AIP/SAIS issue aka limp mode on early 1st-gens?
Discussion in '1st Gen Tundras (2000-2006)' started by fazeka, May 18, 2022.
  1. May 18, 2022 at 2:47 PM
    fazeka
    fazeka [OP] New Member
    Hi all,
    First time poster.
    I'm looking at getting an older Tundra ('01) with the 4.7 V8 2UZ-FE.
    However, back in 2013, I fixed my father-in-law's '05 or '06 Tunrda with that damned limp mode problem.
    Wondering if this problem existed on the pre-'05 V8 Tundras, too?
    Thanks!
  2. May 18, 2022 at 3:17 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Welcome....
    The Limp mode is indeed a function in an 01, as well as 02-06. However, the 01-04 due not have AIP/SAIS since that came out in the 05-06.
  3. May 18, 2022 at 3:48 PM
    fazeka
    Thanks for the info, BubbaW.
    OK, so I guess limp mode can be triggered by other issues as well. At the least, it sounds like I don't have to worry about AIP/SAIS issues with an '01... :thumbsup:
    Cheers,
  4. May 18, 2022 at 5:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yes, there are a number of things that will cause the ECU to initiate Fail-Safe mode which then actuates the Throttle Body Limp Mode lever.
    Past 1st Gen Forum limp mode threads of various issues....
    Search Results for Query: Limp | Toyota Tundra Forum (tundras.com)
    des2mtn likes this.
  5. May 18, 2022 at 5:28 PM
    fazeka
    Ah yes, search feature! :D D'oh! :frusty:
    Thanks BubbaW!
    BubbaW likes this.
  6. May 18, 2022 at 5:33 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    You may already know....check the frame, check the frame, check the frame !
  7. May 18, 2022 at 5:38 PM
    fazeka
    Yup, saw that! ;)
    Was the recall back in '10 for the whole frame or just the crossmember?
  8. May 18, 2022 at 6:27 PM
    shifty` All my rowdy friends have settled down
  9. May 19, 2022 at 9:27 AM
    fazeka
    Thanks shifty!
  10. Oct 5, 2022 at 7:01 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    The Secondary Air Injection System has been implemented on Tundras from 2005 all the way to current. Any model years prior consider your self lucky. Waiting to see if the new twin turbos still have the system but everything else at this time still has this failure prone system. We have Bypass Solutions for all of these models, the anything 2008 and newer we recommend the Gen 2 Bypass Kit. Below I have included a few recent post. Any questions do not hesitate to contact us.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
