expensive but didn’t think it was gonna be that expensive since it’s only a $650 factory option…
    I was planning on getting it on my 2022 but for what I want adding that is gonna make it an oddball build and would push me back a long while so I’m just gonna get the base truck I want and I’ll add aftermarket bags down the road.
  15. Jul 27, 2022 at 9:07 AM
    DexterL
    DexterL New Member
    $650 option due to the face they don’t have to put in rear springs, bumps, etc so it cuts down the cost!
  16. Jul 31, 2022 at 9:10 AM
    DexterL
    DexterL New Member
    did you jack the truck up to cut the bump stop? I was just under there checking clearance for the sawzall and there is zero chance of getting the blade into position to cut that 4th nub off with the truck on the ground- could be due to me having a hybrid
  17. Jul 31, 2022 at 9:29 AM
    rideandfly
    rideandfly New Member
  18. Jul 31, 2022 at 10:45 AM
    rideandfly
  19. Aug 2, 2022 at 8:39 AM
    #49
    DexterL
    DexterL New Member
    bump, anyone with photos of the black internal bump stop cut? @Greenhorn any info on how you cut them on the truck?
    PapaDave418 likes this.
  20. Aug 9, 2022 at 7:33 AM
    #50
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    I’m interested in hearing from those that did the install without taking the springs out. I just picked up the 4164’s off Amazon. I was going to wait but they had a like new set with free returns for $48, so I grabbed them. Sounds like getting to the bump stop is challenging and a long saws all blade is needed. Secondly, OP I know you said you can’t quite get back to level with your camper, would it have made a difference for you if you left more on your bump stop?
  21. Aug 9, 2022 at 9:46 AM
    #51
    DexterL
    DexterL New Member
    Same, have been waiting for @Greenhorn to chime back in
  22. Aug 16, 2022 at 8:11 PM
    #52
    DexterL
    DexterL New Member
    did you jack the rear end up or do it on the ground?
  23. Aug 28, 2022 at 9:37 PM
    #53
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    Does anyone have experience with the Airlift Loadlifter kits?
  24. Aug 29, 2022 at 3:02 AM
    #54
    eebozz
    eebozz New Member
    I ordered a set of the Airlift loadlifter 5000 last week from Jack-it, I was told there was a 3- 8 week wait on delivery. I currently have the Firestone coil rite helper airbags and I still experience some squat when pulling my 6500 lb trailer. Patiently waiting…
    Scruffy_Nerf likes this.
  25. Aug 29, 2022 at 8:25 AM
    #55
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    You asked above if 4164 will work with a spacer lift, apparently you decided they will and I concur. Coilspring height isn't changed. If in future you install lift coils, taller coils, you'd need a taller airbag. Had that problem with my Runners, 2" Toytec lift coils I had to get taller Firestones meant for a mid-90's Crown Vic.
    Taking off less bumpstop you'd have less contact area on the bag. That may work fine though, IIRC Firestone includes a thin plastic puck for the top of the bag where the bumpstop contacts. Having one would act to spread the load. Best of luck, been happy with Firestones on the Runners carrying a lot of gear and tongue weight. They help control sway also, the rear doesn't dip as much side-to-side, behave much like a swaybar.
  26. Aug 29, 2022 at 9:31 PM
    #56
    Scruffy_Nerf
    I am trying to decide between the Timbren SES, Airlift Loadlifter, or Firestone Coil-rite kits for my slide-in camper install. Any advice or experience would be greatly appreciated.
  27. Aug 30, 2022 at 7:01 AM
    #57
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    How much does the camper weigh loaded? The coilrite kit is just barely sufficient for our camper at about 1000lbs.
  28. Aug 30, 2022 at 7:14 AM
    #58
    Scruffy_Nerf
    Dry weight is about 1,100 - 1,200 lbs.
  29. Aug 30, 2022 at 7:29 AM
    #59
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    I'd be looking at the airlift kit if I were you. And shocks that are valved for the weight. That is my number one issue with the camper on this truck is the factory shock tune.
    Scruffy_Nerf[QUOTED] likes this.
  30. Aug 30, 2022 at 7:32 AM
    #60
    Scruffy_Nerf
    Thanks. I really appreciate the advice!
